18
Everything posted by 987687
Burping is the term suby people use to refer to getting the air out of the system, using that in your search will probably yield the result you're looking for. But as stated, lift the front end Fill the engine through the top rad hose! Don't just fill the radiator, actually fill the engine through the top hose. start it up with heat on full, and the rad cap off. As soon as the thermostat opens you'll probably see the level drop quite a bit, add coolant and cap it. Sometimes squeezing the top rad hose will "pump" the air out a bit, do it with the cap off. You'll get a big bubble and coolant level drop. Using this method I've never had an issue with overheating. But like I said, search using burping the system and you should find more threads on it.
You mean you're just going to bolt it back on without putting new gaskets in? It will definitely leak in that case. Even with the EGR tube on, I bet there's enough wiggle room you could slide new gaskets in. Although, no way really to clean the mating surfaces. And it will probably leak... At this point you really have to replace the gaskets. If you don't care about the egr, the other option is to cut the pipe and just crime the ends off.
Last one I dealt with did the same thing that happened to you. rounded the nut. And I ended up squeezing it so hard with vicegrips I squashed what was left and broke it so there wasn't anything to grab onto anymore... So I cut the pipe in half. Then I slid a big nut over the pipe and welded it to the part that was stuck in the intake. Then I could also use a box end wrench on it, finally that got it loose. Same deal for the head end. Fortunately I had a spare EGR tube laying around that I actually managed in getting off without destroying, but otherwise I'd just have welded the tube back together and called it good.
11 codes?!?
987687 replied to 97ej22's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I did an engine swap and forgot one of the engine connectors once... It ran, amazingly. But terribly and threw about 11 codes. That's why I said clear codes, and see what comes back. If it's a wiring problem where the computer just doesn't see the sensors, the codes will come right back. Not having the MAF plugged in won't throw 11 codes all at once, it'll take some driving to upset the computer into throwing codes for everything. -
11 codes?!?
Clear the codes, and see what comes back immediately. With that many, some will probably immediately come back. But I'd start checking connectors... 11 censors didn't all die at the same time, you have a wiring problem. Pull the engine harness connectors, check to see if they're corroded, have crap in them, etc. Clean them up. Check the computer connector. I've had a problem that I tracked down finally to a loose computer connector. And just check all the engine wiring, something has come loose that's causing massive mayhem. -
Steering wheel sticking every half rotation
987687 replied to 987687's topic in Old Gen.: 80's GL/DL/XT/Loyales...
So I answered my own question. Got the sucker out. Amazingly, not rusted in there at all! I let it soak a few hours. Then the bolts came out, no battle. I used a chizel to span the collars, then just hammered it right off. I was amazed at how easy it was... Anyway, the joint is very bad, one is really sticky, the other is completely loose. You have a PM incoming, thank you! Sorry if the message sent twice, I'm having weird issues with the forum... -
Do I have to drop the crossmember any to get it out? Or can I slide the joint up on one end, then slide it off? -
Is it swappable with any EJ subarus? EA stuff here is pretty hard to find, and usually all rusted out when I do find it. -
Anybody? Please? Rally drive type stuff is coming up and I need my car working! -
You can run the car till it's way below resting on the peg... then you can sputter along for another 5 miles to the gas station. I think dealers and shops that know subarus tell you to take it in under 1/4 tank. I did mine at just below 1/4 tank and was fine, I definitely would NOT remove the filler with a full tank.
Sorry if this has been covered before, I couldn't really find exactly what I was looking for. I don't drive my 89 GL very often, maybe once every week or two. Yesterday I took it out for a drive for the first time in over a week and a half. Nothing was wrong with it then. But now, the steering wheel sticks every half turn, pretty bad. It won't turn back by itself after going around a corner, I almost have to force it around. It got better with some driving, but it's still there. Power steering fluid is a fine level/colour, the pump turns freely, no bearing noise, no play in the pully, no leaking, etc. The steering rack boots aren't torn and the tie rod ends are nice and tight. All I can think is it has something to do with the linkage/u-joint. Or maybe the struts binding when turning?? It does it when not moving too, so I don't think it could be an axle.... But I'd like some input before I go throwing parts at it. Thanks much.
Are you pushing for the XT because you'd rather have that in 5 years when she's done with it than the tribeca? Unless you're looking to replace a lot of stuff, buying any turbo car with over 90k you're looking at replacing stuff. Turbo is staring to get old, etc, etc. NA stuff does a lot better with higher mileage. But the tribeca is ugly as hell...
I don't usually call bull************. But, putting on the filter too tight will not cause high oil pressure. As zacyork said it just makes it a pain to get off.. Putting it on too loose will cause it to fall off. And that causes low oil pressure...
You can't judge high or low oil pressure from the stock gauge. If that's what you get your readings from, you have no grounds to state you have an oil pressure problem. My oil pressure gauge always reads something, and moves when I rev the enigne. That's about all I use it for. If it drops to zero I'll be worried, but otherwise they're useless for any accurate readings. It's really doubtful you have high oil pressure anyway, if the engine runs well and doesn't make any bad noises it's probably fine..
What exactly are you saying? Are you really saying you should leave the oil filter loose so it leaks
