135
The "flappy thing" is the release lever for the clutch. Its fairly common for the release lever to crack at its pivot point inside the transmission bellhousing. It doesn't look like the release lever is situated properly in the pic, I would guess that it's broken inside. Unbolt and place the slave cylinder off to the side, Pull the rubber dust boot up and off of the lever, then bolt the slave cylinder back in place. Look inside the bellhousing with a light while someone pushes the clutch pedal and you may be able to see where the lever is cracked.
Alright then, disparity of the vehicle it cam from aside, if that harness plugged in correctly then You have to pull the timing belt off and swap the crankshaft timing sprocket and the left side (drivers) camshaft timing sprocket with the ones from your old engine. Around 00-01 they changed the number of teeth on the back edge of the sprockets that the crank and cam sensors read. Your ECU is getting confused by incorrect crank and cam signals, so you're not gonna get a spark. Swap those two sprockets and you should be good.
Don't clean inside the joint. Washing the grease out will cause the joint to fail. A split boot is only a temporary fix. Meant to last a couple weeks at best. Truthfully, I wouldn't even bother. If the joint 's already clicking, you need to replace the axle. If you need a couple weeks, just keep driving it until you can get a new axle. If the boot has been split so long that dirt and sand have got in the joint, packing new grease into the joint and sticking a split boot on it will only shove the dirt and crud further in and will cause even more wear.
Did the pulley seize or did the hub seize? If just the pulley seized then you can just pop a new compressor on and recharge it. If the compressor seized internally there's a good chance the rest of the system is full of metal, which means there's a good chance the new compressor will fail quickly if you don't flush out the lines and replace the condenser and filter/drier at the very least. Take the lines off the compressor and check for metal flakes in them. Any metal at all in the system will ruin a new compressor in short order.
Holder cable is too tight. Clutch cable should have about 1/4" of free play at the lever. Adjust that properly first, then pull the top of the lever forward (toward the engine) and adjust the holder cable until it just barely starts to pull the lever on the holder. Tighten the locknut and it should be good to go. If it doesn't hold enough, adjust it tighter a half turn at a time.
Its a 3 wire TPS right? Back-probe the center wire of the TPS connector with a paper clip, key On, adjust the TPS until you get between 0.50 - 0.55v at the center pin.
- 11 replies
- forester
- throttle position sensor
(and 1 more)
Tagged with:
Leakdown test will tell you if its a valve or piston. I would be tempted to just drop a lower mileage engine in it.
- 23 replies
- 1
- legacy
- hesitation
- (and 7 more)
Kinda sounds head gaskety. Block test don't work on these. Need a leak-down test to confirm a bad head gasket. Shouldn't have any real problem getting air out of that engine. Fill it, let it run until the cooling fans cycle on and back off and the thermostat opens, then turn it off and let it cool. Top off if necessary. Thermostat should be Subaru OE or an OE similar design. The cheapos can cause more problems.
That's kind of a balogna test. I can get just about any car moving from a stop in second gear. 5th gear doing about 55-60 mph put the gas pedal on the floor and see if the engine speed goes up while the vehicle speed does not. Release point is high because that's how hydraulic clutches work. Not sure on adjustment, but if its adjustable it will be on the pushrod from the pedal to the master cylinder.
