replacement headlight bulbs
Fairtax4me replied to buzzcon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is the nature of Silverstar bulbs. I've been through quite a few of both the standard silver star and the ultras. Great light output, the ultras are godawful expensive, and they only last about 4-6 months. Same story in all 5 of the cars I've used them in.
What sealant?
Fairtax4me replied to samm's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI bought a $12 tube of Anaerobic sealant (5-6oz.) about three years ago. First thing I did was use it to reseal an oil pump. I've since used the same for 4 more oil pumps, 3 separator plates, and to reseal the case halves and tail sections on three transmissions. There is a lot of surface area to cover on a transmission case. I still have about half the tube.
(ej22) rear wrist-pin access cover o-ring?
Fairtax4me replied to blues's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou would be surprised at how much can leak from that stupid o-ring. New o-rings are only $2 or so at the dealer, they usually keep them in stock. Worst case, that cover could also be sealed with Ultra Grey RTV or Anaerobic sealer.
Weird Vibration
Fairtax4me replied to axgutt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXU- joint is a good possibility. Bent wheel or bad axle come to mind too. Clicking is only for outer CV joints. When the inner joints wear they tend to just get out of center a little and wobble. Makes the whole axle shaft move in a circle as it spins. Kinda hard to check though.
5 speed issues after new syncros
Fairtax4me replied to torxxx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPerhaps the shear pin in the shift fork sheared and the fork will only go forward? Are you sure the fork centered between the collar correctly?
93 legacy 5sp wont go into gear (cable clutch)
Fairtax4me replied to subestyle18's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood chance the release lever cracked. Possible the pressure plate is damaged or the clutch disc fell apart but they usually make some racket. Easier to hold heavy clutch components while reaching over the fender or laying under the car, or easier to put engine on a work bench or crate to work on the clutch? The release fork is only clipped on and is fairly easy to remove. Get new clips for the throw out bearing while you have it apart.
Audio/Electical folks: No sound from McIntosh stereos...not solved...
Fairtax4me replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCan you post a picture of it? How many pins are in the cable? You say the connector on the amp twists? Does it have pins soldered to the PCB or wires?
Crank snout....repair?
Fairtax4me replied to Numbchux's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCommonly covered topic here. Quite a few threads on repairing the key way and crankshaft after having the crank pulley walk off. Basically consists of removing what's left of the key, filing down the gouged sections a bit so the sprocket can slide over, filling the key way with epoxy or weld so a new key can be properl placed, then installing a new crank pulley and bolt. Torque to something like 140 ft lbs to prevent the bolt from backing out again. Guess the good news is she recently had the timing belt done. But did they replace all the idlers and water pump?
Keep it or Sell it!
Fairtax4me replied to murphsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's all the usual stuff except burning oil, and that could be as simple as a plugged PCV valve. Exhaust pipes rust and rubber parts (boots, tires, etc) wear out. What code do you have for the EGR? That could be a simple fix like cleaning the EGR valve or replacing a vacuum hose. Probably worth $2500 or better, could be a good buy for a local mechanic or like Texan said, someone's kid who needs it to get to school. I would think you could have all of that fixed for under $1500 if you can do some of the work yourself. Tires and exhaust being the biggest expense.
How heavy is a 4EAT, will it fit in the hatch?
Fairtax4me replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCan't possibly be as heavy as a 4L80-E. Talk about heavy! You can also lose a good 40lbs by removing the torque converter, this presents its own challenges though.
This is a Subaru?
Fairtax4me replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis makes a good "You might be a Subaru owner if..." ...It took you a minute to realize there's a girl in that picture... ...You think it's a shame they didn't draw it in permanent ink...
No cel but dead cylinder?
Fairtax4me replied to bork's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDis you set the meter to the Mega-ohm scale? Did you try anywhere else besides the base like the metal part on top? Sensor should test somewhere around 580K (580,000) ohms. If the sensor were open internally the ECU would have set a code just like if it was unplugged. Perhaps there was a cold solder joint where the signal wire joined the sensor element causing very high resistance but not enough to trigger a CEL. Maybe the sensor design is different and the base is electrically isolated from the element. Hard to say. Either way, a new sensor should pass the ohm test just fine. Very strange that it doesn't.
Fairtax4me replied to bork's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs your ohmmeter auto-ranging or manual set? Do you get a 0 ohm reading by touching the leads together?
Welcome me to the 'noisy front diff' club
Fairtax4me replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's a pretty sweet deal!
Fairtax4me replied to bork's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt grounds to the engine block through the base. Put one lead on the block somewhere easy to get to. You may have to scratch some dirt out of the way to get a good connection. If that doesn't work unbolt it and check resistance to the base of the sensor. There could be some corrosion on the block under the sensor.
Fairtax4me replied to bork's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXKnock sensor should be roughly 580k ohm. It's probably fine if it has already been replaced. If there is any corrosion on the housing that can alter the voltage signal. O2 sensors either Denso or Bosch is OE. I've seen both on the soobs ive worked on and either seems to work fine. If you get the Bosch universal fit make sure you know which wires to connect. Denso exact fit sensors are usually pretty cheap through Rockauto.com. (Around $50)
2000 2.5 SHOC into a 2002 Legacy
Fairtax4me replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would stick with the 02 manifold as John suggested. Try the rubber hose EGR trick to keep the CEL away if the 00 head doesn't have the EGR port.
Fairtax4me replied to bork's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd you're positive you have no vacuum leaks?
Fairtax4me replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes I believe the green wire goes to a radio signal amp. Not the speaker amp.
Pulling EJ22, Can't remove Flex Plate bolts...
Fairtax4me replied to suprunner's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI use a 12mm socket on the end of a serpentine belt tool. Just enough room and plenty of torque from the 18" handle. A 1/4" drive ratchet works as well. Most you can fit the handle of a small floor jack over the handle of the ratchet for extra torque.
Odd ABS question
Fairtax4me replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat code did you get? Did you wiggle the wire around while checking the resistance? Could just be an internally broken wire. Takes 16 miles for it to move just the right way before it breaks the signal. You could also test it by connecting a voltmeter set to AC and spin the wheel. $125 is a waste of money for a sensor. They all work the same way, just find one in a junkyard that looks the same and has the same plug.
Odd ABS question
Fairtax4me replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow do you figure it's dead? I guess you've checked the codes already to know its seeing a fault in the RR sensor?
2002 Subaru Outback - CEL - P0065 P0137 P0138
Fairtax4me replied to ibroad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA head scratcher. Doesn't make much sense to get both high and low voltage codes for the O2 sensor. I would have to guess that's going to be a loose connection, possibly a chafed wire. Air assist injector I'm not sure about. Would have to look it up in the FSM. What engine is in the car?
Trans noise final diagnosis before buying a trans
Fairtax4me replied to CNY_Dave's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like an old tractor transmission with straight cut gears. Time to tear it apart and have a look at the carnage.
This is a Subaru?
Fairtax4me replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've wanted one for a long time. Never seemed entirely practical for me to have a two door car though. Maybe someday. I seem them pop up on Craigslist from time to time usually for under a grand with a dead transmission or a half primed rice-ject that someone abandoned because they couldn't figure out how to fix some random issue.
