135
The bearings in the rear case can make noise that goes away when the clutch is in, since that takes some load off of the bearings, but those will generally make a constant sound that varies with wheel speed. Faster you go the higher the pitch or louder the growl is. The input shaft bearing makes noise based on engine RPM. It will not change pitch with wheel speed. If the growl you had changed pitch each time you changed gears, that's a bad input shaft bearing and you may be better off to find a used trans to put in the car.
I don't know what plug is recommended for your car. The heat range for the iridiums listed above is 5. Look in the owners manual, or on the emissions label under the hood and find the part number for the recommended spark plug for that engine. If you still have the original plugs you can check the part number on those.
Can you explain what you mean by "hear the knock sensor kick in"? You won't "hear" the knock sensor because it doesn't make noise. If the engine is pinging that could be the whole issue since the knock sensor is listening for the engine to ping. It sends a signal to the ECU, and the ECU will dial back ignition timing in attempts to prevent the pinging. This will be noticed as a lack of power or may feel like a hesitation followed by a surge of power in the upper rpm range. In this case the sensor is responding to an engine condition. Pinging is most often a fuel mixture problem, but can be caused by many factors, including spark plugs with the wrong heat range. If the sensor housing is cracked, the sensor should be replaced, eventually it will corrode inside and either stop responding, or will start sending false signals.
Your compression numbers are far too low for a running engine, those only indicate the compression test may have been done incorrectly or the guage was faulty. The engine you have doesn't typically leak coolant internally. That was a major failure mode on the 96-99 EJ25 engine, but 2000 and later tend to only leak externally. Minute cracks in the combustion chambers are nothing more than casting marks from the sand or foam form used when the head is manufactured. Is the misfire constant? A constant misfire will generally make the CEL flash. If you were to unplug the injector for cylinder 3 does it change the "shake" of the engine at all? How about for the other cylinders?
The R just means its a resistive plug, the iridium plugs are still R type plugs, they just don't have it marked on the side because it's easier to market fancy plugs with a fancy IX printed on the side instead. Most ignition systems are optimized to use a certain spark plug which the engineers who built the engine have found works best with the engine design. Check the emissions label under the hood if you don't have the owners manual, the recommended spark plug part number may be there. What you might have done is put in a plug with the wrong heat range. The temperature of the spark plug makes a big difference, and can cause sluggishness, hesitation, or stuttering. Often the plugs listed at parts stores will fit physically, but have the wrong heat range. Just because it threads in doesn't mean its the right plug.
It's not something you can just poke your head under the dash and look at. The rust happens inside the booster. You may be able to see some by removing the dust boot around the pedal pushrod, but you probably won't be able to tell if that's definitely the problem. The best test is probably to unbolt the master cylinder from the booster. Loosen the bolts or nuts and pull the MC out away from the booster about 1/2". Then try to push the pedal again and see if it moves that 1/2" or so. Typically the booster can be removed without having to remove any brake lines from the MC. Just unbolt the MC and pull it forward a few inches. Then unbolt the booster from the firewall (usually bolted from the inside) and pull it up and out. It may help to remove the pedal pushrod from the booster if possible. Sometimes it just pulls out, other times there is a snap ring or circlip that needs to be prised out, and it's not worth fudging with.
Slooow Fans?
Fairtax4me replied to quazi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I've replaced 5 radiators in the last couple months, all due to split end tanks or leaks at the seams. It's the most common failure mode for a radiator. Sometimes you have a small leak for a very long time before it finally splits open and becomes evident, sometimes it just blows out all at once. Just depends on your luck that day. -
Probably not the MC. Much more likely for it to be rust or some obstruction in the booster servo. The pedal pushrod doesn't actuate the MC directly. It pushes a cylinder inside the booster, the booster pushes the MC pushrod. The boosters on these are known to get moisture in them which freezes in winter weather. Moisture also means rust.
Pull the wheel well liner out and you'll be able to get in there to the attaching mechanism. On the older cars there were bolts or screws there. Newer stuff has plastic latch-tab things that require you to slide this way, hold your mouth just right and stick out your tongue and it will pop loose. I don't know specifically what a Legacy of that year has, but it shouldn't be too difficult to figure out once the liner is out of the way.
You'll see that TPMS light a LOT during season changes. When outside temperatures are changing from high summer temps to moderate and low temps (and vice versa) the air pressure in the tires changes drastically. The best thing you can do is check tire pressures at least once a week in the morning while the car and tires are cold. Keep your pressures 2-3 Psi above the recommended pressure on the door sticker to help keep pressures between checks and avoid having the TPMS light turn on.
- 10 replies
- 1
What wheels are the 16" tires mounted on? Pretty much any Subaru wheel should have plenty of room and no issues with rubbing. If it's an aftermarket wheel or from another manufacturer, how wide are they and what is the offset? Incorrect offset could cause them to rub. With a Subaru wheel, a 205/55/16 will fit fine.
For a. 2013 your dealer will probably be the only source for a missing body part. There is no aftermarket demand for body parts on most cars until they've reached 10-12 years of age. A used part will be difficult to find since most salvage yards consider that to be part of the bumper and would not likely sell it individually. Take the car to a dealer and they can correctly identify, order, and install the replacement part.
