135
As far as I know the parking brake is separate from the caliper on those. It uses a separate set of shoes inside the inner drum of the rotor. It's not until later years (05 maybe?) that the park brake is part of the caliper, and even then you shouldn't have to remove the cable to get the caliper loose.
Is there not an arrow on the splash shield pointing to a spot along the seam? You can lift the car by the rear cross member, but the jack may not lift the car all the way off the ground from that point. There should be a notch or something in the pinch seam where the jack should go. Worst case, you can lift the car by the outrigger for the diff mount where it bolts to the chassis near the trailing arm. In this pic, the large bolt with the circled number 2. http://static.opposedforces.com/epc_img/366495020101.png You can lift from there with a floor jack. But you should still find the correct place on the pinch seam to place a jack stand while you work.
Play at the output stubs from the front differential is normal. They are high clearance and offer quite a bit of wiggle room between the stubs and the diff carrier. A bad center diff can make clunking sounds, but usually causes binding when turning tight circles. The car will not roll easily, you will have to give a LOT of extra throttle in order to make tight circles. The car will jerk/jump and the tires will squeal on asphalt. There was a year or two that the center diffs had problems, but their failure mode results in the diff basically exploding and usually taking out the transfer gears with it, which eventually leaves you with NO drive at all. Warning signs of this are slight, usually a constant grinding or squealing sound from the transmission. Clunking/ clicking when turning is usually an axle.
SJR Now Making Bumpers
Fairtax4me replied to Scott in Bellingham's topic in Products for your Subaru
Oh nooooh! Google doesn't like your site. Maybe a virus scan would catch something? (I don't know how that kind of thing works with websites) Anyway. Any plans for Gen 2 Legacy/Outback bumpers? -
Head Trauma, inc. Bumpers, Racks, Guards
Fairtax4me replied to [HTi]Johnson's topic in Products for your Subaru
Diggin that Gen2 Outback bumper! Any other pics of that? Does it have or can it be ordered with light mounts? Winch mount possible? How/where does it mount to the car? Are the tow hooks part of the bumper? Extra cost for those or included? -
What happened to Low budget? No offense, but boost is going the complete opposite direction. Forced induction needs a lot more to work than just a Turbo stuck on the engine. You need higher flow injectors, higher flow pump, intake parts, entirely new exhaust. Then you still need the right electronics to make it all work (ECU, sensors, etc), or some form of engine management. If you want to go that route that's fine, there are plenty of options, but I don't think an Ej22 crank in a 2.5 block is going to work. If you're really stuck on using the 2.5 block, just take it apart and rebuild it. A set of ACL Race Bearings is like $40-50, need a few O rings from the dealer for the case halves, new head gaskets (again). As for the 2.2. What does "in pieces" mean? Did you separate the block halves?
Rag joint on the EJ steering shaft? I've never seen one. All the ones I've dealt with are just a straight section of tube between two U joints. The 2" kit I put on my 96 had a lengthened steering shaft with it. Seems to me it was only about 1" longer than the stock one though. I think they just cut the stock one in the middle and slipped a larger I.D. tube over it. Dunno how they figured the length though.
ej swap, what do vacuum lines REALLY do 4 me?
Fairtax4me replied to tallwelder81's topic in Subaru Retrofitting
The early EJ's didn't have any of that "sore thumb" deal on the intake, just a straight tube from the filter box to the TB. But you do need to keep the Breather hoses that run from the valve covers to the intake tube. They don't have to hook into the same place, but without them you'll have all kinds of other fun problems to deal with, like oil seals blowing out, and sludge in the crankcase. Actually I don't suppose you HAVE to have them, you could put those little breather filter dealies that you get cheap on the rice rocket isle at Autozone on the valve covers, but they'll probably just leak oil all over the place. I'd rather have the hoses connected to the intake tube in some way. PCV stuff has to be there, but that isn't going to be in the way of anything. Certain vacuum lines you absolutely DO need. Others depend on what your ECU is looking for. Fuel pressure regulator has to have a vacuum line. No if's ands or buts. Although that's the only one that I can think of that's absolutely necessary for the engine to run. Are you going OBD1 or OBD2? -
Well, I wouldn't expect wheel bearing noise to carry all the way up the axle shaft and still be prominent in the transmission case, but I suppose it could. Transmissions are loud any way. It's possible the noise you heard in the trans was just normal gear noise. At any rate, input shaft noise will be more prominent closer to the back end of the transmission. The input shaft roller bearing (the one that commonly fails) is mounted at the end of the main case, not up front where the axles are. Noise can carry some, but when listening with a stethoscope noises are much louder when you're right next to the source. A bad input bearing will typically start out as a low clunk or knock sound that changes exactly with engine RPM, and will go away entirely when the clutch pedal is depressed. Follow the seam in the bottom of the transmission between the halves of the case. Where it ends, the MSB is directly above that point in the upper half of the transmission. Beyond that is the center differential and transfer gear housing.
You don't even need the axle pin tool. Just a few punches that you can buy cheap from the parts store. The special tool just makes it a bit easier for people who do these on a regular basis. If you're really dependent on a mechanic, Order an axle from MWE, and have the mechanic install it. Mail the original (core) back so it can live on in someone else's Soob rather than go to the crusher and be made into a Kia.
Snap-On? Matco? I have a set of Craftsman flare nut wrenches that are miles better than the cheapos I bought at Autozone years ago. Yet they're still no comparison to the Matco wrenches I bought last year when I needed good wrenches for brake lines. I have yet to round off a flare nut when using the Matco wrenches.
I've been driving with a split boot for about a month. It split at the narrow end though so there's less chance of stuff making it into the bearings in the cup. No gears in there just a few large bearings, and they're pretty tough. These are very easy to reboot though. Can be done in about an hour start to finish, you don't even need to completely remove the axle from the car to do the inner, but you might as well. If the outer boot looks like it has cracks between the ripples you might as well replace it too while it's off. Check Youtube for videos on how to replace CV boots. There are quite a few.
I would drill the hole behind (to the rear of the car) the bolt. I think there's less chance of there being stuff in the way. Drill directly behind the crossmember and your pilot should end up only about an inch from the bolt. But like I said, remove the ECU and whatever else may be in that area, and hang any wiring up off of the floor so it wont get knicked by the drill bit just in case. You may end up just drilling right through the floor pan there, but that will give you a reference for where to measure from so you can cut the bigger hole.
