Turbo Question
Fairtax4me replied to NV Zeno's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's a Subaru, it leaks oil. The stop leak stuff is usually just thick gooey oil... stuff. It helps increase surface tension which makes the oil less likely to work it's way through the small holes that are the source of leaks. I certainly wouldn't use it on a turbo engine for fear that it may impede oil flow to the turbo and cause damage to the bearings. (which would then mean she'd need a new turbo) I'm quite familiar with bad turbos working at a Saab dealership. We see one at least once a month. They usually blow a greyish blue smoke screen so thick you can't see the car for the smoke. And it hangs around for a LONG time too. It can start out small in some cases. You might only see some slight smoke when coming off the throttle or sitting at idle. But that only lasts a few days to maybe 2 weeks at most depending on how the car is driven.
2nd Gen Legacy Headlight/Turn Signal ?
Fairtax4me replied to zooandbio4me's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was 40 bucks short of buying a set of the two piece headlights and corner lights off of a 99 outback in the yard last time I went. I had the idea that the newer lights might fit my car, which has the one piece lights, with some slight modification, if any. Just didn't have the cash at the time. Not sure when I'll end up back down there and by then they might be gone. The bodywork around them is the same, the only tings I could see that might be different were the mounting points, and maybe part of the header panel. But the thin metal right around the back of the light housings can be trimmed/cut easily and will not harm anything structurally.
CV Joint Grease
Fairtax4me replied to uspowers's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAny type of Moly grease will work. Though parts stores usually stock pre measured packets of grease usually listed as CV Joint Grease. I've seen it on the shelf at Napa.
93 Impreza Climate Control Back-lights
Fairtax4me replied to Murthius's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSame as the early legacy stuff. Radio shack sells them cheap. #7219, 12V, 60ma, Micro Lamp. They come in packs of 2 for about $1.79 a pack.
P1041
Fairtax4me replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSometimes the ECU doesn't pick up on a bad o2 sensor right away. I the sensor is still responding in an expected manner the ECU will just adjust the fuel trim and go with it. The sensor output has to be out of spec or the frequency of change in the output has to be below a certain threshold before the ECU knows there is a problem. The heater circuit code may indicate there is a short or broken wire going to the rear O2 sensor, or that the heater itself has burned out. Either way it's not a huge deal. The sensor will still work normally once it reaches operating temperature. The heater is just there to hasten warming of the sensor so it produces a signal sooner.
how to apply clear coat?
The last time I wet sanded a large section on a car (had to sand and buff out a 2 foot long scratch on black paint) I draped a water hose over a large box and let it run constantly across the panel while I sanded. Turned out great, most "even" sanding I've ever done with 2000 grit, but I probably wasted 15 gallons of water, and my fingers were numb when I got done.
Pulled off the oil separator procedure!!
Fairtax4me replied to Legback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX$6-8 for a gallon of PP concentrate vs $5 for a 16oz spray can of Engine Brite.
That's the idea. It scuffs the surface to help the clear adhere better to the paint. The paint will be dull but the clear coat should fill in the sanding marks and come out nice and shiny. That's the idea, I've never done it that way, but I've only cleared 1 or 2 things I've ever painted. Usually I just prime, paint and be done with it.
EJ non-turbo burned exhaust valves - consensus?
Could a bad exhaust gasket on the head cause an air leak and possibly cause the valve to burn? I know these cars have issues with exhaust leaks, not sure how commonly that particular gasket goes bad though. I've heard of this before and am also interested to know exactly how it happens. My suspicion is varnish/buildup under the bucket.
IAC needs to be cleaned bad?
Fairtax4me replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat do the motor mounts have to do with it? Doesn't look like the engine is moving too much in the vid. Are they flat/crushed out? If you suspect a fuel injector is bleeding pressure down after shut off, get the engine warm, pull the spark plugs and turn the key ON. That will prime the system and any injector that is leaking will mist/vapor out of the cylinder.
P1041
Fairtax4me replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRear sensor... That shouldn't affect mileage at all. A failing front sensor may be to blame for the mileage drop. The rear sensor is just a monitor and doesn't have any dealing with fuel consumption.
Fairtax4me replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSeems to me that idle fuel pressure should be something like 32-35 psi. (might be wrong on that) So that might be a bit low, but I dunno if it's enough to worry about. Pretty sure I've seen you mention that you've replaced the filter. You could try a new FPR if you want, or grab 2 or 3 out of the junkyard and see if that changes it any. Idle did seem a little rough. You ever used seafoam?
Wawa noise gone
Fairtax4me replied to cobalt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDifferential noise could have been unrelated, but failure could have still been possible in a short time. I don't see why they would have suspected the differential for a constant noise though. Constant reverberating noise is almost always tires.
Fairtax4me replied to Legback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGo buy a gallon of purple power and spray down the whole bottom of the engine and car and transmission really well, let it soak in, spray it some more, spray it all off with a regular water hose (helps to have the front end up on jack stands or ramps, or on a lift if you have access). Spray it all down multiple times if you have to and get it as clean as you can. Let it dry, park the car on a level surface and just let it idle for a few minutes and watch for drips under the car. Try to track down where the oil trail(s) originate.
P1041
Fairtax4me replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI can't find a definition for P1041. P0141 (in case that was a typo) is the heater circuit for the O2 sensor which could affect mileage significantly if you only make short trips. There are some other things that can affect fuel mileage. A faulty coolant temp sensor for example, but people usually encounter driveability issues when those go bad. What year, engine, and mileage?
Fairtax4me replied to Legback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhich engine do you have? On the 2.2 there is a seal on the rear of the passenger side head that leaks like a sieve. But all the leaks on subaru's tend to end up dripping down to the jack plate. Can't rule out a bad oil pan seal, but those are sealed with Threebond RTV at the factory and are rarely the actual source of a leak. People see oil around the pan sealing surface and just assume it must be leaking. But it could be a front crankshaft seal, front cam seal, or oil pump seal.
Fairtax4me replied to Legback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAbout 18 - 20". You can put the front end on a set of ramps and it will clear.
Easy Transmission Front Seal Replacement
Fairtax4me replied to Gloyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI replaced the shift selector seal when I did mine. It's really easy if you have the tailshaft housing off of the trans already. Sand down the rust on the selector shaft before you slide it back into the new seal. I coated the shaft with anti corrosive grease to help prevent further corrosion. Petroleum jelly also works well for that and is easily available.
Wont go into 1st gear!!!! 91 legacy 4WD wagon, Stick shift.
Fairtax4me replied to code420247's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSeems to me the main shaft roller bearing going bad allows the main shaft to move fore/aft which will cause it to not engage certain gears correctly. This would also explain the heavy glitter in the oil. Rebuild or new transmission time! Make sure you get the right diff ratio.
Fairtax4me replied to Legback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGet 'em at the hardware store for like $2 for a pack of 10. I didn't think it was too hard to drop the trans. Took about 3 hours to get it out and I was in no hurry. But I did that because I needed to take the trans apart. Still haven't pulled an engine out of one of these but I figure it would take about as long first time.
differential issue??? what do I do please help.
Fairtax4me replied to KodiHamill's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEither auto or manual is just not worth ripping into the trans (auto is much more difficult) to replace diff parts. It starts as a bad bearing, but when it starts making noise it has progressed into drive surface wear on the ring and pinion gears which requires replacement of both parts as well as the bearings in order to correct. There are other parts in the trans that need to be replaced since they basically get destroyed during disassembly. If you tear it down that far, you better just rebuild it and at that point it's just not worth the cost. You're looking at probably $3000 between parts and labor JUST for the rebuild, plus extra for removal and installation, depending on where you take it. The better option is to replace it with a rebuilt unit, or just a used unit from a junkyard. Try what 91Loyale said first. Check fluid levels and try to isolate whether it is front or rear diff making the noise. The FWD (Front Wheel Drive) fuse is used to disable the AWD system on automatic transmission cars so that you can drive with the spare tire on the car and not cause damage to the center transfer unit. It is a fuse just like any other blade type. There is a small black holder on rear of the passenger strut tower under the hood that should say "FWD" on it. The fuse holder should be EMPTY. You put a fuse in (use one of the spares from the interior fuse panel) to make the transmission disable the transfer unit and work in only front wheel drive.
Oil Filter Question
Fairtax4me replied to 9098's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPLEASE do some research on Fram filters and stop using them. The actual size of the filter doesn't matter much for these engines. A larger filter can, in theory at least, last longer before clogging and causing a drop in oil pressure. Or it can take too long to reach its point of optimal filtering efficiency and cause more harm than good over the long run. As oil filters catch particulate the "holes" in the filter media fill in and filter out/catch smaller and smaller particulate. But during this time particles large enough to cause wear can still get through the filter and do their worst on your engines bearings and cylinder walls. When using a larger filter, it takes longer for these "large" particles to be filtered out. Of course "large" is a relative term since we're talking about scale of several microns here.
2000 Legacy stalls when clutch is depressed
Fairtax4me replied to 2000 Legacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWas that 68°F or C? Maybe consistent, but high by 3 V. O2 sensor output shouldn't be more than 1.0V during normal operation. Maybe OB has a good explanation for this? I work at a car dealership... I have to be honest at some point during the day!
2002 legacy need help
Fairtax4me replied to greenstang's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCrank angle sensors fail and the engine stalls and won't start at all. They are usually intermittent. The ignitor is a small black or grey box mounted to the bracket over the pitch mount (dogbone). It's only about 2" x2" and 1/4" tall.
