136
Battery is low. Probably had a poor connection when you tried to jump start it. It's better to disconnect the battery and charge it if possible, rather than jump starting.
- 4 replies
- clicking noise
- starter
(and 2 more)
Tagged with:
Does it have the electronic throttle body? Those often idle low for a while until the ECU has a chance to adapt new idle speed settings. One thing you can do is reset the ECU by disconnecting the battery negative for about 30 minutes. When you reconnect it turn the key on wait about 5 seconds then turn it back off. Do that a few times then start the engine and let it idle on its own. Don't touch the throttle at all. Let it idle until it warms up to operating temp. If it stalls at any time just turn the key off and restart. Let it do its thing and learn proper idle settings.
Dynamic compression is different than static compression. Static compression is what you'll measure when cranking the engine during a typical compression test. Dynamic compression is measure while the engine is running. Testing dynamic compression can show you if the compression in one cylinder is dropping at higher RPM due to a valve problem. Typically high rpm misfires will be due to fuel starvation or incorrect valve timing, which can be caused by several things. I would pull the valve cover on that side and readjust the valve clearance. Loosen them up some, especially the exhaust valves. Another thing I notice is you say the fuel pressure sits at 52 psi all the time? Even at idle it's still 52 psi? That's indicative of a stuck or clogged fuel pressure regulator, or the vacuum hose to the regulator is broken or no longer attached to the regulator or intake manifold properly.
Get the factory service manual for your car and check the wiring for the dimmer switch. The switch controls the ground side of the lights, so if pulling the stalk makes the high beams turn on the wiring up to the switch is probably Ok, but you could have a bad ground. If the switch really is the problem, you could install a relay for the high beam ground that gets triggered when the low beam ground is taken away.
I was thinking this would be one of the type that sits up on the strut tower where the fuel lines run up before they go to the engine. If it just threads onto the rail maybe you can find a plug or a bolt with the same thread and screw that in place of the damper. If that engine sat for several years you may need to have the injectors cleaned to get the varnish out of them.
Is the harness aftermarket? The only reason for needing power from the battery would be if you have trailer brakes and you need a charge wire for the breakaway battery on the trailer. Normally I do not run those directly to the battery, I use power for a rear outlet or some other switched supply that is only hot when the key is on so the trailer battery doesn't drain the vehicle battery for various reasons.
Sounds like clutch chatter. Fairly common with replacement clutches especially the chinese ones that a lot of parts stores sell. I use Exedy clutch kits and haven't had any issue with this from their kits. Usually around $150 online. You do have to check and make sure that both the clutch disc and pressure plate are Exedy brand. Some kits have an Exedy disc, with a Chinese pressure plate. Take it back to the shop that installed that clutch and have them install an Exedy clutch kit.
I'm not a fan of dayco belts. Lately it's getting hard to find timing kits that have good idlers in them. Gates kits on Amazon are around $100. A bit more with the water pump. NSK, Koyo, NTN are all Japanese and good quality. Gates tends to use these for the idlers and have seen GMB tensioners in them. For the one piece tensioners I would probably not even use the cheapie that comes in the kit. Get an Aisin or OE Subaru. I also use Aisin water pumps. Aisin is an OE supplier for many Japanese manufacturers.
Probably coming from one of the lines where it runs across the back of the rack, or from a fitting where the lines attach to the spool housing. Most steering rack leaks end up running toward the center of the lower crossmember and drip down the center. Follow the lines and you'll find it.
- 3 replies
- legacy
- powe steering
(and 1 more)
Tagged with:
If the rotor has been replaced before it's possible the inner lip of the park brake drum is rubbing against the backing plate. There will always be some drag from the brake drum against the shoes. It's unavoidable, and it's normal. But it shouldn't be a scraping or grinding sound. It should just make a mild hiss sound as the rotor spins.
If you cut wires with the ECU still plugged in or unplugged the ECU with the battery still connected, its probably cooked. The knock sensor wire is shielded. Has a grey outer insulation and a braided sheild section outside of the insulation for the signal wire. Did you cut through the shielding, and did you solder the shielding to the signal wire when you tried to repair it? The shielding is grounded and needs to be kept separate from the signal wire.
- 11 replies
Think of it like a shock absorber for the fuel line. Gas comes up under high pressure, and every time an injector opens that pressure drops a little then bounces back. Somehow they figure that eventually causes things to wear out, and it can create a clicking/rattling sound coming from the fuel lines or fuel rail. If you think thats the problem, remove it and run a straight section of high pressure injection hose as a temporary fix.
