136
Lots of things that could have happened. Previous owner could have installed the belt wrong and bent the valves. If it's been running rich for a long time it cluld have severaly worn piston rings. Either way, leakdown test will tell. If you want to confirm, pull the passenger side head and check the valves and cylinder walls.
If you have voltage on the ground side that means the ground has high resistance somewhere. Need to fix that because it can keep the signal voltage high. If that reading is testing at the ECU, you need to check the ECU grounds on the intake manifold. On the older engines the ECU ground is at the base of the rear of the number 4 intake runner.
806946030 Its a dealer only o-ring. Parts stores don't list it, don't carry it, can't match it.
It's under pressure so when the o-ring splits it will puke oil. (which is what happens after they get old and dry) Valve cover gaskets also leak at the lower corners. The oil tends to run towards the back of the engine. Rear mains don't leak on these unless someone has tried to replace it before. An oil leak from the center at the back is usually the separator plate or the access cover in the bellhousing. Pics and write-up here http://beergarage.com/Subaru.aspx
Does the knock go away once it's warmed up? Those blocks are known for being clunky due to piston slap. Generally quits after the engine gets warm. Doesn't hurt anything, just an annoyance. I wouldn't trust a 25D that had bad head gaskets. Rod bearings are small and they'll be eaten up if that engine overheated.
Depends on the flywheel. The original flywheel on my 96 had a step on it where the clutch disc made contact. Not much of a step, it was only about .005" higher, but it was enough to be noticable. After 165k miles the flywheel was worn down lower than the step height, so the flywheel needed to be resurfaced to restore proper clamp force for the new clutch. If you can feel that the flywheel is worn where the disc rides, have it resurfaced. If it isn't worn, scuff it up to remove any glazing and it should be fine.
If it's leaking that much... Walk. Gasoline doesn't play nice. Short term, you could probably run it with the return plugged. It'll run really rich though. Where the fuel hoses meet the intake manifold, top is supply (from the filter) bottom (smallest) is the evap, middle is the return. Pinch the hose with some vice grips. Use a small piece of cardboard to wrap around the hose to keep the vice grips from cutting the outer layer.
The monitors on 95 and 96 model year Subarus reset every time you turn the key Off. Therefore they are exempt from emissions monitor testing. There may be other types of testing (tail-pipe test) that may be required depending on your locality. Subarus generally pass those with ease. Print out that EPA exemption list and take it to the inspection station. Page 31 in this article: http://www3.epa.gov/obd/r01015.pdf Subaru TSB: http://graywarrant.us/manuals/Subbie/State%20IM%20Adv%20PRogram/On%20Board%20Diagnostic%20System%20Check%20During%20State%20Emission%20Test11-68-0233865.pdf Page 3, near the end of the 5th paragraph.
Just because GR-2s are the lowest on KYBs line-up doesn't mean they're bad parts. I've always been very satisfied with KYB Excel and GR2 struts and shocks. If you want stiffer springs, King makes heavy duty standard height and lift springs for the Baja and second gen Outback. You can get them through Primitive racing.
The lines going up through the floor under the seat to to the engine. Going back from there they go to the tank. Go in the trunk/cargo area and pull up the carpet and remove the access panels over top of the tank. Feed two sections of new 5/16 or 3/8" (whichever macthes what's there. Only do one at a time.) fuel injection hose through the passenger side access hole and across the top of the tank, fish it into the corner where the lines drop through the floor. Cut the hard lines off inside the cabin, flare the ends so you have a lip for the hose. Pop the new hose up through the floor and stick it on the line here, then cut to length and attach it to the corresponding line on the fuel pump cover. I think (don't recall exactly) the return line runs to the transfer tube on the drivers side first, then across to the passenger side. Napa has about the best injection hose you can get. Rated for 300 psi. The junk at autozone/advance is only like 50 psi.
