Everything posted by 987687
P0204 injector open circuit cyl 4 and timing belt ?
987687 replied to Grumble7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThrow it in the trash. Get a real one, or you'll be left stranded.
Monster wagon vr2 "Monster Sedan" build thread
Cool! Kind of like old subarus that had the brakes on the transmission side rather than in the hubs.
I've been DDing my legacy auto for a while now. It's a treat to cruise around in my GL. Missing the stick. The auto is nice though... I can eat breakfast, drink a cup of tea, and drive in traffic with my knees with ease
1-3-2-4's head gasket replacement
987687 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust get everything as lined up as you can. Sometimes it helps having a wrench on the crank so you can turn the engine a bit while trying to made it. Helps line the splines up. It can be a real pain on any car with a manual.
Hood mounted radiator?
Didn't someone do a top mounted radiator with an H6 swap?
This is my safety valve. . .
987687 replied to Gnuman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had two of those strip on me in one day. Doing an ej22 swap. The ej22 had it's strip. I said no problem. Went to take the one off the ej25 and the threads came out with the bolt. I bet if you look at the bolt you took out, the aluminum threads are still in it. I wasted some time trying to get a nut on the back side, but finally took it to a local machine shop and had it heli-coiled to 3/8". Worked great.
987687 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood job!
987687 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe bottom starter bolt is a stud into the transmission bell housing. Has nothing to do with bolting to the engine. The top starter bolt goes through engine and transmission, there's one on the other side. And the two bottom studs. Take off the pitch stopper, and that should be it. There are two steel pins that align the engine and transmission. And they get wicked stuck. Jam screwdrivers, prybars, etc, etc into the crack to get the engine loose. It can take some beating sometimes. Just work at it, it'll go eventually.
Phase1 heads on phase2 block.
There is so much mis-information, and conflicting info on this topic... I have no idea what to believe. Can you bolt, say, phase1 2.2 heads to a phase2 2.2 block? There's something about pistons clearing deck, compression ratio change... Can someone please clear this up for me? Thanks.
Axles, what's the diff?
987687 replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't want to come across rude, but instead of hijacking my thread. Start one for your specific problem. You'll get more response that way.
Flexplate replaced, now she's locked up! FIXED! Now no go...
987687 replied to SoobrDad02's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmm, well, being tight at all is bad. When the engine is bolted to the transmission. You should be able to reach through the starter hole and spin the TQ. It should spin perfectly freely with no resistance at all. And coast to a stop. Not just stick.
987687 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI see nowhere it states the year of that car, but it has a phase2 engine. Meaning it's 99+ In 99 they added extra trans/engine mounting bolts. IIRC yours is a 97, so it just has the two bottom studs and the two bolts at the top.
987687 replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, but in a junk yard they're hard to tell apart from aftermarket ones that are also black. If you just go for the green ones you're pretty safe.
987687 replied to SoobrDad02's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm curious as to how this happened in the first place... Did you bolt the engine and transmission together, then bolt the TQ to the flexplate? Because if you did that... It wasn't bound up. Which means it somehow bound after being all bolted together. Which is weird...
987687 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat appears to be the bottom driver's side nut. That one is a pain to access... I'm not completely sure what you're asking, maybe I'm reading wrong. But you're looking for a bolt head somewhere? The bottom two are studs that thread into the engine bell housing and go all the way through the transmission bell housing with a nut on the back side. There's no bolt so to speak because it just threads into the block. They're about 6" long studs. Sometimes the nut sticks and threads the stud out of the block. Don't worry if that happens. Pull the engine and deal with it when the engine is out of the way I just put a vicegrip on the middle of the stud and get the nut off. No big deal.
987687 replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUnless something rips the boot, or you swap things around, I doubt you ever will have to deal with rear axles. They almost never fail.
987687 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, you have to unbolt the header from the heads. No you don't have to drop the header completely. Just let it hang, it will be supported just fine with the mount that comes down from the transmission. If that mount is missing/broken off, use a cloths hanger or something to keep the exhaust system up. When pulling an engine, I've never done more than just unbolt it from the head.
987687 replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs long as it's not full of crap. It's probably fine. Now that this thread has been bumped.... Anyone have any answers to the original question?
987687 replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOEM axles have green cups on them. Thats the way I tell with used axles. Also a hint, if you get used axles from the junk yard it's almost always cheaper to dismantle them and put a pile of parts on the counter rather than the fully assembled axles... Last time I did that, I got them well under half the price of the whole assembled axles. That's true with a lot of junk yard stuff...
My '95 Legacy: Trashwagon10
If you do that, hook it up to a button for when people are tailgating you
clunky sway bar bushings..quick fix
987687 replied to Chip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBuy a bag of zip ties. You should have a bag of zip ties that lives in your trunk anyway.... Then you can make anything stay in place
96 legacy lift
On my GL I found that sliding the boots up the shaft closer to the joints helps immensely in their longevity.
987687 replied to Chip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood idea on the inner tube rubber. I use that red plumbers gasket stuff for fixing clunks in my suspension. Much cheaper than ripping everything apart and spending lots of money on bushings... Haters will hate, but this isn't a race car. It's fine for tooling around on the road.
987687 replied to Gnuman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI feel your pain... I got my car with a bad engine. Put in a motor I got REALLY cheap. And it had blown head gaskets.... Yay engine out again. Just remember that when it's done and on the road it will all be worth it.
swap question
987687 replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt would be much easier just to get a good 2.5 bottom end. It's kind of a pain to replace bearings in these motors.
