136
If it works, the it's fine. No wobbles means it's all in perfect balance and you can go on about your business. Change that timing belt ASAP though. You're riding on borrowed time, and when the clock comes to collect it ain't pretty. "TheImportExperts" on Ebay timing kits are the cheapest and best route so long as you get the complete kit. Belt, idlers, tensioner, water pump. The seals are cheap enough from a dealer, and the OE quality means there is much less chance of a leak.
Welcome to the USMB. It sounds like your local shop isn't a Subaru specific shop. Or they would have known that you just can't use an after market thermostat in a Subaru. It has to come from a dealer, any else is just not going to work properly. The engine doesn't have to be removed to change the valve cover gaskets, and all of the seals in the timing belt area are easily accessible with the engine still in the car. Thermostat and an improper bleeding of the cooling system will lead to overheating. Unfortunately, as was mentioned earlier, overheating is very bad for the 2.5 engine. It's like a snowball effect after that. You mildly overheat it once, that's fine. Twice is pushing it. The head gaskets will be compromised, which leads to more overheating, and eventually to rod bearing damage. There is no real way to tell if the head gaskets have been damaged until they start leaking. But if they are leaking, it will show up in a block test. Bearing damage can be determined by an Engine Oil Analysis Test. A sample of oil is captured during draining and is sent in to a lab where they can determine if there is excessive copper in the oil, which would indicate bearing wear. But, all of this is directly related to the work the first shop did. Had they known what they were doing this could have all been avoided. I'd be having a firm conversation with the manager and the owner of that shop ASAP, asking why the valve cover gaskets you just paid to have changed are still leaking. I'd also be pressing the issue of the potential damage done to the engine. Not for a new engine though. I'd be wanting back every penny of what was paid to them for the work. If they won't co-operate, I'm sure the Better Business Bureau would be happy to file a report about this. And a nice "thank you" letter from your lawyer might help get you some leverage. What they did to your power steering, I have no idea. I wouldn't have driven the car that way. And the fact that they even let you leave with the car in that condition doesn't sit well with me. I only wish you had found the site before all this. Plenty of honest and knowledgeable members on the board here along the west coast who could have done the work for much less $$ and you wouldn't have any problems afterwards.
It's there. It's always there. You just have to look harder. If it were not sending data it would show up as a communication error. The communication protocol doesn't allow the ECU to "not send" the outputs from one sensor or another. Outputs from every sensor are embedded in a hexadecimal code that is transfered from the ECU to the scanner, deciphered by the scanner and displayed accordingly. More than likely it's just a setting on the scanner that needs to be changed.
Missed that part before. You should remove all of the screws that hold the back plate on the pump. Apply thread lock and reinstall them. They tend to back out and the backing plate will come loose bleeding out all of your oil pressure back into the crankcase. Oil pump bolt torque from 2000 fsm. I think you call that "Snug".
Now that's a proper looking Subaru! Sharp indeed.
Taking it to Jiffy lube for an oil/trans fluid change. The front differential shares fluid with the transmission on the MT. So if the diff fluid was low, the trans fluid was really low and you have much more to worry about than the diff. Rear differential hardly sees any load, so if it was low just drain and refill it some some good synthetic gear oil. Worse comes to worse you have to replace it, which isn't that hard, and you can usually get one from a U-pull for under $100. Now for the all important question: What symptoms lead you to believe that either differential is damaged?
Don't need pistons, just get a really thick head gasket. There's more than one way to lose compression. You could play around with different lengths of rods, different crankshaft diameters. There are some nifty compression ratio calculators online. More than one was linked in the big Frankenmotor thread on NASIOC. Of course those guys were trying to get higher compression, so if you do the opposite of them you can probably get pretty darn low.
Really hard to see much there. I'd probably just replace the whole cross member to avoid alignment problems. Not sure how hard it will be to get it set properly. Might need some tweaking or cutting to get it where it needs to be. I'm really surprised the link didn't bend first. They're supposed to bend to prevent damage to the frame. You must have hit it just right to do that.
Normal side to side movement of the shifter when in gear should be less than an inch. The bushings on the linkage wear out and fall apart when they get old. So instead of the normal 1/2" to 1" of movement, you get up to about 3"- 4" of movement. (that's no exaggeration either, mine had a full 3" of side to side movement before I replaced the linkage bushings. I actually measured it for kicks. ) Makes it a real pita to find gears sometimes. Search for shifter linkage bushings, or something like that, and you should be able to dig up a few threads about it here. There were a couple with pics somewhere.
RTV works, but it can dry into little bits that break off later and get stuck in the oil passages. Anaerobic sealer does not dry like a typical sealer. Any that gets squeezed out from between the sealing surfaces will not dry like RTV will (actually it won't dry at all, ever), so there is no risk of it plugging up oil passages. You can get it at most any auto parts store. Permatex packages theirs in a blue squeeze tube.
No, there isn't any type of electrical diagnostic for the clutch. It's all mechanical and the ECU doesn't have any way to tell if it's borked. Not on a car that old anyway. A few sensors on the transmission might make it throw a code, but again I think your car is too old to have any of them. OBD1 cars are easy to get codes from. I know threre's a thread or ten around here about how to do it. Something about plugging together two black connectors under the dash IIRC. Turn the ignition to ON and count the flashes of the engine light.
This is Subaru's part number, so if you want to be picky you should match that up. Honestly though, I don't think it makes a difference. Match up what you have with the car you are getting the ECU from. Engine size, transmission type, and EGR or non-EGR. Those are about the only things that matter. And even at that, the transmission type is selected by a certain pin of the ECU being grounded or not, which is done in the wire harness in the car, so engine size and egr vs non-egr are basically it.
If the wheel got hit something is probably bent and has moved the rear wheels out of proper alignment. Alignment can cause all sorts of problems. The lateral links are designed to bend in a side collision (such as with a curb) in order to prevent damage to the frame. If there was major damage to the rear quarter panel the strut tower could have been shifted which would throw off the camber angle. The strut itself could be bent. I'd try to avoid driving it at all. Just because you don't "feel" something wrong on dry pavement doesn't mean the car is stable, and loss of control is imminent if you happen to hit a slick spot at higher speed.
