18
Everything posted by 987687
My '92 Landcruiser: Safariwagon-II
987687 replied to TheLoyale's topic in Non Soob Cars and Bikes Discussion
I've heard about, and seen this problem. But I have 6k DDM HID kit in my JDM projectors and never have this... Actually though, I'm working on the wiring design so lights and that high power stuff won't turn on until the alternator is outputting. Not for saving my HIDs, but more so when it's -20deg in the winter my car actually starts when I forget to switch everything off. -
1994 Legacy GT - Repairs & Upgrades, A Build Thread
987687 replied to Red92's topic in Members Rides
Funny to see that pop up on here, both the first gen legacy's in that pic are friends of mine up here in Maine. The wagon that's half out of the picture is the fastest first gen legacy I've ever seen/ridden in/heard of. -
Sorry if I missed the ship on this going down, or being relocated. But the ea81 SPFI guide website is down, and has been for over a month. I've been trying to reference something from it. I had it downloaded to my old laptop too, and that died :/ Link to what I'm talking about ... http://home.comcast.net/~trilinear/EA81_SPFI.html And for some reason I can't drag it out of internet/google cache.
The forester XT has a 4.44 transmission, LSD rear end to boot! Although, with any amount of miles an LSD on a turbo car is likely to be totally shot...
Yes, there's a shudder in the projector at the focal point of the beam that moves up and down. When it's down it makes that nice sharp cut offline for the low beams. When you flick the high beams on it lifts the shudder allowing the light to spew all over the place and light the whole road. The ones that move in and out for H4 and similar bulbs are sort of a terrible hack, IMO. -
One other concern, do your low beam lamps turn off when you turn on the high beams? because that's going to ruin your low beam HIDs, you need to wire the low beams to always be on. Probably as easy as grounding the switched negative on the low beam. That way the low beam HIDs aren't always going on and off. The expensive cars you speak of use a bi-xenon projector. A projector that has a movable shudder on a solenoid that goes down when it's on low beams, and comes up to un-shudder the output for the high-beams. This way the lamp is always on. That is the CORRECT way to use HIDs... Or, some of them have a projector for the low beams, and just a regular reflector for the high beam with a halogen. The low beam is still always on though. This is how the JDM lights work in my legacy. -
It's looking good! But you can't use HIDs on the high beams when it's a two light system like that. Constantly flicking the HID bulbs on and off will kill them in very, very short order. -
Counting the turns isn't always a failsafe way of getting the alignment the same. I've seen quite a few inner and outer ends have different amounts of threads between manufactures. Just one thread difference is enough that it'll be out of whack. Best bet is to measure the length of the tierod, and make the new assy. the same length.
Wouldn't that overload the pinion bearing?
How much mine is spun? I dunno... Enough to clear for the right angle. It doesn't really matter how much you spin the strut top around. It's just a bearing.
Having the strut top spun like that makes it easier to bolt together. You can just reach an extension with a wobbly down to get at the strut top bolts. And probably mainly for clearance. When I made my 2" lift blocks with camber correction I had to turn the strut tops so a flat side was on the inside to clear the strut tower.
Not to start an argument here... But the 4eat is known to have less long term issues than the 5speeds... Well taken care of they last longer.
Not looking, no. A sedan pretty much just fell in my lap. But maybe someday... So far between two 2nd gen legacys in Maine I've had three broken front coil springs. Not really abuse related, just rust :/ -
I don't see any way the ignition lock could come out without removing the plastic. It's just a top and bottom piece, not really that hard. Then you have to get the head eye bolts out. I usually drill two holes in them and use a spanner bit. The rear hatch key probably only turns one way because the key or lock are worn. I've had door locks that only turn one way. A good tear down, cleaning up of the cylinder and wafers usually fixes that.
Rust. Rust, and more rust. That's a pretty common thing to break. I'm jealous, I want a first gen legacy wagon... -
Is this your way of saying your next project is going to be a Unimog?
A little strict isn't necessarily a bad thing. There's been some arseholery lately about people not liking each other's builds, etc. So some of that getting cracked down on wouldn't be a bad thing. I wish people could shut up if they don't like someone's build and let live, instead of
That doesn't make any sense... what are you talking about? I haven't seen any incriminating posts from you... You should keep an update of these somewhere else though. I enjoy your project threads.
Only issue I can see is that if you do this the exhaust can't move with the engine. The exhaust is hung from rubber hangers so it can move the same with the engine, if you weld it to something fixed it will crack as the engine moves and the lift blocks (hopefully...) don't. Guess you would put in a flexpipe... but those are expensive and prone to falling apart.
