135
Timing belt, or some other internal issue, such as head gasket, this is the only option to choose. Broken TB on the 2.5 means bent valves. Way too much work on that engine with that many miles. If it isn't a simple fix, like a sensor or blown fuse or out of gas. Drop a 2.2 in it. As Fuz said, if the tires are good, flash them $500 and see if they'll take it.
P0446 Subaru Evaporative Emission System Vent Control Circuit Guess you know which one it is now. The evap system only collects fuel vapor from the gas tank and routes it into the engine to be burned off, rather than venting it to the atmosphere. The engine will run the same regardless, but your car might smell like you just went to the gas station all the time.
Did you do any work to the engine before installation? Timing belt, water pump, oil pump reseal? Did you put new oil in the engine? What kind? P0106 One of the hoses on the passenger side of the engine isn't in the right place. There are two and they need to be routed to the correct parts or you get that code. P0122 TPS might need adjustment. Make sure your throttle and cruise control cables are not too tight before adjusting the TPS.
I imagine eventually the filter might get plugged up with dirt. I haven't ever seen a thread about anybody needing one though. I'd just leave the metal line in place unless it's rusted out. That type of stuff is generally in place to minimize stress on certain components, or guide hoses/wiring around obstacles that might rub or cut.
After looking closer, there are 3 valves possibly back there. One that you probably can't see because it appears to be over top of the canister. Which also appears to be called a vent valve. possibly this is one of he changes on the later models. What year car is this again? http://www.subarupartsforyou.com/cp_partdetail.php?partid=12556 The vent valve that I think you're looking at has fairly large hoses, maybe 5/16" Id. One loops out of the leading (forward) port makes two quick 90° turns and ends. The other comes out of the top port and loops to a hard line which runs to another hose that goes to a filter above the canister. http://www.subarupartsforyou.com/cp_partdetail.php?partid=12552 The pressure control solenoid valve is the one located forward of the fuel tank next to where the rear brake lines come out of the floor pan.
You can yank the steering wheel of with brute strength, but it's a LOT easier to use a puller if you have one. If you go the brute force route, do what John suggested and loosen the nut 3 or 4 turns but leave it on the steering shaft while you pull on the wheel so it doesn't fly off and re-arrange your facial features. The airbags aren't anything to worry about really, but I wouldn't wear clothes that attract static electricity.
Oil's going somewhere. If it ain't leaking it's burning. A compression test will tell you if the rings are failing. A leakdown test will tell you how bad. Turbo's don't generally leak into the intake when they go bad. They puke oil straight into the exhaust system and will smoke like a steam train. Small puffs here and there when coming off throttle are your first signs.
I don't think from your description that it's a head gasket issue. That much oil disappearing... you would have snot in the radiator and mayo in the crankcase if it was going into the cooling system. If there wasn't oil all over the engine, clear evidence of a leak, then it almost certainly is burning it. Bad rings sounds likely to me. Do a leakdown test, since the engine is out of the car that will be easier.
The grid inside can break loose sometimes and rattle around. At worst the broken section can break apart into little bits and clog the exhaust system. If it is one of the front grid sections of the converter it can cause the converter to overheat and catch fire. If you don't have the funding to fix it right away, at least take it apart and gut the converter for safety's sake. Besides, it's fun!
The shafts will come loose from the axle stubs when you knock the roll pins out, then you can slide them off as you lower the trans out of the car. I thought harbor freight had the jack adapters but I don't see one on their website. Northern tool has one though. http://www.northerntool.com/shop/tools/product_200332755_200332755 Fits into your standard 1" jack plate hole. It makes the jack a bit "tall", but it helps a ton with lowering and raising the trans into position without dropping it. Throw the chain over the top of the trans and tighten it down. You want the car to be ~24" or better off the ground to use one of those. The shift cable just has some little clip deal that holds it to the lever on the trans, no work to be done inside.
Ramps should work fine. You want at least about 18" of clearance under the car to get the trans out. Removal is pretty straightforward. You'll have to remove the exhaust system, unhook the shift cable and electrical connections on the trans. Remove the driveshaft, unbolt the mount, unbolt the bell housing and torque converter then you can lower it out with a jack. Make a plate out of 2x4"s or a sheet of plywood cut to fit about the size of the trans pan, and place that between the pan and the head of the jack to avoid damaging the pan. A transmission jack adapter helps immensely.
Head gasket issues are generally identifiable on these by overheating, air pockets pushing coolant out of the reservoir, gooey black stuff in the radiator and reservoir. It can often be confirmed with a combustion gas test or block test. What was the condition of your park plugs? Did any look wet, covered in ash, black and oily? Did you look inside the plug holes at the crown of the piston? If so how did they look? Did you find that your oil loss was external? If it is internal it may be due to ring damage.
RIP Legacy
Fairtax4me replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I wouldn't put any trust in that engine. Frontal impacts can damage internal bearings. You may have a damaged thrust bearing, scored main bearings. The crank could be bent. It might run fine, but damaged crank bearings will eventually lead to low oil pressure, and more damage. -
If correcting the ire pressure relieves the problem temporarily the center differential may be damaged. 4 new tires rotated regularly and keeping the air pressure in check should allow it to work properly for an un-determinable amount of time. Replacing the center diff assembly is fairly easy. Shouldn't be too hard to find a good used one in a junkyard if you feel it necessary.
