136
Clutch is one of those maintenance parts that I just plan on replacing when I buy a car. You don't know how the previous drove it, or how long ago it was last replaced. I'd go ahead and just pull the engine, new clutch, seals, timing belt if its old. Be sure to reseal/replace the separator plate and the access cover oring in the bellhousing.
Did you remove the snap ring from the inside of the knuckle? Snap ring has to come out, then the whole outer race is pressed out to the inside. There is a groove that the bearing rollers will jam in and make it difficult for the inner race to separate from the outer race. The two do not need to be separated to get the bearing out.
Those engines tend to lose coolant slowly, over a long period of time, due to minor seepage from the head gaskets. You'll probably never see a drip on the ground or anywhere under the hood because it evaporates away before it collects enough to drip. Subaru recommends the use of their Cooling System Conditioner in all of the 2.5 engines from 99-up. It's basically a stop leak product. You drain the cooling system, add in the conditioner, and refill with Subaru coolant. Run the engine to operating temp for about an hour so it fully dissolves and works it way through the whole system. Costs less than $5 at the dealer.
The cheaper ones are more prone to breaking. But I forgot, there is a way you can tell if the bolts are original (if they aren't too rusty) you should be able to see paint marks on the top of the bolt heads. Those are the inspection marks for the factory after they torque the bolts. If they were the original bolts and broke, I would definitely think someone has been in that engine before. The head bolts on these are pretty tight. A breaker bar is necessary to get them loose, but if they broke its because the threads seized the end of the bolt in the block. That could come from moisture getting in and causing it to rust. That's normally only a problem if the heads are very rusty though. If the bolt heads are clean I would think someone has had the head off before and galled the threads or overstretched the bolt.
tires
Fairtax4me replied to Chrisatjub's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Depending on the tire, 225s may run the rear strut body. 215/65/16 fit great, and don't rub. -
I have one. But I've only used it for front subaru wheel bearings so far. And yes, I also noted that their instructions don't cover rear wheel bearings. And even though they do have instructions for the front bearing, you pretty much have to ignore the tool numbers they list and pick out the ones that actually fit. Despite that, once you've used it a few times and know the correct sizes to actually use, its a pretty quick operation to change a bearing. If you have some that are badly stuck, I've found it helpful to pop the end of the forcing screw with a 3lb hammer after spinning it up tight. That may not be necessary if you have a stronger impact gun than I do. Heat can also be helpful. A torch on the knuckle for just long enough to get it warmed up usually helps break the rust loose. Just don't let it get too hot to the point of glowing. I'm sure with all the tools in the set there are the correct sized tools for the rear bearing.
Did you ask to talk to the store manager? Advance just went through a supply/rebrand/merger thing with Carquest, and most all of the parts they sell now are Carquest boxed and branded versions of the same parts they used to sell. Some parts brands may have changed, and some of their previous brands may have been replaced or dropped. The warranty should still be valid, you just need to push the issue with the right person.
AWD cars the bearing has to be pressed into the knuckle before the hub can be pressed into the bearing. It can't be pre-assembled, so you will never see them for sale that way. FWD the knuckle has a spindle that the HBA just slips onto. AWD no ABS is a generic hub they can be used on many different vehicles, so manufacturers can justify making them. AWD ABS hubs are specific to Subaru. They almost never need to be replaced, so most manufacturers don't produce them. Those non-ABS hub and bearings are usually sold as a kit, hub and bearing, but not assembled because they have to be pressed in separately.
How old are the spark plugs and wires and what brand are they?
- 10 replies
- 2000 subaru
- legacy
(and 5 more)
Tagged with:
I've used galvanized primer plenty of times on car parts, steel wheels, metal outdoor furniture, etc. Seems to work pretty well. It definitely lasts longer than paint alone. If you want paint to stick to metal, use an etching primer. Makes paint stick like stank on... well, you know... Etching primer tends to be pretty expensive though, and can really mess up some materials so you have to be careful where you use it.
