18
Everything posted by 987687
I got an ej22 with blown head gaskets for $100. New gaskets and it's running, I'd pass on that.
WOW! The subframe on my 89 rusted out... but that's an 89!!! To be expected. The problem is, people who can afford the extra cost wouldn't care because they buy a new car every two years anyway. People who want a cheap car that will last a long time can't buy that new car with nice hardware... But since the rich people never buy them, there wouldn't ever be used ones on the market.
If it's not too bad it won't be blowing much exhaust into the coolant, and will cool off at lower loads. When the HGs went in my family's 99obw I was driving. I was going up a hill and it started blowing cold air. Went to turn up the temp, and then noticed the temp gauge near hot. Pulled over and let it cool for a bit, but I knew I was only a few miles from a mechanic, mostly flat ground there too. Started it back up and just drove 15mph on the shoulder, temp stayed just above the middle. So it wasn't so bad yet that it couldn't keep the temp down, but it gets worse.
If you aren't getting any fluid dripping through the hose even, something is wrong... Make sure there's some freeplay in the pedal. If the rod is pushing the piston in the cylinder when the pedal is up, it will close the ports and no fluid will get through. I had this happen to me bleeding a new master cylinder on a VW beetle a few weeks ago...
Flywheel
987687 replied to Arty's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The 22 and 25 FW have to use their respective pressure plate and disc though, don't they? -
Expanding on what John said... What's the code, P0500? Does the speedo still work right? I wrote a guide on why that happens, and how to fix it. http://www.ultimatesubaru.org/forum/showthread.php?t=119744 On the MT there's only one speed censor, they rarely fail. And if it does, good luck getting the bugger out of there.
I know someone who's been running an ej25d with bubbles in the tank for well over a year now. It hasn't overheated or gotten worse... With leaky head gaskets it's sort of hit or miss how long it'll last. I don't like playing that game, so I just replace them. With my luck I'd be in northern Saskatchewan when it blew.
misfire...
987687 replied to crcorc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
If you think the DOHC is a tight fit, try changing plugs in a newer ford V8. The computer at work gave 5.5 hours for the job. And oh boy did it take that! -
misfire...
Here's my experience with bosch plat plus... This is less than 2k miles, all 4 looked like this. Ran like garbage!! -
Flywheel
I always go out of my way to find local shops, old timers, etc. There's a guy who rebuilds starters and alternators near me. He does great work. Completely overhauled my legacy's alt for $40. New bearings, brushes, etc. And the thing works like new. Best part about guys like that is talking to them, hearing all the stories. If you're not careful you can spend hours in such a shop just looking around and talking. -
Flywheel
Any reputable machine shop should balance the flywheel after surfacing it. If they'd done that, you'd have been fine. -
Flywheel
Why? I've never had any problem with it. -
The change to rear discs was amazing for me!! But .... My rear drums were rusted to hell, cylinders leaking, shoes were gone, adjustment was crazy... I'm sure in working condition they do pretty well. The rear discs are still nice
