135
Both codes are probably because your throttle and cruise cables are adjusted incorrectly. The cable should be loose. It should be able to wiggle side to side about 1/8"-1/4" easily. You have 2 nuts on the end of the cable sheath. One lock nut which is the closest to the throttle lever. The adjusting nut is on the other side of the bracket, towards the front of the car. Loosen the lock nut, then spin the adjusting nut to adjust tension on the cable. If you spin the nut towards the lever, it pulls the cable tighter. Away from the lever will loosen the cable. Once you get it adjusted tighten the lock nut while holding the adjusting nut in place.
That one has a dowel pin which can get stuck pretty good. Kinda need to wiggle and twist and pull all at the same time to get it loose. The condensers like to corrode and develop leaks on the bottom corners where they're exposed to dirt/rocks being thrown at them through the lower grille. If its above that, probably just the o-ring. Don't need to remove the radiator to get the condenser out. Just have to remove the upper support and push the radiator toward the engine. Two bolts behind the grille hold the condenser. Remove those and slide it up and out between the radiator and support.
I've tinkered with this idea as well. I may try soon. I need to put a new toothed idler on my 95 soon because its making noise. All the other bearings are nice and smooth. The cam sprockets over here have 48 teeth so slightly more advance in timing at 7.5°. I just wonder if its too much advance since most of the low end setups I've done are v8s that usually get only 4°. I've searched for adjustable cam sprockets but they only seem to be available for DOHC heads and they're prohibitively expensive. I've also not found proof that they will actually work on SOHC cams.
Possibly the input seal on the trans got shredded. Easy to do with the sharp corners on the TC pump drive. Make sure you didn't just cut one of the ATF cooler lines from the trans to the radiator before pulling the engine again. No-start problem... Did you make sure the cam sprockets didnt get mixed up when you removed them to replace the cam seals? Drivers sprocket has notches on the back for the cam position sensor. No cam sensor signal = no start.
- 8 replies
- ej22
- timing belt
(and 1 more)
Tagged with:
Can you tell where the lock plate was on the ring? If you can see that then you're golden, if not just turn it until it stops then turn it back about 2 teeth like lmdew said. Clean up any rough spots with sand paper and/or a file before putting the new seal in the retainer ring. As long as you didnt screw up the threads it'll be fine.
Are you sure the feed hole in the rocker isn't plugged? Having both bleed down is almost always an oil feed issue. Not hard to disassemble the rocker shaft and clean everything out. Not sure about OE vs aftermarket on these. DNJ seems to make decent parts but I haven't heard anything about the lifters specifically.
I can usually tell when the car starts moving. Happens all the time.
- 17 replies
Oil pump in the trans is probably cracked now. That is almost a guarantee if you force the engine and trans together when the torque converter isn't seated properly. I think there is a circlip at the end of the input shaft which requires some effort to get it to pop loose. I don't remember for sure though. I've never had to reseat the torque converter on a Subaru. I always take extra measures to make sure it doesn't move. The can of worms you open by removing the TC is way more effort than bolting a wrench to the bellhousing to hold the converter in place.
That looks like a mirror for a 95-99 legacy. Either way, Outback heated mirror this is the only part that comes up:http://opposedforces.com/parts/info/91032AE29A/ fits Outback limited, cold weather, and LL Bean. Also some Baja trims. All of these would be equipped with heated mirrors which were larger.
A size larger or smaller will throw off the speedometer, though only by a few percent. Google tire size calculator and compare your stock size to the sizes you're thinking about getting to see how far off it will be. Most of these the speedometer reads about 3-4mph too fast anyway, so bumping up to a larger tire will help to correct that. Clearance is not an issue with such a small change in size. 16" wheels don't solve the tire size problem because the 16" tire will also be an inch larger diameter.
That's no good. Possible the heater 12v feed wire touched the ground wire when it got disconnected and cooked the ground circuit in the ECU. Probably want to check voltage at the pin in the ECU, and make sure there's no crud in the ECU connector. I don't think the front sensor has any other connectors between it and the ECU, so not much chance of a poor connection unless its at the sensor connector.
