WagonsOnly
Everything posted by WagonsOnly
Two red and two white 360s, 3 w/red interior, 1 w/brown A white 360 van, no interior '71 FF1, white, on the way, black interior '73 wagon, orange, black interior '75 coupe, red w/white vinyl top, on the way, black int. '75 wagon, yellow, black interior '81 convertible, silver/gray interior '82 wagon, silver/gray '82 GLF coupe, white/blue '83 GL coupe, white/blue '84 GL wagon, butter yellow/tan '84 GL wagon, maroon/tan '86 GL 3-door, navy blue/blue '86 XT-T, white/blue (checkerboard interior!) '87 GL-10 wagon, maroon/gray '87 GL-10 wagon, sandstone metallic/brown '87 DL wagon, red/gray '87 GL wagon, light blue/blue '87 1/2 XT Turbo, black/gray '88 GL-10/RX turbo wagon, black, gray, tan & white/gray & brown '88 XT GL, maroon/gray '88 GL wagon, maroon/gray '88 DL wagon, red/gray '88 RX 3-door, white/gray '88 XT6, gray/gray '89 XT6, maroon/black & gray '89 XT6, red/black & gray '89 GL 3-door, light blue/gray '89 GL Touring wagon, red/gray '89 GL-10 Turbo wagon, gray/gray '89 DL wagon, white/blue '90 Loyale wagon, silver/gray '90 Loyale wagon, metallic red & silver/gray '91 Loyale wagon, silver/gray '93 Legacy wagon, white/blue & tan '94 Justy, red/gray '99 Forester, red/tan I know I'm missing some but that's about the best I can do...
Oil leaks are common but relatively easy to fix. The electrical system is great. Check the brake lines, and jiggle the doors around and check the drain plugs--sometimes water can accumulate on the door bottoms. Other than that, rust is only sometimes an issue with the first-gen models in the normal places you'd look on a wagon; later models are very well-built. Also, the exhaust system is somewhat expensive and very problematic, and the heat shields may make a racket--check to make sure they're there as well. Tires cost me $115 for a set of 5 new ones last time I had them replaced. Regular maintenance is very cheap, anything out of the ordinary, not so. The local dealer isn't so great about getting Justy parts, either.
Yes, all those parts are hard to get. Wait 'til you find out you also have 3 different sized windshield wipers, too. I don't know of any dealers in my area that have Justy parts on hand--the nearest is about 30 miles away, and they've only got some limited old stock.
My Justy's going to Carlisle, but if we do it some other time (later than Carlisle) count me in. I'll also be in NH the first weekend in May, Concord area. Mary, I'm about 2 hours from you. I live about ten minutes south of Springfield, MA off I-91 (I'm in the Enfield CT area).
Gwinnett Subaru of Atlanta has them right in their parts dept showcase display. Subaru of Gwinnett 2920 Satellite Boulevard Duluth, Georgia 30096 (866) 467-8227 (800) 584-8749 (fax) Liz Wilkins Parts Manager (678) 584-7245 (direct) (678) 584-7246 (fax) Tell Liz (parts manager) that the guy with the '73 wagon, from Connecticut, sent you.
No major rust = worth $500 if you can title it and put her back on the road.
A fried seatbelt control module thingy, a broken track or a broken motor/cable will also turn on Mr. Seatbelt Guy.
How many have you meet and greeted.
WagonsOnly replied to ezapar's topic in Meet n' Greet. Your USMB Welcome Center
You just missed me, too. Next time -
You're basically stuck with some of the interior parts--the plastic wagon cargo surrounds out of the '87 will work with the Loyale but not the upper anchors because of the safety belts; the rear cargo lights are not compatible with each other ;-), intake, possibly tranny...but all the body panels and most of the interior will swap. The only real problem areas will be electrical stuff, where the Loyale has (or is missing) stuff your GL didn't have, like the electric seatbelt setup.
Yes on both counts--but we never got the turboed hatch in North America. Also, as you probably know, the sedans were available with an automatic only if you ordered the turbo, the 4WD, or both. Edit: I'm not sure about the EA81 sedan. The EA82 Turbo Traction sedan was offered in 1985 only, with the checkerboard interior; so was the RX.
Yes, they do have a disty. Love the color! I have gotten up to 41mpg highway with my '94 4-door 4WD Justy; I'd expect a 2 door 2wd to get a few more. Enjoy your beater!
Woohoo! I've been looking for a high-mileage (gas mileage) commuter car for my dad...if you pass it up, can you send me contact info? I'll share in my wealth of Sooby parts for a finders fee:)
Lets See Your Steering Wheel!!
WagonsOnly replied to NuclearBacon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If I was going to rally I'd go with an XT/XT6 wheel, just to be different. As it is I'm planning on a brown DL wheel (I like the slightly thinner rim) for my GL-10 wagon, once I'm done with the brown interior swap. (Almost there!) Edit: I also like the early '80s 4-button horn wheel, know what I mean? Also very different looking. -
Radio to fit in 1987 GL10?
WagonsOnly replied to civilpd's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm 3/4ths of the way done installing a radio out of an '02 WRX into my '88 GL-10. It involved some cutting behind the dash, a little bit of fab work and sanding on a faceplate adapted from a '90 Loyale head unit and a custom hanger, plus the reverse harness for the WRX head out of a '97 Outback Sport and the Metra forward harness for EA82s mentioned on Samo's page. So far it's wired in and working, and the faceplate is on, but there's still more drilling to be done, and the heater ductwork behind the dash is needing to be rerouted. -
The low-octane gas available in Wyoming, plus the fact that no one actually lives there to use an entire tankerful in less than a year, may have something to do with it (at least that's my theory). For reasons I cannot explain, this past summer my VW's gas mileage dropped from ~31mpg mixed to around 28 hwy during the week or so I was in WY. My guesses as to your mileage: -Winds -Bad gas -Altitude (most of WY on I-80 is over 5,000 feet above sea level--Cheyenne is flat, but higher than Denver) -Tire air pressure -Gas cap--lost, missing, or bad seal
How long have you owned your EA81 / EA82?
WagonsOnly replied to GLCraig's topic in Old Gen.: 80's GL/DL/XT/Loyales...
A year and a half for my XT Turbo, maybe 2 weeks??? for the turbo wagon. I have a high turnover rate... -
In these here parts, it's still possible to copy the VIN from the doorpost and have the dealer cut the key. Just have the dealer call the j/y to confirm that the car's on its way to the crusher and in no risk of being stolen. (The parts counter at my local dealer knows me by name, they never ask anyway.)
