135
Search for "Frankenmotor". You'll find some good stuff about it. A lightweight flywheel is going to do more harm than good in an Outback. You lose energy potential in the crankshaft, which means you have less momentum, which you really kinda need to get the Outback moving. Lightweight flywheels also tend to be problematic with uneven wear, and usually have to be replaced at each clutch change because they're too thin and can't be machined to renew the friction surface.
Running rough at idle might be due to low idle speed. Every car I have ever owned (11 total) has done exactly what you describe. Of those I only had alternator trouble on 2 of them. My Corsica, and my Cadillac. (funny they were both GM, and both gave me the most trouble). All the rest have done the same thing, not one of them ever needed an alternator while I had it. My Lincoln (which I still own) has been doing that for 25k miles. I'd address the rough running issue before paying for a new alternator.
Not dead yet! Interesting stuff. It hadn't crossed my mind that the 2000 model does NOT have a MAF sensor. So it's possible for the ECUs air density calculation to be wrong if either the MAP or IAT sensor is out of whack. Or even if both are working properly a fault in the algorithm that determines the density might affect the changes the ECU makes to the fuel trim? I see questions concerning the role of the rear O2 sensor all the time and that is the exact answer.
big trouble
Fairtax4me replied to ellets's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Apparently... http://www.main.experiencetherave.com/subaru_manual_scans/1990-1994_Legacy_Parts_Catalog_-_Engine/ -
DUH!!! I had this link all along and never even though to look at the parts catalog pdfs. Found an old part number for this hose in there. 807507412 Apparently the new part (807607191, which supercedes 807607190, which supercedes 507412) is a semi-generic hose that's supposed to fit several different locations. Found that out through SOA parts interchange hotline today. But I'm not convinced it will fit and work properly where this hose needs to go. Guess I can try it on the car and see. Gonna call the dealer tomorrow and see if they can find me one of these in a warehouse somewhere. (not hoping for any miracles though)
big trouble
How far down is it? Are we talking engine out but still complete? Or is it heads off and crank/pistons removed? Maybe this link will help: This is the engine parts listing catalog for 90-94 legacy and includes turbo motors. I'm glad you brought this up. It reminded me of that page, and I was able to find an older part number for a coolant hose I'm looking for, that has been super-ceded. -
They're probably fine. The stud comes up to the last thread of the lug nuts. The main thing you would have to worry about there is stripping the thread when tightening. Some wheels do require "mag" (that's what I've always heard then called at least) type lug nuts rather than the standard conical seat kind. The mag type use a cylindrical shaft to center the lug stud and hold the wheel with a large flat washer. Seen here: I know Chrysler, Lincoln, and Jaguar use these, probably plenty of others as well.
Wheel time
Fairtax4me replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Flat black with clear = glossy black. Unless you get matte finish clear, which they do make, but I've never used or seen anything it was painted with so I can't say how well it works or looks. A flat finish will be harder to keep clean and will require a "delicate" touch to prevent scuffing and discoloring. And you can't wax it to protect the finish. Also tire dressing can "stain" certain types of matte or flat finishes. -
How many miles are on the one you have? Why do you think you need a new one? The only reason to replace is because of damage (cracked or the drive teeth are chewed up), or because it is too thin to resurface. Resurfacing is generally pretty cheap $30-50. There is a minimum thickness, which the machinist will check before resurfacing. If they say it's too thin to resurface, then you buy a new one.
Yeah I'd still like to kill the brainiac who came up with the idea to raise the speed limits so the state could spend hundreds of thousands of dollars on updating speed limit signs during a recession. But I digress... Oil on the clutch sounds possible. But there would be lots of evidence of a leak if it were coming from the rear main. You would smell it bad because it would drip directly on the Y pipe under the engine. When was the last time the gear oil in the transmission was changed?
There's a U joint coupler on the steering shaft where it attaches to the steering rack. The U joints get rusty and seize and cause this type of behavior. You can try soaking the U joint assembly down with PB Blaster or WD40 to see if that fixes/helps it. If it helps you'll need to replace the coupler, although you can probably get by for a while by just spraying it with grease or oil periodically. The other thing that causes this kind of problem is a problem called torque bind. This is when the front and rear axles need to turn different speeds in order for the car to make a tight turn, but they end up locked because the center transfer unit in the transmission is damaged. This one is much more expensive and difficult to fix. Try the first suggestion first, and if it doesn't help we can dig into the torque bind issue.
