136
That one should be M14x1.5 or 1.75. Try finding another bolt and cut 2 notches in the threads on the end with a dremel. That may clean out the threads well enough to get the bolt through all the way. Put some blue locktite on it and tighten it to about 100 ft lbs. Torque spec on those is crazy high, like 180.
If it seems like you're getting power in all the right places then you need to check the grounds for the dash. I think there's a set bolted to the dash near the steering column. There are also grounds on each side of the center dash console at the base of the dash near the floor. Ground wires are brown, and hey do tend to ground several wires all in the same place so there should be 4-5 wires coming together at each ground point.
- 28 replies
- 1
- ignition
- electrical
(and 3 more)
Tagged with:
Not all locksmiths can, but it's getting more common for locksmiths to reprogram keys on vehicles that require dealer/manufacturer specific security clearance. Maybe not for a 2014, but for an 06 I would think you can find one that can. Usually worth at least browsing through the phone directory and making a few calls.
Daytime running lights use a filament in the headlamp bulb. Typically the high beam filament, but at a reduced voltage. Not sure of which filament your year subaru uses. Fuses. Have they all been checked? You can check relays all you want, but fuses are where the power comes from. Another somewhat common issue with those years is a bad headlamp dimmer switch on the steering column.
It's probably from the steering pump. Only way for oil to get in the plug wells on that engine is to run in from the top. No seals to go bad. The steering pumps leak slow from the reservoir o-ring and the fluid runs across the top of the block and right over to the #1 plug hole. Leaking oil pressure sender can do the same.
Then you need to find an intake manifold and wire harness from a 95-98 EJ22 with EGR.
- 3 replies
- EGR
- engine swap
(and 2 more)
Tagged with:
The whirring is the motor spinning. So electrically its working. Something in the regulator has bound and the motor has probably stripped the gear that drives the regulator. I've seen them bend in the center near the pivot point (if it has the scissor style regulator) and cause the window to jam in the tracks. A pry bar against the regulator may get it to move again. Do not pry against the edge of the glass or the glass may shatter. Worst case you'll need to unbolt or Unclip the glass from the regulator and lift the glass up, then you can wresttle the regulator around to get it to move upward into the raised position. Regulator replacement on these is a royal PITA. Be sure to read up on that service manual on the adjustments you need to make after installing the new regulator.
I put the shaft in a vice tight between a couple blocks of wood, joint end pointed down and into a trash can with an empty box or something to catch it. Then use another block of wood to pound the joint off the axle with a 3lb sledge. It takes a couple hard solid hits. A brass drift is best if you have one. I've had 2x4s split. Oak works pretty well too If you have an old piece of floorboard laying around.
Yeah I suppose it could be stuck in open loop if the second sensor just isn't getting hot enough to create a voltage signal. Pretty sure other people have not had any problems cutting out the second sensor. I would still try it without the first fuel filter. Those little lawnmower filters don't have high flow rates. Worth a shot and doesn't cost anything to find out.
Did you swap the engine or was it already that way? There's a work-around for the CEL but you need the intake manifold with the EGR valve.
- 3 replies
- EGR
- engine swap
(and 2 more)
Tagged with:
No compression on one cylinder would create a dead misfire and make it shake like crazy at idle and feel very underpowered when driving. You can unplug fuel injectors one at a time and see if the idle changes. Buy or rent a compression guage set and do a compression check yourself. Not uncommon for that engine to burn exhaust valves, but If nothing else I would take it to another shop and get a second opinion.
