Fairtax4me
    136
  1. Unless you have dead level flat concrete I wouldn't recommend having the whole car up with the wheels spinning. Remove the wheels and use two lug nuts with washers to hold each of the rotors tight on the hubs. This takes inertia from the tires and wheels out of the equation. And if something slips, the car won't launch when it lands on the ground. The term "differential" gets kind of loosely tossed around and used to describe the whole assembly including the ring and pinion gears. The ring gear, though attached, is not part of the differential. The ring and pinion gears are merely the final reduction gear set before power is sent to the wheels. The four small spider gears inside the differential carrier are what make up the differential (they allow a difference in speed between the wheels when turning). Those gears typically do not make noise unless the vehicle is turning. The ring and pinion gears are what make the whine sound that changes pitch with throttle, and are far more susceptible to wear due to a low fluid level. Most of the heat generated in the assembly is from friction between the ring and pinion gears.
  2. Bulbs are cheap. Flashers (the relay that blinks the lights) are usually pretty cheap too, but a bad flasher should make both bulbs act the same. One bulb doesn't blink says bad filament to me, worth at least replacing the bulb with a spare to check if you can't confirm otherwise. Might check the sockets for corrosion and tight fit, especially the one that doesn't blink. Poor ground is possible too. Signal stalk is big $$$. Checking bulbs and sockets and grounds for corrosion is free.
  3. Legacy wagons if they had rear speakers would only be in the rear doors. No speakers in the cargo area.
  4. Supposn it's possibly the airbox on the throttle body isn't assembled correctly? Only other thing to make sounds like that would be a driveshaft carrier bearing or differential. Differential noise should be pretty evident at higher speeds (about 60) as well.
  5. R.I.P. Blu. FEMA is about worthless and so is the Red Cross lately from what I've read. No personal dealings with either and I'd like it to stay that way. I'd say you made it out pretty well compared to many others, despite the shortcomings of the so called "assistance programs".
  6. I would think them to be 6.5" round same as the legacy of that era, but I may be wrong. It's also possible someone already swapped them at some point.
  7. One of those between years where Subaru was updating brake parts and just tossed on whatever they had left. Definitely something to look out for though. These tend to be very easy to knock off so I wouldn't doubt the shop may have lost them and didn't even realize it. $20 for a set seems stupid expensive though. Almost wonder if the dealer stocks them cheaper. Rockauto lists them for $5-6, But shipping from them sucks for something so small.
  8. When did jumped timing due to the lack of this guide become an issue? I had heard of some newer cars having problems with that during transport because of the car being rocked around while in gear. It seems to me that EJ engines were sold for about a decade before this little idea came up, how frequently can jumped timing be traced directly back to this guide plate not being in place? Seems to me the timing tensioner should hold adequate tension on the belt to prevent jumping.
  9. Simple fix: Fill the engine through the upper hose before attaching it to the radiator. Have never had an issue with overheating after a coolant change using that method.
  10. Front seats, suspension parts, wheels, brakes maybe. Alternator can be used if you swap the plug. AC compressor maybe. Other than that I'm not too sure.
  11. There won't be any different info in a car fax report. Autocheck and CarFax use the same sources to find information, most of it comes from DMV records. If the DMV record is incomplete (no mileage data, etc) then it doesn't show up on the report. I'm a little skeptical of this car because the price is just a little low. I would have the car checked over by a competent machanic and a good body shop (look for repaired frame damage, recent paint work,etc) before taking the plunge.
  12. That's why he asked. Dual port EJ headers will fit an EJ18 Impreza, not an EA81 /EA82 1.8.
  13. The coil could have cracked or could be carbon tracked. Clicking could be the spark jumping straight to ground. Could be evident at night but not guaranteed to actually see the spark where it jumps. (Could be an internal jump) I'd replace the coil. The old 2.2s are not particularly picky about plugs or wires. I just use regular copper NGKs and have car-quest wires.
  14. You need to unbolt the fuse panel from the fender and the lower cover can be removed. The main power wire in to the fuse box is just held on with a bolt/nut. It could be frayed or corroded, or the branches that go from there to the fuses could be corroded or damaged.
  15. You're on the wrong marks. The passenger side cam should not be under any tension when aligned to the proper timing mark. I think you used the arrows instead of the dashes. Fear not, as when the cams spin it's because the valves are CLOSING. Review the proper marks for timing, then turn the crank to proper alignment first ( should only be 90 degrees clockwise) then set the cams. When set properly: The passenger side should rotate about 20 degrees in either direction of the timing mark with little/no resistance because the cam lobes will be between the rocker arms and there will be no spring pressure applied to the cam. The drivers side cam should sit still and will have spring pressure applied directly on the nose of the lobes. This will make the cam difficult to turn by hand, and moving it more than a few teeth in either direction will cause it to snap over. Arrows on the cam sprockets will point 45 degrees to the right. Arrow on the crank will be at 90 degrees to the right. (as viewed directly) Dashes for timing! Not arrows Only differences I know of for water pumps are turbo vs non-turbo. Turbo pump will have multiple outlet pipes and a front facing thermostat opening. Non-turbo will have one outlet and down facing thermostat opening.
  16. I'm glad you think that way, but there are a LOT of people who don't. It only takes one ********************* person to put a business under and ruin the reputation of (and possibly imprison) a good person such as yourself who is trying to make a living selling tires in his/her shop. Nearly every shop that does any type of automotive work has a disclaimer already on their invoices, and require that you sign the invoice stating that you firstly: authorize the shop to work on your vehicle, and secondly: understand the risks that may be involved, and thirdly: release the shop of liability if a part fails, except in the case that said part is covered under a warranty, which is usually also included on the invoice. What's BS is that they have to have that disclaimer at all. In a perfect world, it wouldn't be needed. But in a perfect world, we would all drive Lamborghinis and Ferraris (or what-have-you) and would never have to worry about tires, or anything else for that matter.
  17. Just comes down to liability. They put on tires with the wrong rating, someone gets in an accident because of a blowout, tire shop gets sued. Simple as that. They're covering their own because when their insurance finds out they didn't mount tires that match or exceed the factory specifications, insurance tells them they're on their own. And the lawyers will eat them alive.
  18. I think there's only one way we're gonna find out. Even if its not the same, can't be that hard to modify it to fit.
  19. Welcome! Funny that chassis under the Frankentruck is so recognizable! Is that all band equipment stacked up in the back?
  20. Yes there is. Dealerrater.com. Most people here go to the dealer only for parts. Occasionally a thread gets posted asking for or voicing opinions on a particular establishment, but no section of the forum devoted specifically to that purpose.
  21. I would check in the offroad sections. The rally guys pretty much have to have fuel cells, and the offroaders use them as mentioned before to keep the tank from being ruptured out on the trails.
