18
Everything posted by 987687
Bleeding the master cylinder is what you don't want to do. DO NOT let the reservoir run out.
You do know you can't just compress the piston, right? you have to screw it in. Another thing that'll cause brakes to stick is if the slides are frozen. Disc brake pads always touch the rotor very slightly on a properly working setup. Same with drum brakes, if you have the adjusted correctly. Sounds like yours may need adjusting. I know the feeling of the car sitting... My GL has been sitting for about three weeks now with a broken subframe.
Give it the Chinese water torture... Take a spray bottle with water and spray it over the wires and see if you can get leaky spark and make it miss. Non-oem wires and plugs cause issues like this though. That will tell you if it's damp related. If it's not, it could be a failing coil, ignitor, low compression on those cylinders, sticking valve.... there's a lot that will cause a misfire.
I would have gone... But I live thousands of miles away and my rear subframe is broken.
ile?
My legacy is almost to 232k, ej22 swap. But original auto tranny is still doing pretty well!
Have them check the balance before pulling the wheel weights off. That way you can see how off it was, or even if that's the issue. Whenever someone comes in with a front end vibration or whatever I'll check the balance of the wheels. More often than not that's the issue. But if I just pulled the weights off first I'd destroy some good evidence.
I didn't have one problem with mine for a whole year. Until two weekends ago I broke the rear subframe...
