135
Frankenmotor question. Searched.
Fairtax4me replied to xbeerd's topic in NA Fuel Injection Engine Tech
Typo on my part. Should be X. W is 1998. I edited the previous post with the right letter. -
Emergencey: Stolen Legacy Seattle!
Fairtax4me replied to Ratty2Austin's topic in Meet n' Greet. Your USMB Welcome Center
Glad to hear you got your car back. Sucks about the tools though. Keep a watch out on Craigslist. Those fudgers will get what's coming to them. -
Been a while since i've been on here....
Fairtax4me replied to Ceejus's topic in Meet n' Greet. Your USMB Welcome Center
Body damage, rust, and torque bind? Timing parts at that mileage should be a given no matter the service history unless it was just done and the seller has receipts. I wouldn't budge an inch over $500, I'd even go for cheaper than that. -
Like Ivan said, check the input shaft (main shaft) for play. There may be a small amount, but if there is too much it means the mainshaft ball bearing is worn. Also possible the seal just went bad. In which case, its about $10 from a dealer and takes an hour or two to replace. Most of that is cleaning the case halves before reassembly.
Check the VIN etching on the bell housing. Tenth digit should be a X for 1999. This would tell you the model year of the vehicle the engine came from, if it is not original to the car. -
Coolant level is too low. Fill the radiator as much as you can, and fill the overflow to about halfway up the bottle. Check for leaks before and after driving, and check the coolant level EVERY morning before starting the engine. If you have a very slow leak it can take weeks or months for the level to go down noticably. If the level drops quickly you may have a more serious leak or possibly bad head gasket. Keep a close eye on the coolant level and make sure it's always topped off to avoid overheating and potentially causing head gasket problems.
Gotta go with clutch slave cylinder on this one. Seals in it are more likely to go bad because of the heat, and any water that gets in the fluid (natural for brake fluid, even in a closed system) will eventually settle in the lowest part of the system which is the slave cylinder. Water causes rust, rust eats the seal on the piston.
I don't know that Exedy makes brake master cylinders. And no the part in that listing will not work. That listing is for a CLUTCH master cylinder. Same principle different part, not interchangeable. I have never had trouble with parts store rebuilt MCs but I can't say how long they'll last. I think I've bought maybe two ever and I didn't keep the cars long after. I've had good luck with used MCs though.
The water pump leak could just be the bypass hose or the thermostat housing. I'd try to confirm the source of the coolant leak and address that first. The separator plate leak can be put aside for a little while just keep an eye on the oil level. If you find the water pump is leaking replace the front cam seals and put a timing kit on it when you replace the pump. Good kit on eBay: http://item.mobileweb.ebay.com/viewitem?itemId=260925109309&index=0&nav=SEARCH&nid=42621810424 Comes with cam and crank seals. Aisin water pumps are OE for many Japanese cars.
I may swap the manifold just for giggles sometime. I'd really like to know the actual cause though. If I move everything with the manifold it's harder to know just what's faulty. After riding around for about a week now with my false knock sensor plugged in I have noticed a small increase in power overall, and an occasional ping here and there, but I still get periods of random power loss. Since I can't seem to make the problem happen on a consistent basis I'm just going to swap out one part at a time and drive a week in between to see if there is any noticeable difference. If I stick to that schedule, I should have every sensor/electrical part changed out by about March. :-p
The California sensor has a shorter wire harness I think because it was placed further forward on the exhaust. Other than that I don't think the sensor itself is any different. Does the listing give the length of the pigtail? I saw the cheap prices of the off brand sensors on rockauto and am tempted to try one, but just to save $5 or $10 it might not be worth the hassle to have it fail in a year (if it even lasts more than a day) and have to replace it again. One other thing to check is the shape of the connector. There are slots on the sides and/or top that keep the wrong sensor from being plugged into the harness. You might also just check the wiring going to the sensor for damage before replacing it. A heater malfunction isn't an uncommon problem but there could be other reasons for the code, such as damaged wiring.
Pull the engine and do a reseal. $225-250 you can do timing belt, all idlers, water pump, all the cam seals and o rings, front crank seal, oil pump reseal and o ring, separator (baffle) plate reseal/update with new steel plate if needed, and valve cover gaskets. Don't forget the $2 o-ring under the rear wrist pin access cover. (It's the diamond shaped cover left of the rear main seal) Step by step picture write-ups for all of the above can be found at The Beer Garage: http://beergarage.com
Like press said, each winding (wire) is basically a circuit all it's own. The copper winding is coated with an insulator so the electricity flows all the way through the length of the wire rather than jumping straight across to the closest exit point. If its a brushed motor the open or shorted windings will create a dead phase. You'll get no "push" no magnetism from that winding. As the motor turns around you basically end up with the equivalent of a misfire to a gas engine. It causes the rest of the motor to work harder and creates more heat. There's also the possibility of the broken strands breaking loose and shorting against the case while the motor is turning. Do you like fireworks? I'd see if there is a motor place nearby that can rewind it or source a new armature. If its an induction motor (3 phase?) I'd just solder the broken ones together. The affect depends on the number of turns and just how any windings are in each coil. Probably wont notice too much difference but it would be wise to monitor the temperature of the motor and the "repaired" coil for a while just to make sure it isn't going to overheat. (Could catch fire or burn out the solder)
P0420 catalyst efficiency below threshold. P0440 evap emissions system. You got the wrong codes. Your definitions are for codes P1400 and P1420. The pressure control solenoid valve is located above the charcoal canister behind the right rear wheel. All of the metal parts back there are prone to rusting. I don't envy you having to remove the canister to get to that valve. I'd expect some corrosion in the wiring or inside the connector. Good possibility of mouse damage too.
