135
$750 is a pretty good deal on an 04. No, no RTV on that gasket. Just make sure the sealing surface on the block is 100% clean. Install the gasket dry. Unfortunately bent valves are almost guaranteed with the newer engines, but it's definitely worth the time to at least stick a belt on it and see if it runs. You don't have to put everything (AC PS ALT, belts) back on, really don't even need to put coolant in it. Hang the belt and put the crank pulley on then tighten the crank bolt with a few quick tugs on the breaker bar. If everything is timed right, you should be able to tell if it runs well with only a few seconds of running. Really you only need to get it re-timed so you can do a leak-down test. But if you have to start it, and it runs Ok for a few seconds, then it's probably OK and can be put the rest of the way back together. Other wise it will be shaky and rough, and you'll know you need to put some valves in it.
Does the latch mechanism not close? Or is it the lock mechanism? The latch itself has two operating levers that can stick and hold the stops open so the latch won't stay closed. If the locking mechanism gets jammed it can hold the stops open as well, at least it can on the older cars. It basically acts like the handle is still pulled up when you shut the door. Lithium grease on the outer part of the latch will help keep the latch mechanism free, all of the release levers and the lock mechanism have to be accessed from inside the door panel. The whole assembly is fairly easy to remove, there are the three screws in the door jamb and one nut towards the bottom of the door behind the panel. The rods that make it all work are kinda tricky just to figure out which end is best to unhook, but they are easy to pop loose. Then there is a wire at the bottom for the lock actuator that has to be unhooked then the whole thing can be fished out so you can grease all the pivots and levers.
It should be stiff. New bearings and new seals are tight and make the pulley feel like there is more resistance. The engine won't notice. If the old pump feels loose/spins very easily then it is worn out and probably about to fail. Are you replacing the idler pulleys as well? There should be similar feel to those. They should NOT spin freely. They should be smooth and quiet, but should not spin around and around and around when turned by hand. How many miles are on the car?
What B said. No brake cleaner. Spray it with lithium grease or som other rust inhibitive grease. Move the latch up 1/8" or so, turn the bump stops in about a half turn to take pressure off the latch. Also check the adjustment of the release cable. With the hood open, press the latch closed with a big screwdriver and see how much play there is in the release cable. It should have 1/8" to 1/4" of free play before it starts to pull the release. You should check this at the latch under the hood, not at the lever in the car.
I've found on that type of surface it's better just easing into the throttle and letting it slowly creep forward. Not spinning right off the line is the best, but sometimes it's unavoidable. Either way, put some weight in the trunk, it helps. Even when the rear wheels are spinning, if there's no weight on them you don't get traction.
81 posts and still no answer!? So we're still dealing with noise AND the smell? Ever think it could be a gremlin letting out little "toots" here and there while you're driving? Lets see, cheap axles + clunking noise + pulling to right + nasty smell = Cheap axle with a split boot flinging grease on exhaust system? I have a spot on one of the rear axles on my wagon that looks like a mouse chewed a piece of the boot off. Every now and then it flings out a little half pea sized drip of axle grease. Been like that since I got it (9 months?) and there's little more than a few dozen little splatters here and there inside the wheel well. Just a drop here and there, not like a typical ripped boot that flings out a half pound of grease all over everything all at once. Look a little closer at those axle boots. Sometimes splits in the end of the V sections can be harder to see.
MAF sensor code could be broken wires and would cause exactly the type of stalling problem you describe. At random the engine will stall, then restart and keep going like there is no problem. If the MAF sensor signal breaks the ECU kills the engine. A simple "test" is to unplug the MAF, start the engine, and drive around with it like that, but I wouldn't want to drive 50-60 miles that way. I had this same problem with a broken contact inside the MAF, it was difficult to track down, but wiggling the wire harness for the MAF in just the right way would cause it to stall every time. Replaced the MAF and it fixed it. This could just as easily been a broken wire inside the harness making poor contact.
The water pump is an absolute necessity on Subarus. It's driven by the timing belt, if the water pump fails and locks up, the timing belt breaks and valves get bent. Then you get to pull the heads off again and spend another $750- 1,000 in labor and parts to replace the valves. Subaru head bolts don't stretch so there is no need to replace them. Run a wire brush over them to clean the threads then stuff 'em right back in the engine. Three seals on the back of the engine. From left to right: Wrist pin access cover O ring, rear main seal, Oil separator plate. If the rear main isn't leaking don't mess with it, the other two should be replaced. Don't overlook that $1.50 cent O-ring that takes all of 30 seconds to replace. That thing will leak like a beach when it starts leaking. Remove Oil pump. Check the screws on the backing plate of the oil pump. They can loosen and back out then you lose oil pressure and get rod knock. Re-install pump with new O-ring and front crank seal. http://beergarage.com/SubyOPump.aspx And since you'll have access, new coolant crossover pipe O rings will prevent future coolant leaks. Coat them with Indian Head gasket shellac and they'll never leak.
You could just call a locksmith. It's probably $75 for a service call but you'll get a new key and they can more than likely fish the broken section out without trouble. I like the needle nose pliers option myself. A flat head screwdriver might also work. Removing the broken key can be as simple as grabbing it with some pliers and pulling it out. But if it twisted, the edges could be jammed into the sides of the lock and make it much more difficult.
In the FIRST 1000 miles I could understand a new engine burning a quart of oil or more. But I would call that much oil consumption excessive for 32,000 miles. Is this a recent problem or something that you have had to deal with since the car was brand new? Have you spoken with your dealer about this?
On the right track with the equal length header. Sometimes you can find them for sale in forum classified sections. Check some of the performance Subaru places like RS25 or NASIOC. Might have some luck at Subaruoutback.org as well. Another option is Ebay, http://www.ebay.com/itm/SUBARU-STI-WRX-LEGACY-02-06-Equal-Length-EL-JDM-Exhaust-Manifold-Header-03-04-05-/330667221413?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item4cfd4d61a5#ht_4247wt_836
