135
If that engine was dropped or the car was wrecked there could be damage to the camshaft or bearing journals in the cylinder head. The cam rides directly in the head on these, no replaceable bearing, so any damage means replacing the entire head. There is also the possibility the crankshaft was struck in the same event that caused the other damage. Excessive force on the crankshaft can damage the thrust bearing, or score the main bearings which could result in catastrophic failure. I'd stay clear of the Phase 1 Ej25 anyway, moreso one that has accident damage.
Just lean the other way. Or drive from the middle like a thug. I guess I'll never know, but the combination of things just spells disaster IMO. Subaru AVLS is nothing remotely similar to Honda Vtec. AVLS advances camshaft timing, but does not change valve lift or open duration like Vtec does. The lift and duration change of Vtec is why you can hear the pitch of the engine change when Vtec "kicks in".
Yeah they make them for small trucks. Most of your 3/4 or Ton trucks will handle one of the hydraulic assemblies with ease. A 1/2 ton can still push a 6 or 7 foot blade, but the front suspension isn't designed for the weight of an ~8ft blade and the hydraulic control equipment that goes along with it. If it was a 1/2 ton truck, a front end collision could easily damage the frame which would send the repair bill through the roof.
But seriously. No, Vtec didn't do it. I did notice the wear pattern on the seat of the old valve seemed to have a curved profile. When I "ground" it, the small high spot on the seat flattened out. Wondering if the wear might be abnormal, and if so could it have been a contributor to this case? This engine did also have a faulty knock sensor...
I leave the joint on the arm and get it out of the knuckle first. They tend to seize in there and you can get better leverage with a big prybar between the knuckle and control arm. Once that's loose a pickle fork and 3lb mini sledge gets the stud out of the control arm with little trouble. Getting the bolt out of the knuckle is the only part I really worry about.
Certainly. A chain can be a blessing or a curse. I tend to think Subaru would take a page out of the H6 book and design the FB with a similar chain setup. But if they went to Jaguar for advice they may be breaking guides at 120k miles and leaving you with the irritable valve syndrome. Most modern chains do not need replacement until around 250k miles in my experience. There are the occasional bad apples, but for the most part you don't hear about broken chains like you do belts.
95 Ej22 at 178k. The grey stuff is valve grind compound. But you can see the important part. Now what I've read about burned valves, it would seem that cheap/bad gas would cause this. But the car was being driven up the long side of a steep mountain road, by a college student, when it "happened". Thoughts?
Not if the anti drain-back valve is functioning properly. But even if it did, any "crud" would just go back into the pump side, so it would get sucked right into the new filter when the engine is started. I like the timing chain most. No more broken timing belts to kill your engine. Probably a pita to reseal the timing covers if they start leaking though.
I can only imagine they should be of the same type on each side of the car. Meaning, a new vehicle would not have one type of axle on say the left side and a different type on the right or vise versa. Front vs Rear may have different joint types because the rear wheels do not turn. Obviously at that age there has been ample time for the boots on the original axles to split. People tend to replace the entire axle when that happens since it is easier. So it's no stretch of the imagination to think at least one if not more axles have been replaced by now.
Quite common on modern engines. BMW, Mercedes, Audi, Saab have all done this for years. They just use cartridge type filters instead of the canister type. It makes an oil and filter change very quick and simple, with no need to lift the car, and if done properly, there is no mess to clean up afterwards.
I've seen some aftermarket replacements, but they're always listed for the Impreza. 93 to 99 Impreza (all trims), 95 - 04 Legacy (all trims), and 98 - 01 Forester (all trims) use the same part. It's fairly simple but the bushing has to be pressed out of the control arm, and the new bushing pressed in. Subaru OE replacement PN: http://www.subarupartsforyou.com/cp_partdetail.php?partid=13224
