18
Everything posted by 987687
	If you strip a plug it isn't the end of the world. You can get thread inserts for spark plugs. On the ea81 the plugs come right out into plain view, you can see the threads, makes it very easy to do thread inserts I would think. I've never done this on an ea, but have on an ej22, the plugs are a few inches down in a hole and is a little difficult/scary...
	^^ I'm glad you don't worry about running around on worn out/iffy timing setup. I've been very, very stranded by it. Whether it can be done in car or not doesn't matter when it's dark and raining and you're on the side of the road 80 miles from home in the middle of nowhere. In regards to bolts stripping out and timing belts. The bolt that holds the tensioner to the bracket on the block. I've had that hole strip twice now on me. I PB blastered one from the back side and let it sit, still stripped. I don't get it... I usually just have the machine shop down the road helicoil it to 3/8th.
	Thanks man! Oh, and I forgot to mention. Last week the ej22 blew a head gasket. Not bad, but bubblies in the overflow bottle I understand not why the precious ej22 that never blow head gaskets blew both head gaskets. But that's what happened. I had the engine out late one night, HGs done the next morning, and back in later that day. That sucked. But it's all worth it now.
				RIP Legacy
987687 replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
That's really terrible to look at. So sorry to see this. I love the Legacy SS, and yours was mint. I hope you can make another one beautiful. -
				1999 Legacy SUS
987687 replied to coach9's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Didn't realize you were somewhere you need emissions. I was being kinda facetious because there isn't really any way to make the non-egr engine work right with your setup. -
	I had an alternator go intermittent on me for a few days, then totally quit out. Brake and batt light, low voltage. It turned out to be the the wire that goes to one of the brushes broke. About three weeks after that being fixed the regulator started to go. It would only put out over 1000 RPMs, then 1500, then 2000... you get the idea, just got worse and worse.
				1999 Legacy SUS
Electrical tape? It's been discussed a lot on here. There isn't really any easy way. -
	WOW! Thank you for all the great info Gary! I'll source the o-rings and schrader valves for sure. Doesn't sound very hard to replace at all!! When I had the rad out the condenser looked fine, not bent, no messed up fins on either side, etc. I cut a piece of plywood to protect the condenser so it wasn't damaged. All that came into contact with it was my knuckles I'll also get a black light out there and see if theres an UV dye, great suggestion! Thanks for all the advise guys. This is really awesome.
	I have a 98LGT with 228k miles on it. Only problem with it now is the AC doesn't work. The compressor won't even engage. Tried with defrost, heat on coldest setting with AC button, etc. It will not come on. So I checked the system pressure, and there's no pressure. I guess there's a pressure switch disabling the system? Will recharging the system fix that? Also, since there's no pressure I'm not gonna recharge until the leak is fixed. Where do these usually leak? It will be easy to work on now that it's all leaked out...
	I shoulda taken pics of the one I just did. The ears stick out a bit. The way I gauge the TQ is in far enough is like this. The distance the ears stick out past the tranny bell housing should be LESS than the distance from the engine bell housing to the flex plate. (the flex plate holes where the ears bolt to)
				Gas light not working?
987687 replied to 92_rugby_subie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
In the Legacys I've owned the light is always really good. Comes on at about 2 gal left. In my GL..... I've never seen the light. And I'm known for running so low on gas my engine starts to stall if I go up a hill or accelerate. heh. As you said, it has to do with no money. In my gl I've had the gas gauge pretty darn far below E. Put in 15 gal. which leads me to believe the light is broken. Next time you fill up fill ALL the way up, it's a 15.9 gal tank. Then you can see how close you were to the end. PS. I'm jealous that you have a working speedometer -
				1999 Legacy SUS
The engine obviously has to be high enough to clear the mounts. So if the tranny isn't supported up, it'll go crashing down when the engine comes loose. That's no good. Especially since it's an auto, you will pull the torque converter out, break it, etc. Just make darn sure everything is disconnected though!! Especially the torque converter. You really, really, really. do not want that to come out with the engine. I repeat, you really want it to stay in the transmission. -
				1999 Legacy SUS
I'm having a hard time understanding that ... umm ... sentence? Are you having a hard time getting the engine separated from the tranny? Disconnect the pitch stopper, jack the transmission up high enough for the engine mount studs to clear the crossmember. DO NOT JACK THE TRANNY FROM THE PAN! Jack it from the front diff. Put pressure pulling up on the engine and give it hell. Hammer chisels, screwdrivers, etc into the bell housing crack to separate it. They get wicked stuck.
