135
how do you flush out brake lines?
Fairtax4me replied to Stubies Subie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If you have compressed air, that combined with a can of AC system flush will get them squeaky clean. http://www.autozone.com/autozone/accessories/Quest-Clean-and-flush-aerosol/_/N-25p8?itemIdentifier=896840_0_0_ I have also seen people use transmission/oil cooler flush kits as well. OR you could just spray a bunch of brake cleaner in them and blow them out with air. I used the AC system stuff on my neighbors car because some jackass at a local tire n lube place had put OIL in the brake master cylinder. All the seals had swelled up like balloons. I had to replace the MC and all the rubber hoses, wheel cylinders, and rebuilt both front calipers. Problem was I still needed to get the old fluid out of the lines. The AC system flush dissolves oils, and it worked out pretty darn perfect. Blew it out with compressed air and put it all back together. 2 years later, brakes still work perfect. -
DUDE! You know you need some of these for it!
So wait... Whats next in the TW chapter? TW11? The board might seem a little... empty? without the TW10 thread being always at or near the top of the list!
P0130 O2 sensor Bank One Sensor One is the front O2 sensor. There are two sensors. Sensor One is on top of the front catalytic converter, if looking down from under the hood its under the passenger axle. Not much easier to see from below either. A 7/8" wrench should fit over the wire connector which is plugged into the main wire harness on top of the left side of the transmission bell housing. It's either a grey or white connector. Second sensor (#2) is further down the line close to the back of the transmission, on top of the second cat. P1101 Neutral switch circuit Off The neutral switch is on the passenger side of the transmission, check the wiring for it. You have a lot of wiring to check if there was a squirrel in the car. Hold off on tracking down the P0500 until you get the neutral switch issue fixed. You may be getting that code because the ECU thinks the car is not in gear when it's moving. P0500 Speed sensor A The one speed sensor is on the passenger side of the transmission. This feeds the speedometer in the dash, and from there is a wire that carries the signal to the ECU and TCU. There is an issue with some models where a few screws on the back of the speedometer work loose and apparently one of the screws makes the contact with the signal wire that goes to the ECU. Worth checking at least. Beyond that, it may be related to the neutral switch code. For wiring diagrams check out this website: http://www.main.experiencetherave.com/subaru_manual_scans/
I think they're somewhere in the neighborhood of 10.9 steel (metric equivalent of grade 8), so that they are the least likely to round off. Last time I cut a 10.9 bolt it was an 18mm thread and took about 10 minutes of constant cutting with a pneumatic die grinder. VERY hard steel. I can imagine trying to drill it would be nearly impossible without some serious bits and a drill press.
Much easier to just replace. Front diff requires disassembly of a large portion of the transmission in order to set the pinion depth correctly. The labor required for this makes it very impractical to replace just the differential. If the diff goes, the whole transmission goes with it. Rear diff is easy enough to swap. Unbolt old, bolt new (used) in.
It's probably that way to limit oil flow in the turbo, and keep pressure up in other parts of the engine. The turbo is fed by the same gallery that feeds the camshaft and rockers in the passenger side head. If too much oil is allowed to flow into the turbo, the camshaft may be starved and seize, which is a much more damaging condition than worn bearings in the turbo.
FSM says 10-12 psi at warm idle is normal. Hook up a gauge in place of the sender and get an actual pressure reading rather than relying on a light. I think it would be worth pulling the oil pump to have a look at the backing plate. In 30 minutes you will know if it's a mechanical failure of the pump or a condition internally that is causing the low pressure reading.
High pitch is likely to be a differential. The only thing you can do to buy some time is change the fluid. Pretty simple drain and refill. The condition of the fluid should tell you which diff (front or rear) is making the noise. As to your question does your car have a transfer case, yes and no. In the auto trans, there is a transfer unit in the transmission but it is electronically controlled by a solenoid that varies fluid pressure on a set of clutches. Manual trans has a set of gears and a fluid filled coupling combined into a center differential which balances power output between front and rear driveshafts. Both however, share the fluid of the transmissions they are built into.
