136
11s, 12s, 13s, referring lbs of boost? You could be getting into an overboost condition, wastegate valve sticking, possibly a vacuum leak somewhere. Or the fuel pump isn't able to keep up anymore. When was the last time the fuel filter was changed?
What He said ^ Most of the ones I've seen have a label with the pinout. The larger of the two wires just goes to 12V. Some tap directly into the charge lead, later models it runs to the underhood fuse panel. Either way as long as it gets 12V while the key is ON. Can't help so much with the EA wiring. I thought there was a swap write-up about this in the Old gen forum?
What condition were the plugs in when you removed them? Dusty White? Dusty Black? Oily? Wet? 1+2 are on the same coil, so any ignition problem that effects both is likely the coil or igniter, and since you replaced the coil already... Bad fuel injectors possible, spark plug condition can indicate. Compression related issues, timing not likely, but valve lash could be too tight. Burned valves are common enough on that engine. Lash is easy to check with an angle feeler gauge.
Bad axles are typically aftermarket axles. OE Subaru axles don't have this problem unless they're completely worn out, which is hard to do, even with no grease in the cv joints. It's getting harder and harder to find OE subaru axles on these cars in junkyards, but I'd look there first for a few. Even if they have split boots, re-grease them and they're good to go. Or order some from MWE. http://www.ccrengines.com/mwe/ Marshall only rebuilds OE Subaru axles, and does a fantastic job. Pricey, but well worth it when you need the quality of OE without the price tag of new dealer parts.
Nothing to be worried about. Unless you purposefully try to set off the airbag, it's not going to pop. Unhook battery is always a good place to start. Be sure the steering wheel is centered before disconnecting power though. Look around on the back of the wheel there is a hole or two on either side at around 9 and 3 o'clock. Remove the screws you see in there, they are probably either Allen or Torx head. (don't recall exactly) Once those are out, pull the airbag module out from the wheel. The airbag harness connector probably has a lock tab that has to slide over before the release tab can be pressed. Unhook and set that off to the side. Then the large nut in the center of the wheel can be loosened. Some wheels will simply slip off, others you will need a puller, or some strength. If you decide to go the strength route, thread the nut back onto the steering shaft at least the width of the nut so when the wheel pops loose it doesn't frisbee or re-arrange your facial anatomy. Steering wheel pullers are cheap to rent though.
Speed sensor on the trans just drives the speedometer in the cluster. There's a converter in the cluster that cuts the signal in half and then sends it to the ECU. I would suspect that since you say the speedo needle never moves. Just out of curiosity though, did you turn the cruise off and see if the reading still changes the same way?
I can see it in the video. Looks like someone welded an aftermarket cat in and they cut/welded the bracket onto the side of the new cat. It's there, but it ain't pretty. The stuff after that is all cut/weld as well. The resonator looks like a cheap glasspack from the auto parts store down the street.
Head Bolts?
Fairtax4me replied to nwtech's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
No reason to replace unless they're damaged. Just clean the threads and dip them in clean engine oil before installing. -
Ej22, good. Put a set of valve cover gaskets on it. Make sure the rocker shaft bolts are tight. The ticking will go away after running for 20 - 30 minutes. Hopefully the smoking out the tailpipe will go away. If not it could need head gaskets. Not unheard of for an EJ22. But like Suzam said, smoking could be due to oil burning. Check the PCV valve. Oil level is correct?
Researching the brands you buy beforehand will often get you a better quality part. I just bought a set of Megan motor and transmission mounts because I read some reviews about them and they appear to be the same quality as Subaru OE parts, just under a different name. One review said they had a set installed by Cobb Tuning, and the installer noted that the Megan parts even had the same identification numbers stamped in them as Subaru OE parts.
The cheapest cheap part you will be replacing again in 6-8 months. If I want a part that will last until the rest of the car rusts away I buy Moog. Usually twice the cost of the less expensive parts but worth it when you don't have to replace them again in a year, and have to pay for another alignment. For Ball joints that's not necessary, but after replacing steering parts an alignment is just cheap insurance against worn out tires.
