135
I just had the same idea and took a look at the 99 FSM (don't have 98). FB-4 Engine control module Fuel pump relay Ignition coil Transmission control module FB-17 Rear defogger timer FB-18 AT shift lock control module Back-up light switch (MT) Inhibitor switch (AT) FB-19 Hazard switch FB-20 A/C switch Combination meter Mode control panel Rear defogger timer TCS off switch FB-22 Blower motor relay Check connector Daytime running light control module Daytime running light relay FRESH/RECIRC actuator Hi-beam relay Keyless entry control module Power window and sunroof relay Seat belt timer Security control module Vehicle speed sensor (MT) Wiper deicer relay Wiper deicer timer FB-23 Airbag control module FB-24 Airbag control module FB-25 Lighting switch IG Headlight alarm relay All of these draw power from the ignition switch. So the question is... is the ignition switch out of adjustment or faulty and allowing a small amount of current through when it's in the off position? Or is power back-feeding from one of the sources listed? Lots of options there. Of course this is all for 99 so 98 may be a bit different. You can narrow it down by pulling fuses for these in the interior fuse panel under the dash. Depends on the type of circuit. Some makers switch the ground side of the light circuit. So any short to ground in the circuit between the lights and the switch would make the lights stay on.
Not hard at all really. Takes a few hours though, about a day the first time around. If you have some basic tools, access to either an engine lift or a large jack, and a friend who's wiling to help you can do it yourself. You can either lift the engine out, or drop the transmission to get access to the clutch. Either way is pretty straight-forward on these. Most people on the boards here, who do clutches regularly, pull the engine out, unless there is some other reason to remove the trans, such as to replace the input shaft seal.
Is this the original clutch? I've "smoked" the clutch in my 96 twice in the last year. (brand new in Jan.) I gambled on the cheapest clutch kit I could find and it hasn't turned out to be the best decision. Surprised? It is VERY easy to get it hot to the point that it smokes, it chatters on damp mornings, and chatters really bad when it's hot. I'm actually kinda hoping it will wear out fast so I'll have an excuse to replace it with a better quality kit. Anyway, a cheap clutch will do exactly what you describe, but so will a good one that is on it's way out.
Stock 09 Forester X tire size is 225/55/17. They'll fit but be mindful of the height difference. Loss in ground clearance is one thing, you're talking about a roughly 7.5% difference in circumference which will make the speedometer read slow by ~5mph at 60. This will also throw off the odometer by the same amount. Plus they're gonna look funny. 45 profile is reallllly short on a 225 width.
Wheres my news paper? Front to back makes the difference of your center transfer unit wearing out. Larger tires on one axle (front vs rear) will create a difference in driveshaft speeds, which causes the transfer unit clutches to slip constantly when the vehicle is in motion. Side to side will make a change in half axle speeds which will be balanced out by the front and rear differentials. This is still not good for the differentials, arguably it can be worse repair-wise, since a worn out spider gear shaft in the diff can lead to failure in the form of chunks (the big kind) dropping out from under the car. Then you get stranded. Either way, with an AWD vehicle of any kind (not just Subaru), you NEED 4 tires, one of the same size, type, and wear, on each corner of the car to avoid wear and/or damage to the drivetrain. edit: 1/4" difference in circumference on a tire with an overall diameter of 26.4" (size of a 205/70/15 Yokohama Avid Touring S, according to Tire Rack) would be about 2.8mm overall diameter, 1.4mm tread depth.
The cheap ones have always worked best for me. FSM lists these as OE plugs for 97: Be sure to check gap before installation. It makes a big difference. Power loss started after the seafoam treatment, chances are it fouled the plugs, but you also said you found a loose vacuum hose. Change the plugs and wires and take it for a drive before troubleshooting anything else.
Mine will click when I pull the release but the spring isn't strong enough to lift the hood anymore so it doesn't look like it's popped. Try to get some fingers under the edge to lift up on the hood after you pull the release. You could also try pushing down on the hood (put your weight on it) to make the latch move a bit and help free it up.
Looks nice! What's the little diaphragm thing attached to the number 1 intake runner? Oil pressure sensor?
