135
Don't waste your money on another intake just for some little metal hoses. Run rubber lines and be done with it. It's not THAT difficult. The only difference between the two intakes is the one that came from the car with the canister in the back does not have those two metal hoses sticking off the front. Run a rubber hose from the port under the 1+3 intake runners over to your canister. Then run a hose from the canister back to the evap purge control solenoid. This is exactly the way it's done on the other intake, except you'll be making hoses with rubber, rather than metal.
Does the after market unit have a wire for dimmer control? All of the dash lighting is powered AND grounded by the illumination control module. Hooking up to one side (power) may have damaged the module. I've also seen many Subarus with aftermarket stereos installed with no trouble. I'm guessing that somewhere along the line you accidentally pinched a wire or tapped off of the wrong one and caused a short. The test now will be to find the illumination module and unplug it, then see if the fuse still blows when the lights are turned on. Scroll back (from last page to the first) through this thread of "vacation pics" posts and you'll surely find some relevant info for your year, or at least close to it. http://legacygt.com/forums/showthread.php/wants-see-my-vacation-pixi-6216.html?p=2717922 The links at the beginning don't work anymore for the most part, but the ones in back are still fresh.
Some cars had the canister behind the right rear wheel under the bumper. Those will have a line that goes from directly below the fuel pressure and return lines, to right between the 1+3 runners under the intake. Just run a hose from there to your canister under the hood, then run another hose from the canister back to the purge solenoid.
Best bang for your buck is a set of reground cams from Delta Camshaft. Other than that, there really isn't much for the 2.2 other than intake stuff and headers for the dual port heads. Not sure about porting/valve work, not many around here mess with all that. Some of the more performance oriented subaru boards would have some tips/info about that though.
I've never heard of anyone replacing the bearings in the tail housing. I had one in my old transmission that was a little loose, but I decided it wasn't worth replacing. Plus a few of them are more difficult than it's worth because they're pressed on, and chances are they aren't bad anyway. When you get it apart, see if any feel like sand paper or have a lot of play, if not then I'd leave them alone.
Connector worked perfect Mike! I owe you one. All the lights on the dash are out, so it seems to be working. Now to figure out the oil leak, and the coolant leak. She didn't say anything about it leaking coolant but I could see the splatter of dried coolant all over the radiator and timing cover. Probably needs some Subaru Coolant Conditioner.
Ok so it has the 3 pin "Oval" plug. Found the ouput wire was loose, tightened it up to no avail. Still no charge. I mounted a second gen legacy alternator just fine, so I know that it fits physically. If I can get a connector for it, it will work. I can use the $65 Subaru reman and she'll be good to go for the rest of the life of the car practically. Would you happen to have a second gen Legacy parts car I could cut the alternator connector off of?
No, no. :-p The engine isn't running, and shouldn't be allowed to even start when checking compression. Warm up the engine to normal operating temp, driving or idling doesn't matter. Shut it off and remove ALL spark plugs. Unplug either the cam and crank sensors (both of them) or the fuel injectors and Ignitor module or coil pack to prevent spark and fuel when cranking. Attach compression gauge, then hold the throttle pedal on the floor while cranking the engine. Crank it until the needle on the gauge doesn't go any higher. Should only take 3 or 4 seconds.
Compression is checked warm, throttle wide open. Compression will vary depending on outside air temp and density, but 180-190 psi is about normal. IIRC all 4 cylinders should be within 10 - 15 psi. Cold numbers are only useful to see if you have compression at all. 156- 185, are those your compression readings? Squirt some oil in the one that's low and see if it comes up closer to the others.
98 (I think) Forester 2.5 automagic, belongs to a friend of mine's sister. She says bettery light came on, then car wouldn't start the next day. Dad put battery in, now car starts but battery and brake lights still on, after driving to work and back home car idles funny and then wont start again next morning. Told her she should have asked me first and I could have saved her $95 on a battery. :-p But I digress... To the point! How different is the Foz alternator than the 95-99 Legacy alternator that Subaru sells for $75 reman.? I'm thinking I can pick up the reman alt from the dealer and pop it on there, and have a better quality part than the "Worldwide" rebuilt turd from Advance auto for half the price. Any hangups with that idea? Different mounting bracket? Wire connector? Pulley?
