135
High HC and high CO says its either not getting enough air, or its giving too much fuel. Plugs and wires are new, but I would pull one or two of the plugs and see if they're covered carbon from excessive fuel. Temp sensor or MAF sensor will also affect fuel delivery. MAF can be skewed enough to greatly affect fuel mixture at lower rpm.
No need to wait. Put in on and tighten. On something like a valve cover gasket or oil pan gasket, they recommend waiting a short time for it to cure slightly before tightening because that will allow it to seal larger voids. On some oil pans this is necessary. On Subaru oil pans, it's not necessary.
Purge solenoid under the manifold. When this sticks open or the valve is dirty, it allows fuel vapor from the tank to be pushed into the intake manifold while re-fueling. This causes the air fuel mixture to be too rich for a few seconds when starting, basically causing a flood condition, and the engine may not start. After a few cranks the excess vapor is sucked out and the engine will start. Find the vacuum hose that runs from the solenoid to the throttle body, pull if off the throttle body and blow into it. If the valve is bad you'll be able to blow air through it. Usually its because or carbon stuck in the seat area of the valve, but sometimes the valve just goes bad and doesn't seal properly anymore. You can temporarily plug the vacuum hose to prevent starting issues. You'll likely still get a CEL until the solenoid is replaced.
98 forester
Fairtax4me replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Burned valve would cause a dead miss at idle. Most likely just has an intermittent/occasional misfire. Plug and wires. -
This is how ALL sun/moon roofs work. There is no way to get a perfect seal around the opening and still be able to open/close the glass at will. Water drips in around the edges into a tray that surrouds the opening. The water is then allowed to flow into drain tubes at each corner of the tray, where it then drains out underneath the car.
- 6 replies
- water leak
- moon roof
(and 1 more)
Tagged with:
Put it in test mode and make sure the fans work. If you have a scanner that reads OBD live data make sure the ECM temp sensor is reading properly. Temp guage on my 96 sits slightly lower than the one on my 95. But The 96 runs about 5-8° hotter than the 95. (according to the ECU temp reading on tmy scanner. 96 runs about 195, 95 runs about 189) Where the guage sits will depend on the condition of the wiring and can also vary based on the sensor. I wouldn't worry about that too much as long as it isn't creeping up higher.
If it has any burrs just file down the rough edge just enough to not interfere with new sprocket/pulley. The new key sits against the undamaged edge so the new pulley and sprocket will still line up properly.
- 8 replies
- 1
- crankshaft
- ej22
(and 2 more)
Tagged with:
Nope. The key is fairly soft steel. It won't hurt it anymore than what's already been done. Once the sprocket is removed youll be able to pop the key out. Take the undamaged section to Napa and buy a new peice of key stock that matches in size.
- 8 replies
- 1
- crankshaft
- ej22
(and 2 more)
Tagged with:
Tap threads into the holes in the sprocket and use a harmonic balancer/steering wheel puller to pull it off. When you install the new sprocket and crank pulley, torque the crank bolt to about 140 ftlbs.
- 8 replies
- 1
- crankshaft
- ej22
(and 2 more)
Tagged with:
Most spark plug thread chasers have a wide hex that won't fit down the plug hole on the 2.2. If it was spinning and he couldn't get the plug out, more than likely it pulled all the threads out of the head anyway. Threading in a new plug will probably only grab enough threads to have it blow out again after the engine gets warmed up.
