135
Fixed that for you. You go more than about 5% larger in tire size you will notice it trying to stop. Smaller brakes will get hot much faster and will glaze over in no time. You'll be standing on the pedal with both feet just trying to keep it from running away down your driveway. Take it out on the road and overheat the brakes, you'll stop... when you run into something. Ask "oooo" for a picture of his OBS. That thing is huge!
You're drinking flavored water, that's what wrong! And X2 on Aspartame = If I eat/drink aspartame I get a headache so bad it makes me nauseous.
How do YOU change the front wheel bearing in your wheeler? :-)
Fairtax4me replied to obk25xt's topic in Off Road
Same kinda hillbilly okie that has a leather couch and AC on the porch! I would have at least found a big tree stump to roll under the car in case that jack slips out. Reminds me of this pic. At least you weren't welding on the gas tank though! :lol: -
EJ Off Road Bumpers anyone??? * * * Done Post 28 * * *
Fairtax4me replied to newsoobdude's topic in Off Road
Look at the second pic in post 37. It's mounted to the unibody at the stock location. Large square bar going straight back from the rear of the bumper. I think I would have made it so all the lights mount BEHIND the bumper rather than hanging out off the front. I can see those getting plucked off when you run into that tree. -
I've had that site bookmarked for years. I can and already do with my truck (riding on 31"s), but I drive the truck once a week. I drive the soob every day!
Aww man!!! That sucks! At least he has (had) insurance. Looks like it's come back together nicely though. Guessing you got a nice fat check out of it.
Well 3 of those are Fords, which are THE absolute worst for PS noise. If it doesn't go away after turning the wheel from lock to lock a few times you probably have a bearing on it's way out. Take the belt off and wiggle the pulley to see if the shaft has any play. How much deflection is there in the belt for the PS pump? A belt too tight will eat the bearings up pretty quick.
If you didn't find it yet, the usual cause of a "clunk" is a bad ball joint or tie rod end. But it could be a bad strut or some worn bushings of some kind. The rear bushings on the control arms are filled with grease, if the grease leaks out the back part of the arm flops around and can make a racket. Usually only during acceleration or breaking though. I loved the "Grandma" one myself.
With the trans in neutral it doesn't matter if the clutch is engaged or disengaged the car will still roll. I'm gonna guess your clutch disc exploded. The anti rattle springs on the hub can crack and fall out. Then they bounce around between the disc and the flywheel/pressure plate, depending on which way they fall. This causes mass havoc and the rest of the clutch disc explodes soon after. (like a second after) You can end up with this: http://www.drummerdonnie.com/BossHoss/Clutch-Soup-2.jpg Or this: http://partsforclunkers.net/Images/gary%20clutch.jpg The front diff won't be moving with the trans in neutral if the car is sitting still, so unless you blew up some gears inside the trans (which is entirely possible) I'm gonna say clutch.
One of those pesky water pump leaks probably. Mine did that a few times and has a very small leak somewhere around the thermostat housing. It will dump coolant all over the place when it's cold, but then the engine warms up and it stops. Then it might do it the next day or it might wait a month before doing it again.
I've been meaning to check it against a GPS anyway. It's accurate at 25. The radar boxes they put in random places around here always say 23, which I know is 25, they just want you to go that extra 2mph. It's how they get you. I'll do that first and see how it changes with the new tires. What's this black box thing though? After market?
She might have done that yesterday. FWD + lots of power is a LOT of fun until you get to the point where traction in everyday situations becomes a problem. But it all comes down to weight. Cadillac used to run the 300 hp Northstar FWD, and they had some torque steer but no real problems getting the power to the ground because there was a V8 sitting on top of the wheels. Meanwhile most Hondas have a hard time with much more than 150 hp. You might be able to run ~200 hp without much trouble in that car, but it's gonna be a trick to keep it in a straight line. Might invest in a limited slip diff to help keep the tires spinning the same speed. As for a better transmission setup. If you blow up the FWD trans, go find an AWD trans and weld the center diff and see how that works for you.
Got me some big ol' stock 97 outback size tires (205 70 15) to throw on the Legacy. Now since these are substantially larger than my 185 70 14s, it's gonna throw my speedo off by a couple few MPHs. (not that kinda speedo) Any easy way to correct that? Swap in an Outback speedo? Or would it have to be a gear swap? I tried searching but the answer eludes me... as usual.
My car did some screwy stuff when the positive post on the battery was about to break off. There was a thread about it, sometime last fall IIRC. It eventually did break, and any sudden use of electricity would kill the car. I limped it to the local advance auto. The trip was all downhill from the grocery store parking lot where I had to roll start the car. Car stalled when I hit the brakes to turn into the parts store lot. I parked and started taking the cables off the battery. The post came off with it.
I noticed that too. There was some site I found that might have that section, but it's in Russian. Kinda hard to read unless you have use a translator. (actually I think google did it pretty well) You could just use the 99 model FSM for reference. http://www.main.experiencetherave.com/subaru_manual_scans/ I got that page bookmarked. (it's in english)
You can download the FSM for 2000 from this link. http://www.main.experiencetherave.com/subaru_manual_scans/ I can't recall who hosts it, but thanks a million to whomever for doing so. Trans selector cable is on the side of the transmission, you won't see it from above, you have to crawl under to get access to it.
Might have something to do with the topic discussed in this thread: http://www.ultimatesubaru.org/forum/showthread.php?t=116101
That would probably be OK, but it's hard to say with wagons. With a sedan the rigid safety structure of the car is generally encompassed between the axles. That structure is generally dual purpose, serving both safety and performance/handling requirements of the design. Whether that aspect gets carried over to wagon designs is probably dependent on if the manufacturer intends to allow seating in the cargo area. Which would be a no in Subaru's case. My non-professional opinion... if that makes sense.
