135
The fpr does not block the flow of fuel. There should always be fuel flowing back to the tank. Normal pressure for an ej22 should be 25-30 at idle. Should jump up to 35-40ish under snap throttle or with the vacuum line removed 99 if it has the cone type idle valve, those are known to be problematic. Could try cleaning the IAC, but usually those just need to be replaced.
I think i gone an fudged up
Fairtax4me replied to Cedro289's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Is it an automatic trans? Auto trans you can usually pop the stub out with the axle. The proper sized punch makes all the difference on these. If you have part of the pin sticking out like in the picture above, use a grinder to cut the end off, you don't need to cut into the axle cup. Once that mangled end is cut down flush with the axle cup it will be much easier to knock the pin out. It also helps to put your punch in a socket and use a long socket extension so you have something to hold. -
Gas stations start with basically the same gas. Different additives are mixed in depending on that particular brands proprietal mix, and then transported to the store. P0420 has quite a few causes. Best place to start is with a tune-up. Spark plugs and wires, PCV valve, air and fuel filters. Make sure you have no vacuum leaks, and no exhaust leaks. An exhaust leak in-between the engine and cats will allow air into the exhaust stream and can throw off the o2 sensor readings. Old worn spark plugs may not be igniting the AF mixture properly, and will cause a higher oxygen and higher unburned fuel content in the exhaust which will alter the operation of the cats. Beyond that, O2 sensors. Using a scan tool to monitor voltage readings from the sensors will often reveal if one is reading incorrectly. If you don't have access to a scan tool, it's usually best to just replace both.
Use 5w-30 conventional oil. All you're really doing is breaking in the rings, so they need lots of oil. No special additives, just clean oil. Don't let it idle for long until you get it up to operating temp. Keep the RPMs between 1,500-2,500 to keep from fuel washing the cylinders. I usually change the oil after the first hour or so of running, then at 100 miles of normal driving. Then again somewhere between 500-1,000. You can change to synthetic after this if desired. No long steep hills or heavy acceleration, but don't drive like grandpa either. Keep the RPMs changing so the rings see different pressures while they're breaking in. Make sure the cooling system is full before the first start so you don't get an overheat condition waiting for the thermostat to open. Fill the block with coolant through the upper hose. If the tensioner is the one peice type I would replace it. Those don't take well to being re-compressed and re-used. Also on the first start, if you can, leave the plugs out and unplug the injectors. Crank the engine over with no load until the oil pressure light turns off. Pre-fill the oil filter so you don't have to wait for the pump to fill that before the engine gets oil.
Parts listings just don't have the F on the end. The main 10 digit number is the important part, at least in this case. There are sometimes internal differences in the part depending on when it was manufactured, and that can be denoted by a different letter on the end, but generally as long as the first 10 digit number is the same, the part is functionally the same.
97 outback
Fairtax4me replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Fusible link probably burned out. In the underhood fuse box, looks like a black wire. -
The evaporator core is freezing up and the thermo-sensor on the core is turning the compressor off. Then it takes those couple 30-45 seconds for the core to defrost. Once defrosted the compressor is allowed to turn back on and it starts the freeze cycle over again. Probably could use a small amount of refrigerant added to it. The newer systems only hold about 18oz, so its probably 3-4 oz low.
I would oil anything that's steel because it doesn't take any time for rust to form on bare steel. One night in a somewhat moist garage and you'll have surface rust. If the garage is temperature controlled, may not be an issue. I would try to get the garage as clean as you can beforehand. Sweep well and vacuum to remove dust. Wipe down the walls near your workbench with tack cloth. Doesn't have to be perfect, but the cleaner you can keep your build area, the better results you'll get, especially when installing new bearings and wen putting the pistons in. No point re-using the old piston rings. If the block is going to be tanked have the cylinders deglazed or get a stone hone and do them yourself. Pistons may be fine, but you may need to replace them if the anti-wear coatings on the skirts are worn off.
If it has crap tires put some good ones on it. Good tires are worth it even if they don't fix the noise. (Peace of mind) You could try rotating them and see if the noise follows to the front. Probably a wheel bearing. Looks like 07 uses a pressed in bearing. If you have access to a press the job isn't bad but you may be better off having a shop do it.
