Sangerboy
Everything posted by Sangerboy
Gas mileage is still decent (24-29 mpg depending on how much highway driving I do) performance is certainly not what it was when the car was young but it doesn't seem to have degraded to where I feel it is down on power. It doesn't miss and still runs smoothly, I'm most suspicious of an exhaust leak which is what I'll check first. t'll work through these suggestions and see what happens, thanks for all the help
Hello everyone, my 1995 Legacy Outback (340K miles now ) has thrown the dreaded PO420 code, I noticed that Subaru has discontinued OEM catalytic converters. Is there a replacement OEM part # or will I need to go aftermarket? If I need to go aftermarket, what is a quality company to purchase replacement CC's from? Thanks for you help. I am the original owner of this car, it just keeps running so well, no need to replace it!
Final update, after more thorough checking it turned out to be the fuel pump itself. This was very frustrating as it was the first thing I checked and tested it twice, once in the car and once outside after I had removed it from the tank. I guess it just happened to test positive those times and wouldn't work under a load. This threw me but I finally circled back to the true problem after everything else was checking out OK. Oh well, I learned more about the car and once again have great appreciation of how easy this car is to work on. Took the car out for a 35 mile test drive including a good grade on the freeway and everything is working and running perfectly. Thanks again for everyone's help and input. On our way to 350K
OK everyone, here is an update thanks for all the advice and help to this point. I got some noid lights and determined that the fuel injectors were firing so we do not have a computer or sensor problem. I also got an inline fuel pressure tester and determined that there was 0 fuel pressure. Previously the fuel pump had been pumping fuel (evidently sporadically) but now it will not pump at all. I had also removed the pump and tested it outside of the tank and it functioned normally. There was no power being supplied to the fuel pump when the key was turned on and the engine being cranked (the blue/yellow wire at the connector at the top of the fuel tank). I started tracing at the fuel pump relay, the red wire to the relay was hot under all circumstances (normal) the yellow wire was hot during cranking (normal) and the relay itself tested normal so it would appear I have a wiring issue. There is a wiring loom connector in between the fuel pump relay and the fuel pump harness. My question is where is this connector located in the car and what is the best way to get to it? This is the spot where I would like to test next to try and figure out where the short or problem is. Also where does the fuel pump loom ground to?. Thanks again for any help you can give. Greg
Thank you O., I'll check those things this weekend as during the week my job takes me away from where I keep the car. There were no numbers given on the scanner as no codes had actually been recorded by the system. The MIL "ready" codes are evidently "pending" in the system but the Actron scanner I was using won't give a code # until the system has actually decided to throw the code. Just the words- "Misfire, Fuel & Comp". Thanks again for the leads, Greg
Found my code reader, computer is not throwing any codes but car will still not start. Fuel pressure is good, have spark to the plugs, fuel injectors do not seem to be firing. Am beginning to suspect the ECM. The random, sporadic odd behavior of the tach should be a clue (see previous post). Any thoughts by anyone? Am considering buying a used ECM just to test rather than spending $600 on a new one in case that is not the problem. No codes thrown but scanner did list three MIL "ready's" Misfire, Fuel and Comp. After disconnecting the negative battery terminal and placing a new coil. The car started and ran perfectly for about 10-15 seconds then quit again and no start since then. Will welcome any insights
Thanks for the reply, the engine will not start. I've had the cam position sensor go out once before (about 250K miles ago lol) and it wouldn't start just like now until I replaced it. This time though I noticed symptoms in the tachometer for a bit before it failed to start and run. The tach would randomly fluctuate at times (drop a few hundred rpm and then go back to an accurate reading right away) the engine would not hesitate or miss though and I do not remember that happening to the tach the last time. I'm pretty sure the problem is in the crank position sensor or the cam position sensor, possibly both but I was just curious if one or the other was primarily responsible for sending engine rpm data to the ECU since the tach has occasionally been acting abnormally.
I am the original owner of my '95 Legacy Outback and am coming up on 330K miles. My question is which sensor provides the engine rpm to the ECM so that it then sends the information to tachometer in the gauge cluster. My guess is the crankshaft position sensor but I was just wondering if anyone knew for sure.
My '95 Outback has developed a rattling noise at the front of the AC compressor. My suspicion is the compressor clutch. I cannot complain as I've got 327K on the car and it is the original compressor. I was having some issues with the AC compressor cycling on and off but all that was was an overcharged system. I bought a manifold gauge set from Harbor Freight and checked the pressures. Does anyone sell just a clutch replacement for the compressor. Everything else is working fine except that sometimes the compressor won't engage when the AC button is pushed on the dash. It always seems to engage when the defroster button is pushed though. Any thoughts?
No I had the whole unit out and the cable moves freely, also it is easy to rotate the bell crank the last 10-15 degrees by hand to get the valve to release. I just shortened the existing spring to add more tension and it works fine again but I don't know how long the spring will last with added tension and stretch. I may have to check local junkyards to see. I live in SoCal so rust is not a big issue.
After 314 K miles on my '95 Legacy Outback, my hill holder return spring has gotten weak and will not return the crank pulley far enough to release the valve at times. i checked with the dealer but they want a couple hundred dollars for a whole new hill holder assembly, but all it really needs is a new spring. I've considered going to the hardware store finding something comparable and making my own but would like to get a Subaru spring if possible. Any body have a source for just the spring?
That's it, perfect!! Part #6 on the diagram. Labeled simply as "plug", part #807045040. Thank you very much for your help. I'll go by my local dealer and get it ordered. Considering that it has been on the car for 17 years and 302,000 miles, I suppose it has earned the right to leak a little. Who knows how many heat cycles it has been through
I've pulled the engine on my '95 Legacy Outback (2.2 liter) due to some overheating and coolant loss issues (302 K miles so far), also looked for an oil leak that has plagued me for a bit and found that the rear camshaft oil seals were leaking. The right head has a cover plate and o-ring which is no problem and shows up on the diagram, the left head appears to have a 1 piece press in seal that I cannot find on a parts diagram to order. Anyone have a part # for this seal or does it come in a kit? My family says it's time to let the car go but it still runs so good and is so easy to work on that I just keep fixing it. Thanks for any help, Greg
It's time to get into the manual transaxle on my '95 Legacy Outback (I'm the original owner 280K miles) Does anyone make or offer a rebuild kit? (Seals,syncros etc) It has started leaking gear oil and will not stay in 4th gear, 1-2 shift has been sketchy ever since my oldest daughter brought it back from college when she was using it a few years ago. Would like the convenience of a kit, don't really want to go to the dealer and order a bunch of individual parts. Thanks for any help. Greg
OK here's the follow up, Cougar and OB99W, you guys rule!! Cougar you set me on the right path, I disconnected the main relay and tested with success- no blown fuse. I then disconnected all components that run through the main relay and reconnected the main relay then tested- success again no blown fuse. I then reconnected each component and tested after each connection until I found the one causing the short. Sure enough it was the pre-catalyst oxygen sensor. No fried or grounded wires, the sensor had just gone bad. Replaced it and the car is running great again, going to take it in to get it smogged and registered for another couple of years. Thanks again for the help, it is well appreciated
Well of course I spoke too soon, When SBF-2 is replaced and the battery hooked up everything is fine and power is present at the OBD II port. As soon as the key is turned to run position it blows the fuse link. After studying the wiring diagram it appears that the only thing activated on this circuit in run mode is the fuel pump. I disconnected the fuel pump harness and tested, still pops the fuse, I removed the fuel pump relay and tested, it still popped the fuse. Is there anything else on this circuit (SBF-2) that is activated when the ignition switch is turned to on? I'm going to check all the other fuses just to see if anything else is amiss. If I figure anything out I'll report also. Thanks again Greg
Hi , new to this forum, I'm an original owner of a '95 Legacy Outback (260K miles). It quit running yesterday, I'm suspicious of the ECU (tach and speedometer just dropped to 0, no power to the OBD II port) engine turns over and other gauges work but no fire. Coil checks out OK. Before I buy a new ECU (expensive I know) I have a nagging feeling about a fuse or relay. Is there a fuse or relay that sends power to the ECU? In the main fuse/relay box what do SBF 1,2,3,4,5 and 6 control? thanks for any help. Greg
