135
Bosch plugs are great plugs, nothing wrong with them. But some people don't have the same experience with them that you may have. The reason everyone here recommends OE plugs (which are just NGK in a Subaru box) is that they have an almost 100% success rate for curing spark plug related misfires. It's not that there aren't other plugs out there that will work, it's that the OE plug is almost guaranteed to work without problems, whereas other brands of plugs can be hit or miss. There are so many factors that determine whether a certain plug works; air density, temperature, fuel quality, and combine those with any number of mechanical reasons such as cylinder wear, high / low compression, oil consumption, ignition system voltage, and most of all the type of ignition system. The wasted spark system on Subarus fires two plugs at the same time. But the polarity of the spark is reversed on one plug. Rather than jumping from the center pin to the ground electrode, the spark goes the other way, which will build excess heat on the ground electrode and wear it away instead of wearing the center pin. With this style ignition system one worn out spark plug and one brand new one connected to the same coil can make a big difference in the way the spark jumps the gap of the plugs. MAF or MAP, which could be something as simple as a vacuum leak, but it helps to know the CODE so we know what the ECU is looking for but isn't finding. P0420 could be related to the MAP/MAF code. Or could just need an antifouler on the rear sensor.
The crankshaft sprocket usually gets people with the triangle or dot mark on the face. You have to use the dash mark on the back of the sprocket on the reluctor tooth. The cam sprocket dashes can be hard to see but are on the forward face of the sprocket on the outer ring. All three marks should point straight up.
If you're talking about the "9510- 9709" numbers on the diagram, those are production dates. Year then month. 9510= 1995 October Rear mains didn't change shape any but they may have changed material or structure. OR they just felt like changing the part numbers. :-p If you look at the "alternate" part number under the one listed for the first year range, you'll see it matches the one for the next year range, and the next one has an alternate as well.
Bosch Platinums work great in some cars, and in some other cars they don't work at all. The fact that you have had them in your car for some amount of miles (you didn't say how old the plugs were), says that they must be at least OK, even if not ideal. I prefer to stick with what the manufacturer recommends, since they generally do alot of research to find the best spark plug for their application. But here the fact is, you only changed 3. That one old spark plug could be the one causing the trouble. You definitely want to get that one changed ASAP before chasing other issues. CEL codes may point to something. If you can post the exact codes, we might be able to narrow it down, or at least help you get rid of the codes.
I don't think you can get to the lever it with the trunk closed. But maybe you can I don't know. I'm not sure how you could kajiggle the latch to get it popped. I know there is a little square hole right in the center that I THINK you can jam a screwdriver into and twist and it will pop but I'm not sure. I can check in the morning. Your back seats don't fold down? Seems like it might be better/safer to just take the back seat out. It isn't that hard to remove the cushions. Two bolts for the bottom cushion and three for the back cushion.
Hi level inputs are bad for clean high power sound. Even with a mono amp and low-pass x-over, you really need that pre-amp RCA output for good sound from a sub. The higher the output voltage the better. Also helps to have a good quality head unit. A bottom end JVC or Dual is just going to sound like crap.
Haha! Nope. It was stored (capped) in the corner of the shop when it wasn't in use. Most of the time it was empty, and the only thing it ever really got used for was pumping out fuel tanks. Usually gas or gas and diesel mixed. And most of the time one of the techs would empty it the next day to use in a tractor or farm truck. That time they had to hunt down an empty plastic barrel to store it in while we waited for a special hazardous waste truck to come pump it out. Then they found a new oil barrel and tossed the messed up one. Doesnt chemistry kick butt!
I cant view the diagram right now (on the mobile) but what I remember from it I THINK The Dudes suggestion should work. You could run a jumper wire straight to ground from the pump (modulator unhooked) and turn the key on to see if the pump runs. There's still no guarantee that the new pump isn't just DOA.
Don't give advise like that. That's just like telling someone to fill the transmission with saw dust to cover up the bearing noise so they can sell it. That's just flat out malicious. The next car you buy might be some scumbags trade-in because they got the same kind of advise. Maybe he shouldn't have the car because he's gonna beat the hell out of it, but that's just like every other bandwagon WRX owner out there. Let him destroy it. Sounds like one of those people that won't learn a damn thing either way, except that when a car starts to go south he should just trade it in and make it someone else's problem. That's understandable, but ya gotta pay to play. Worst case, another WRX needs a new engine.
Ugh... As far as I can tell Autozone doesn't even carry the right one for your car without ordering a whole key cylinder, which is expensive and just not worth it. Go get that one from Advance. You need a 4 wire switch. You really should try to get the correct switch rather than cutting/ modifying trying to make the wrong one work. Sure it might be fine, but that's going down a road just asking for trouble. There are differences in the switches between certain models. I suspect (and I could be wrong) that the reason you can't get the correct one to pull up is you may be selecting the wrong car. You have to make SURE that you select IMPREZA OUTBACK when selecting your vehicle. LEGACY Outback is an entirely different car. That distinction between the two models has to be made. Lots of people unknowingly get the two confused, or don't pay attention, and while there are plenty of parts that can be interchanged between the two, they are two different cars. Transmission selection can make a difference as well, so make sure you select the correct transmission type if it is an option. Remote start. If it doesn't work. you want to get rid of it asap. Reason why, that may be the cause of the problem. Those aftermarket add on kits aren't exactly reliable. After market alarm systems quite often cause trouble in many cars. If it's dead, get it out of the car. Follow those wires from the ignition harness back to whatever made in china/tiawan/korea/insert-name-of-cheap-labor-industry-country-here module, find all the other wires spliced connected into the factory harness that go to it, relieve them of their duties, and get rid of it. If you need help, post some pictures of the wiring and where it goes and we can tell you if it's factory wiring or aftermarket stuff.
Not in my case. The ones that I've seen the whistle clearly comes from the muffler. EPA mandated new diesel emissions regulations in 2007 for all highway operated vehicles. The catalytic converter regulations do not apply to vehicles made before 2007, but any diesel highway use vehicle made for the US market for model year 2007 and later has to have catalytic converters. Because of that diesel fuel has new refinement requirements. The biggest change is the amount of sulfur allowed has been decreased from >500 ppb to >15 ppb. Makes a big difference in how much smoke comes out of the pipes.
Some type of chemical/solvent contamination of the fluid. I have seen this on other things with similar coatings, but never on a transmission pan. We used to use old 30 gallon oil drums at the dealership to store various fluids, usually gas pumped out to drop tanks for fuel pump replacement. We had a car come in not running and found the pump, filter, injectors, basically the entire fuel system corroded because of (what we later found out through fluid analysis) chlorine contamination. Bleach basically. Anyway, it Fd the entire fuel system in the car, and the gas we pumped out into the storage drum peeled the coating off of the inside in only about a day.
I ran a few wires through the unused port of the rubber/silicone plug for the fuel lines in the upper corner of the firewall behind the strut tower. Very tight to get to. I managed to fit an x-acto knife in there and cut an X through the open one, and then wiggled my 4awg wire through from the inside after spraying it all with silicone. Also have an 8awg wire running through the same hole right alongside the 4awg now. There are many hundreds of innuendos that could be used to describe trying to get that second wire through there. :-p
