135
80w-90 is the basic stuff, what's recommended in the owners manual. Works just fine. If you want to spend more money on synthetic you can get 75w-90 which offers a bit better cold flow rate. Or if you are hauling heavy loads frequently, get the 75w-140 for better high temp protection. Do not use either of the latter two in the manual transmission. They will cause shifting problems. Fine for use in auto trans front diff though.
There's no specific code that says "blown head gasket" because that's a mechanical issue that the computer can not monitor. There are codes that can be caused by the effects of a bad head gasket, such as misfire codes, P0420, cooling fan operation/temperature regulation codes, etc., depending on the failure mode of the gasket and what running conditions it is causing. What codes do you have, or what symptoms lead you to believe you have a bad head gasket?
I bet you saw the difference between the Felpro gaskets and those cheapo gaskets and understood why everyone here recommends Felpro.
- 32 replies
- head gasket
- oil pan gasket
(and 1 more)
Tagged with:
.1 = 1/10 One tenth of a quart. If you look at the side of a 1 quart oil bottle you'll see it is marked with graduations. Usually 9 marks. Sometimes they're numbered. Sometimes there will also be another scale for deciliters as well. How much the car realy takes depends on the car. Some vehicles the stated capacity meets around mid-range on the dipstick. While others the stated capacity will mark it right at the full mark on the dipstick. Subaru tends to be the former, requiring slightly more to bring the level up to the full mark on the stick. The only way to find that out is to start pouring oil in and see just how much it takes to get to the full mark. It says 5.1, so buy 6 quarts, pour in 5 then start the engine and let it run for 20-30 seconds. Turn it off and wait 2-3 minutes and check the oil level on the dipstick. Add oil if necessary.
More often its the condenser that leaks. The lower corners are exposed to salt and road debris, and can corrode and leak in an area not easily visible. What is the labor rate they're quoting for that? Even at $120/hr labor you're only looking at $1100 for parts and labor. Another $150 for vacuum and recharge. Where they're getting $1,600 from, I think they're trying to hit you with a "blondie" charge. Absolutely get a second opinion. Maybe someone here can recommend a shop in the Northern Va area.
So you've fixed the leak? Are you now still having overheating problems? These cooling systems can be tricky to get all of the air out of. Open the bleeder cap on the passenger side of the radiator to help get air out of the block while filling with coolant. Once full, run the engine to operating temp and the radiator fans to cycle on then back off, then allow the engine to cool completely. After cooling, top off the radiator with coolant if needed. No way to really tell how long it will last. You may start burning coolant immediately, or you may get another 50k out of it. Just be sure to keep an eye on the coolant level. If you notice it getting low and you have to add coolant on a regular basis, time will be limited.
Looks like that seal can be bought from several sources online, partsgeek, autopartswarehouse, for about $6 but shipping is a killer for just that seal by itself. It does look like that seal comes with most of the inexpensive head gasket kits, so if a total reseal is needed, buying a whole kit is worth it, and then you can ditch the cheapo head gaskets and buy a pair of Fel-Pro head gaskets for about an extra $60. (90-98 EJ22 only)
- 32 replies
- head gasket
- oil pan gasket
(and 1 more)
Tagged with:
They've gone up on that one because retail price used to be about $12. Last time I bought one was probably over a year ago. Obviously if evergreen can put one in a $50 kit with a ton of other gaskets they can't be that dam expensive to make. Gonna have to find a better source for those.
- 32 replies
- head gasket
- oil pan gasket
(and 1 more)
Tagged with:
No torque app for iPhone, unfortunately. There are many more options now than there were a few years ago. Most look to be Chinese made with limited functionality, though if you're just reading codes they should work ok. One that looked promising required a purchase for each vehicle and separate purchases for higher functions such as ABS /airbag system scanning. Unlimited use available for about $120 by the time you add it all up, not including the cost of the Bluetooth adapter. One app that was free looked great but the required wifi adapter was $149. One of the first results was a $9.99 app with a "premium" upgrade for another $14.99. (Which I couldnt figure what's included in that) It requires an Eml327 adapter which usually are less than $20.
This o- ring was in your kit? http://parts.subaru.com/images/parts/subaru/productimages/fullsize/11122AA340.jpg That one I paid $9 from the dealer here last time I did a pan seal.
- 32 replies
- head gasket
- oil pan gasket
(and 1 more)
Tagged with:
The compressed air idea sounds bad, but if theres a small leaf or something inside the evaporator box covering the drain hole the air will blow it out of the way. There isn't anything in there to hurt, and the air does a good job of desintegrating dust clumps and leaf crud, then they can hopefully drain out with the water the way theyre supposed to.
I've never bent large diameter tube, only brake and fuel line sized stuff, and some 1/2" conduit, but what I know from that (and kinking plenty of it) is that the tube has to fit snugly into the die. The wall of the die supports the tube wall to keep it from pushing outward as it bends. When the tube has room to wiggle in the die, the walls of the tube will spread outward, and the tube will kink rather than bend. Say you're trying to bend a 5/8" od tube using a 3/4" die. Its going to kink because the die is wider than the tube. Same applies of the die is too small and the tube doesn't fit into it all the way. You can't bend 7/8" Od tube with a 3/4" die. For 1/2" tube you need a 1/2" die. 1-1/4" tube needs 1-1/4" die.
- 1 reply
- 2
For most things that will probably work fine. For really stuck wheel bearings it may not have enough oomph.
