135
I have a flaky lifter on my 96 that comes and goes. Generally shows up about 2500 miles on oil. Has taken over 100 miles to go away after a change before. Usually it's within a a day of driving after the change. What Lucas additive did you use? Oil stabilizer? Marvels Mystery Oil works better to clean up noisy lifters. Start poking around with a screwdriver or stethoscope and see if you can figure out which side the noise is coming from. Pull the valve cover off of that side, spin the engine so the rockers are unloaded. Line up the crankshaft at 90 degrees clockwise past TDC to unload one side, rotate another 360 degrees to unload the other side. "Unloaded" means the cam is not compressing any of the valve springs on that side. Check each for play. Press firmly on the ends of the rockers to check for squishy lifters. The lifters sit directly on the valve stems. You can use a prybar against the frame to help apply pressure on the lifters. If any compress before moving the valve, the lifter is either no good or is not getting proper oil pressure. The oil feed holes in the rocker assembly are tiny and easily clog. That's another possibility, and disassembling the rocker assembly and blowing out the feed holes with compressed air can clear the obstruction which will let proper oil pressure reach the lifters.
You need to order some Knock sensors from Bheinen74: http://ultimatesubaru.org/forum/showthread.php?t=128092&highlight=Knock+sensors Much cheaper alternative to the dealer part and will make you some labor $$ rather than possibly losing a customer due to a very common issue.
It just goes between the distributor /ignition module and coil so should work regardless. Make sure you set the box to run on 4 cyl mode if it isn't already that way. I had to drill out the rivets on mine and open the box to get to the mode selection wires so I could solder some of them back together. Wiring is pretty simple. The stock power and "ground" wires to the coil get run to the box instead through the small red and white wires. The black and orange go the the + and - on the coil. If your car has a tachometer hook up the wire to the "tach" plug on the MSD box. I have one on my 85 V6 Ranger with the stock electronic distributor and EEC-IV ignition/emission control system. 85 was the last year with a carbed v6, and the carb has a screwy feedback system for emissions. A carburetor with a throttle position sensor, and electronic idle speed solenoid, then there are two engine temp sensors, and an oxygen sensor, all that it uses only to adjust spark timing. Should have just made it fuel injected. Anyway... my original point, it made a HUGE difference in the way it idles and revs through the power band.
That makes it much easier then. Thanks for the info!
Is the XT6 flywheel any different than an EA? I can get an EA flywheel easy, but if it means I would have to use the smaller 7-7/8" disc I'll hold out for an XT6. Also, got a part number for that Sachs kit?
So you're using a re-drilled EA flywheel with an XT6 clutch? Does the XT6 clutch have the 8-7/8" disc with 24 spline?
EA dual range going into 99 Outback, a couple questions
Fairtax4me replied to daredevil1166's topic in Subaru Retrofitting
Hey Daredevil, What size clutch did you use? I see some listings for a 7-7/8" disc with 21 spline, and some for a 8-7/8" disc with 24 spline. Trying to figure out if there was any rhyme or reason to which clutch a car had. FWD vs 4WD? -
Duhhh.
If they don't fit on what? -
The old 3.3 has belt driven cams, the new ones are chain driven. Maybe 3.0 heads on a 3.6 block would produce some change in hp. Would be interesting to know combustion chamber sizes and "flow rates". Didn't know about any 2.7. Where was it used?
Rounded Axle nut removal
Fairtax4me replied to kabarakh's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Pound a smaller socket onto it. If the wheel was wobbling and the nut was tight, I think you probably need new bearings. -
A local auto upholstery shop can probably repair the damaged section. If not repairable they can replace the section for probably only $100-$150. Probably less if you can take the seat out of the car and take it to them. Friend of mine had a side bolster on an old BMW leather seat replaced for $100 by a shop here.
Yeah, I always jam something in the rotor. Screwdriver, small prybar, large punch, etc. While we're talking about these, what's the torque spec for Subaru axle nuts? I found 137 +/- 14 ft lbs in the MY 95 FSM.
