135
Fairtax4me last won the day on February 17 2018
Fairtax4me had the most liked content!
About Fairtax4me
- Birthday 03/14/1985
Gender
Not Telling
Location
Charlottesburg, VA
Interests
Subarus? Fishin
Occupation
Bait Master
Vehicles
96 Leg L MT Lifted! 95 Leg. L MT FWD
Recent Profile Visitors
Fairtax4me's Achievements
Elite Master of the Subaru (11/11)
1.4k
You should have told them not to do the work and taken the car somewhere else. A rental car for a month is cheaper than a $2200 bill from a dealer. Cams not bent. Yes the journal is out of round, they almost always are. It's just the way the head wears as the cam rides in it. The seal is old and leaking. New cam seals and a timing belt kit cost $300 plus maybe $700 labor from a decent shop.
I think somewhere around 2000 they changed it. I grabbed a spare I had on a shelf and it had a 6203 bearing in it, but the one I put in my 96 a few years ago was deffinitely a 6204. Mame sure you get one with rubber seals to keep dirt/dust/water out. These bearings should not have metal seals for this application.
94 ej in Vanagon dies w/o notice
Fairtax4me replied to blurat1's topic in Vanagon Conversion Discussion
If the ECU loses MAF signal momentarily it will cut fuel, but will NOT set a code, especially on OBD1 computers. When the old square top MAF sensors fail, they drop the signal momentarily due to a cracked solder joint. This causes the engine to stall immediately and with no warning. The MAF can be repaired, but if you have a spare MAF just replace it and see if that fixes the problem. -
Does it have a MAF sensor? Square top with a greenish label on the side? -
The simple answer is that coolant leaked in from above. Radiator was replaced, possible that the old radiator split open and sprayed antifreeze everywhere under the hood. No other way for there to be a noticeable amount of coolant in the plug tubes without there being huge amounts of it in the rest of the engine oil as well.
First need to take that belt off and try to spin the compressor pulley by hand. Most often, a pulley bearing can be replaced with no actual AC work needed. If you do need a compressor you'll probably also be doing an R-134a conversion if that hasn't been done before. It's that or take it to a shop to have it charged with R-12 (common refrigerant used until 94) which is horribly expensive and can't be bought by an individual. Two main parts of the pulley assembly are the pulley itself and the clutch hub on the front face of the pulley. Try to Spin each part individually, and see if there's any roughness. If they won't turn separate of each other there is something jamming the two together which is most often parts of the clutch, and that usually causes the compressor to fail internally. If the pulley doesn't spin or spins rough, but the hub spins smoothly, it just needs a pulley bearing which can usually be bought online. The hub won't spin freely because it's what drives the internals of the compressor, but it should feel smooth when turned.
What Gloyale said or one of the hoses for the PCV/ breather tubes near the back corner of the bell housing might have broken or isn't connected properly.
- 10 replies
- #99legacy
- #legacynostart
(and 2 more)
Tagged with:
