136
Those have big problems with the rear cross-member rusting out so check under the back before buying. They can be purchased used from a rust free area and shipped in, but if that car is rusty underneath all of bolts that hold the suspension parts on and hold the cross member to the frame will probably be seized. That engine doesn't have many issues. The head gaskets weep externally which will cause a slow loss of coolant. By that mileage they're usually leaking enough to need replacement if they haven't been done already. That's fine that they replaced the timing belt and water pump, but unless they replaced all 3 timing idlers and the tensioner it will need to be done again soon. The timing belt doesn't fail on these. The idlers fail and take out the belt with them.
Are all of the lights and everything turning off when this happens? When the MAF signal drops out the ECU cuts fuel so the engine basically stalls. If you're rolling it will come back in a few seconds and keep right on going, no lights or anything because the engine is still being turned by the wheels, even the tachometer will still say the engine is turning because the tach runs on signal from the igniter which will still be firing. If you're sitting still it will stall and the CEL, oil pressure, battery and some other lights may come on, but no codes because the ECU doesn't alway pick up on the problem. It just sees a drop in the voltage signal from the MAF, and decreases fuel input accordingly. Unless you're losing ALL electrical power ( radio, lights, instrument cluster, etc.), that would be a different problem.
Broken solder joint in the MAF sensor. Pretty common on that year and doesn't always set codes. If you're comfortable with a soldering iron you can pull the square top off the sensor and resolder the joints where the pins meet. That usually fixes it, but if not a used one is cheap and they tend to work fine.
Can't say I've ever had much trouble with them, but about half the ones I remove the whole stud comes out. Do you already have the other two totally out? I leave one on each side to hold the y-pipe up while I work on the other side. Keeps it from binding them as it tries to pull down. If they're turning then keep turning them. If they lock up, hit them with some PB and leave them for an hour.
That engine has hydraulic lash adjusters and they will clatter like the end of the world if they bleed out. Use a stethoscope and see if the noise is comiing from the heads. If it is, pull the valve covers and remove the rocker shaft assemblies. The feed port in the rocker shafts and tiny and easily plug up with RTV/or other crud, usually after someone has resealed the oil pump. Blow the rocker shafts out with compressed air, pump up the lifters with fresh oil and re-install.
That thing looks like an old ford. That degreaser stuff in a can doesn't cut cooked on caked up crud like that. Wd40 or PB blaster work great for cutting heavy grease. Spray some, let it soak, spray a little more, scrub, repeat. After a little scrubbing you'll start to see the silver streaks of the aluminum in the brush marks through the grease. Hose it down with some brake clean after you start seeing the silver. Compressed air works wonders as well.
There are about half a dozen relays that AC system uses and they should all be under the hood except for the blower motor relay. Does the relay click only when you push the AC button, or does it click when the blower fan speed switch is turned on/off? When you push the AC Button, do the radiator fans under the hood turn on?
