135
Check fuses first. If the low beam fuses are blown check the connectors at the bulbs for melted terminals. There are separate are relays for fog and head lamps, unless for some reason it has some kind of aftermarket wiring for the fog lights. The low beam lamps and the fog lamp relay are grounded through the hi/lo dimmer switch. If the dimmer switch burns out it can cause this. Possible other sources kinda depend on if it has Daytime Running Lights.
If timing marks were off its usually pretty obvious its off enough to make it run rough. That said, 1 tooth off on the drivers side cam will cause misfires because that's where it reads cam position for fuel and spark timing. Incorrect cam/crank sprockets or dead cam/crank sensor will cause a flat out no-start. No difference in auto/manual sprockets. My initial thought is a bad coil pack. Was that carried over to the "new" engine? Are injectors original or did they come with the engine? If you swapped them did you install new o-rings?
Anytime they use a D= xx in these diagrams that refers to the diameter of a round part such as an o-ring or rubber grommet. I would guess that is supposed to go beneath the shifter assembly around the mounting screws that hold it to the floor pan. Was there any other new hardware included with the cable?
The diagrams make it look like there should be a tube or sleeve that the rod slides into. The adjusting nuts tighten to either side of the sleeve. The white/silver section in the middle of the "fork" pivots doesn't it? That should pivot so the cable doesn't bend when the shifter is moved. I believe you're correct, the two nuts should tighten against that piece in the center.
I think we've heard of this dealer before. The story is familiar... bought out by GM dealer, poor service tactics...
- 23 replies
- TCU update
- Reflash
(and 3 more)
Tagged with:
Mine is a 96 Legacy L. It's gone through an outbacksformation, plus a 2" lift kit. Somewhere that I can't remember offhand someone had specs from KYB with overall height for I think 2nd gen Forester and 1st gen Outback struts. If I remember right the Outback rear struts had longer travel by about 3/4", the front struts by about 1/2". Forester rear struts had a very slightly longer overall extended length. Every forester Ive driven in has a stiffer ride than any outback ive driven, which i believe is due to a different valve rate in the forester struts. I haven't found actual valve rates though it would be nice to see the difference.
If you ordered lift springs for an outback, you should probably use outback struts since that's what the springs are made to fit. The forester struts have different valving and may have different extended lengths which will change spring preload. Most of what I've seen when people put forester struts on the outback, they still need strut top spacers to get rid of the saggy butt look. But those are usually with stock springs. I just ordered kings and new outback KYBs for mine. Hoping I get the same look as the gen1 outback wagon pictured on Primitive's store. Just a tad more arch height in the back than in the front. Except mine will be 2" taller than that.
You did inform SOA that the dealer performed an TCU flash and Did Not note it on the service ticket? That's a big no-no. As far as I'm aware they can perform an update without authorization Only if there is a Recall campaign concerning the TCU, but it has to be noted 1 on the receipt, and 2 with SOA that the recall was performed. Has to be a Recall though. Just a TSB doesn't count. I would definitely go looking around for unplugged or damaged wiring or connectors. Also, check the bottom of the car. Trans pan have fresh dents in it? A reflash doesn't require unplugging or even removal the TCU. The only reason I can see to remove it is maybe to look at it to get a serial number off of it. Shoddy work for them to not reattach the remote start boxes back where you had them.
- 23 replies
- TCU update
- Reflash
(and 3 more)
Tagged with:
