18
Everything posted by 987687
A couple things I wish from the auto... I wish the TQ would lock in 3rd, and I wish I could make it hold in 4th. Sometimes going up long hills (I live in a very hilly area), it'll downshift to 3rd. Accelerate too much, so I lift off, then it'll shift into 4nd, but a tiny more gas to maintain speed it goes to 3rd again. Also, when I slam the gas to the floor, if I'm going over 40 it won't downshift to 2nd unless I put the shift selector into 2nd. But what's happening with yours is normal..... Swapping mine to a manual to fix all these issues.
Towing
987687 replied to subsince77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I've had my car towed with a dolly before -
Towing
When there isn't any pressure in the transmission (engine off) the rear section isn't connected to the rest of the transmission anyway. So FWD fuse or not doesn't make any difference. The reason you can't tow it with the back wheels on the ground is lubrication. The bearings in the transmission only get lubricated when the engine is running turning the tranny pump. If you tow it with the engine off you'd destroy the bearings. Now, in theory if you had the FWD fuse in, tranny in neutral, and the engine running........ Still a dumb idea. -
I dunno either, but I put them back on the same way. I didn't replace the hoses, but everything is sealing nice and tight. I didn't think this was the gas cap/leaky filler neck code.... I really don't want to buy one of those stupid expensive things. Mine has the evap canister in back so it probably has the dumb valve on it too.
I have a P0441 on my 98GT with ej22 swap. It's an auto. Here's what happened. Swapped in an ej22, drove it for a couple hundred miles with no CELs or any issues. Then blew a HG. Pulled the motor back out and replaced the HGs, put it all back together and BAM after about 15 miles P0441. Found out I broke the stupid vac solenoid on the right (pass.) side of the intake for the evap system. I put a used (tested and working) one in, but I still get a CEL. I can clear it, but it always comes back. What did I eff up?
Some brightons didn't even come with passenger side view mirrors. Since it's a 99 you need to swap in a cluster from a 99. It's really easy to change the mileage, just snap out the retainer, change the mileage, snap it back in and make sure it's all lined up. I've done it a few times swapping clusters around.
Jumpy tach usually is because the disty bushings are worn and the shaft is wobbling around.
I'll trade you an ej25D block for the turbo block....
EA81 oil Pressure/air pressure question
987687 replied to fshnidiot's topic in Historic Subaru Forum: 50's thru 70's
Is there any evidence it's been pumping oil? Easiest way would be to pull the oil filter. If no oil comes dripping out, it isn't pumping. If you're run it much with no oil circulation you've probably fubared the bearings... good luck. -
RIP Legacy
987687 replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The cam gear broke off?!! -
Will an EJ22 from a 92 Legacy work in a 97 Outback?
987687 replied to nickolai's topic in Subaru Retrofitting
No, you do not need a new exhaust manifold. The 92 ej22 will have dual port heads. -
I had my inner tie rod fail because of a bad boot. It didn't break, but I failed inspection because it was pretty loose. I ended up having to replace both inner and outer tie rod ends because the jam nut was so rusted it just crumbled when I tried to get it loose. It ended up being around $100 in parts, but only half an hour labor. It's pretty easy. I just measured the old assembly and matched the new one to the same length. Alignment was fine afterwards. But if yours comes loose, there's no reason to replace the tie rod at the same time. If the joins are in good condition, just leave it. It's extra labor to take it out. So long as it isn't all rusted to hell just replacing the boot should only take 10-15 minutes.
The GL seats are a step worse than the cloth seats in the 2nd gen leggy...
