backcountrycrui's Achievements
USMB is life! (4/11)
2
hey. hows it going, im kinda local... anyway i was wondering if you or any other forum members wana try meet up at effendal pass in tahuya o.r.v. over the weekend?
no bigs man, just checkin on an old friend. lemme know if you need any thing
Rob
I used the manual choke 32 36. It worked like a charm. It is a 86 gl wagon, 5spd dr. It went better than I thought it would. Alot of guys buy used or rebuilt carbs, and have problems fabbing up parts and pieces. With the kit all I had to do was add another gasket so I could use the plastic spacer from the old carb. The reason I used the spacer is because the bolts in the kit are a little too long. Other than that, at least on my car everything went well.
Good luck
Mike,
I see that you put a Weber on your car. What year is your subaru? Did you use a DGAV progressive? I am converting my SPFI engine to a Weber as its going into an 86 AWD. Thanks. TT
