Location
Central
Vehicles
1979 Brat
Allouez's Achievements
Advanced Member (3/11)
10
i hear you have a 78 automatic front wheel drive. so do i. any troubles with the transmission on that one?
-sc
78 brat... still overheating. advice?
Allouez replied to ninefourteener's topic in Historic Subaru Forum: 50's thru 70's
Hope it's not a head-gasket ... That can make a car run hot. Happened to me some years ago. Does it run rough when you first start it? Also, if you can smell antifreeze and it blows a little white 'smoke' from the tailpipe, those are indications of a bad head-gasket. -
Very nice....
NOT mine, but thought you'd all like to see this, just in case you haven't already: http://subarujusty.proboards.com/index.cgi?board=memberjustys&action=display&thread=1276
Thanks! And likewise. Interior is fair... cracks in the dash and so-on. But it's remarkably clean otherwise. So glad I didn't sell this thing when finances were tight....
Just thought I'd share my Brat w/you all. Originally from Arkansas, but now in Wisconsin. It's been sitting for a couple of years and I'm now ready to goto work on it. Just got it going this weekend -- a LOT of electrical problems -- but a new fuel pump later and it's ready to go. At least until winter, when I plan to build and engine for it. I'll need plenty of help, so I'm glad for this forum!
84 4WD Wagon new daily driver with future EJ swap
Allouez replied to LeoneTurbo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Great-looking car. I love the color too, but it should be fun painting it. -
So I had to put my Brat into storage for 2 years and as of today am re-devoting my time and (few) funds to the cause. The fairly wimpy after-market Mitsubishi fuel pump that it came with can't seem to get the gas up from the tank and to the carb. Did OK before I parked it. It's got 1/8 tank, so that's not it. Any good recommendations for an electronic pump? Also, I'd like to start modifying this car during the winter. I'm generally aware of what others have done in this regard, but am wondering what my parameters are for an early Brat. Is a motor swap within reason/worth the effort, or should I put a carb on it and generally call it good? (I'm looking for more power) Is a 5spd. at all doable w/the 1.6? What ignition mods can be done? In the meantime, I'll keep reading this great forum. Thanks.
83 Wagon probs. Can anyone help??
Allouez replied to Allouez's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yeah, rebuilt carb, but don't know if they replaced the float needle/seat or not....I'll look into it. Thanks. -
Hi- I posted a while back, but no luck yet, so here's my situation: It's an 83 GL wagon. Initially, it would bog-down and hesitate once up to running temp. It ran rich and charcoaled the carb up. I removed the after-market gas-cap (vapor lock?), installed a new exhaust (was suggested that it may have been a cat. issue) and a rebuilt carb (from an 81 hatch. I've been told that this should work fine), and it now has new problems. It seems to be fine at idle, and then, as if someone threw a switch, it dies and won't stay running unless you stay on the gas. It's been at an import garage (they did the carb. work) for 2 1/2 months and they are completely out of ideas. I think it's a vacuum issue, but they've told me that they've checked for leaks and cannot find one. He did say that it runs better without much of anything hooked-up, but still not right. Of course, we've tried all the obvious stuff... Again, it's as though a valve closes or something, and it starves for gas. Ideas?? Thanks! Eric
Hi! A lot of great people on here, so I'm sure you'll like it. Good luck w/the Justy. I've always wanted to try one...had so many others. And yeah, there were some on E-bay for cheap and in good shape, but maybe not in your area. Let us know if you get one...they're an interesting car in a few ways. Especially the transmission choices. Personally, I've always wondered if they could be made to perform like a Mini....
Mine has come on lately as well, and means, I think...correct me if I'm wrong ladies and gents...Emission Control System. This light could mean any number of things, but it looks more and more as though my issue is a bad catylitic converter. I've heard however that it could be a PCV valve or Oxygen sensor. Sorry I can't be more help...Again, mine is running poorly, hesitates, no power and a big dead-spot at half-throttle. Don't know what your situation is... Can anyone help out?
Why more power at part throttle than floored?
Allouez replied to Mantonite's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The post about the "other" fuel filter (near the gas tank) is a good one. I'm having a very similar prob. w/my 83 wagon, and have replaced nearly everything that it might be and have yet to solve it, though the cat. is up for surgery this coming week. Mine acts as though the choke isn't opening properly, but it does. If I solve my prob., I'll be sure to post it. Definately check that other filter if yours has one. My father always said: "Check the cheep stuff first". Thanks all for the great posts. I'm learning a lot! -
Wow, that is a great-looking car! I hope you'll post some details about it. Nice work.
A Tale of Two Carburetors
Allouez replied to exister99's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well, not to take time from your probs., but mine is an 83 wagon gl. Got it from a junkyard and ran well for the first couple of months, and then began to lose power and eventually choke and hesitate off-the-line. In time, it began blackening the carb/air filter and eventually quit all together. I had replaced wires and plugs prior to the probs., and was told it was anything from a clogged cat. to after-market fuel cap vacuum-lock and eventually the carb. So I replaced the carb w/one from an 81 hatch that ran great and for a time my issues seemed resolved, but now the hesitating is back (as is the blackening). Note the carb is NOT identical to the 83's; there is one fewer vac. line on the 81...I was told that it shouldn't be an issue in this case however. I plan to open the cat. converter this week, but your theory on weak coils caught my attention. Mine is original, as is the cat. and most everything else on the car. I've had a LOT of these older Subarus and have never had one with these issues, so I'm at a loss. No computer (thank God), and very simple, but I've not been able to figure it out. I've had 3 mechanics look at it and nothings been solved... Anyway, if you have any thoughts, I'm all ears. And good luck to you too. P.S. I plan on replacing the coil regardless...do you have any recommendations along those lines? Factory, or a different coil? Thanks!
