18
Everything posted by 987687
Before I***knew better, I used bosch plugs. This was the result.... These were in for about two weeks, never ran right, and just got worse. The wires were crap from pep boys. I finally started pulling stuff when it didn't run when wet. Spark show under the hood.... Switched to good parts and it fine again. Here's the plug
Since it's been pouring so much oil, first thing you should do is clean up the whole engine really well. So there's no oil on it. Then you can find out where it's leaking from. Right now with oil everywhere it's impossible to know what's leaking. As for the oil pressure gauge. It's somewhat useless. They're extremely inaccurate. If it moves up and down with the RPMs, you're good... If you want real readings, get a real gauge.
For a reliable comfortable DD, take the legacy. As long as the auto doesn't have any problems now, and you take care of it. It will last a very, very long time. Much as I like my GL, my legacy beats it for DD/roadtrip status. Or, you could buy both. One for lifting, and one for DDing
Jump ahead to 2025. You gen one for $600 because it has 300k miles, the timing chain is loose and slapping around. And needs replaced. Also, one of the vtec actuators won't work right. Not only will this cost a fortune to replace, it requires a huge skillset. It's not like an ej22 where you just slap on a new timing belt and role for another 100k miles.
The EJ line has been around now for 21 years. It's about time they move on to the next engine, the EJ isn't going anywhere. And in a market where engines need to be more powerful, more efficient, longer lasting, etc. It's important they make something new and improved that can grow. I'm all for it. Hell, I'm glad car's don't still have an ea82....
I'd take it to an indy shop. Dealers don't have the time to deal with older cars (yes, 2003 is an older car to a dealer). They drive people out by giving them a ridiculous bill for stuff that may not even be necessary. They basically want to sell you a new car. That's what dealers do best. An independent shop, on the other hand, stays in business by doing good work for people and making happy customers.
Make sure it's going together nice and straight. You need to get the splines to line up. Put a breaker bar on the crank so you can turn the motor over as you slide it in. That way as you're pushing you'll get it lined up. Put it in gear so the transmission doesn't spin with the motor when it's partially engaged, not letting it go farther. They can be a pain sometimes.
Strange electrical symptoms. What could it be?
987687 replied to nickolai's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Test for ripple. Put your meter on AC and check the AC voltage in the system. Shouldn't be more than about 1v AC. If it is, you have bad diodes. That will cause all sort of problems in the electrical system. -
Since you say you're looking for alternatives... You could try to rescue it by welding sheet metal over it. You might get a few more years that way. But for the love of god, don't do it still attached to the gas tank Big fuel hose might work... Maybe you could fab a new one out of exhaust pipe. Unfortunately, that's the only year of that style filler. Unless you don't care about evap codes, then use a cheaper earlier one.
It's not that there's anything wrong with bolt on mods. Just that if you do it all yourself you get that good feeling of having created something awesome from scratch. And then when something breaks you're more in tune with your rig and can fix it on the fly.
If you have a brat or a wagon, jack, and one of those electric impact drivers. It would be a breeze to swap out when you hit the trails.
Not to pick an arguement... But now lets assume you're going downhill with one rear wheel off the ground. That's 1000lbs per tire, plus the fact that most of the weight is on the downhill front tires.
If you take the clamp off carefully you can re-use it. Otherwise wire it on, hose clamp. whatever.
Same goes for ATV tires as goes for the ATV wheels that have 4x140 bolt pattern. Don't run it on the road at speeds, and you'll be fine. Some of those ATV tires are 8 ply, that's gotta be enough to hold up a little old subaru.
