				Posts4285
				Days Won18
Everything posted by 987687
	  1999 Legacy SUS987687 replied to coach9's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX I was terrified I was going to break something getting them loose.
	  1999 Legacy SUS987687 replied to coach9's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX It would be really hard to turn a short breaker bar with the final torque. Especially the middle bolts... Those are tight!
	  1999 Legacy SUS987687 replied to coach9's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX With my luck, I'm not surprised I heard you can do them in car too. Never done one before though, so I pulled. Glad I did. I'd have effed it up bad in car probably.. hah
	  1999 Legacy SUS987687 replied to coach9's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX I put a 2.2 in, and it had a blown head gasket
	  Rarest Old-School Subaru Part or Option?987687 replied to Loyale 2.7 Turbo's topic in Old Gen.: 80's GL/DL/XT/Loyales... Well that was silly of them.... I love subarus... But I wouldn't trade a 74 mustang for one!
	228k on my Legacy. ej22 swap made it to be alive again!
	  1999 Legacy SUS987687 replied to coach9's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX Two top bolts, one is shared with the starter mount. Two bottom. And two locating pegs. They might be missing from your swap engine leaving un-threaded holes. You'll have to swap the pegs over, no bigger, vice grips pulls them out. It's an SUS, so it's an auto. Be sure you have all four torque converter bolts out, and then push the torque converter back away from the pressure plate so it doesn't come out with the engine.
	I like the AWD in my daily commuter suby. Going from snowy to dry pavement in the winter, my nasty driveway to pavement, doing hill stop on a steep slippy hill that turns into pavement 10' later... AWD is wonderful Now I LOVE the 4wd in my GL, especially with low range. In heavy snow, offroad, getting unstuck, pulling people out, etc. The locked center is absolutely awesome. So the way I see it is, 4wd is more fun offroad and playing around, but AWD is a lot better for just everyday driving. AWD is also wonderful for street performance. 4wd can't even compare in that respect.
	  1999 Legacy SUS987687 replied to coach9's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX If you can pull a engine, you can do the 22 swap. It's very easy, no electrical work needed! Only other thing you have to switch might be the AC bracket from the 2.5. Not all AC brackets are created equal. Do the head gaskets on the 22 before you swap it in! I didn't, and regretted it.
	For what it's worth, I just find it easier to disconnect it at the top... That way I don't have to deal with the cable attached when I'm working with the controls. And it's a pain in the neck (literally) to bend my head down under the foot well and look for the other end. Just pull out the two clips and it's disconnected. A good pair of needle nose vicegrips make it a piece of cake.
	And being an auto nobody ever uses the e-brake.... I just don't understand how if the cable was seized the handle would still pull up, and pull the cable. But I'll have someone pull the handle and I'll watch to see if the shoes expand. I'll search around how to adjust the shoes, never done it that way before...
	Judging by the look of the license plate....... Those lights are doomed
	Auto and manual engines are the same, so yes. Either will work. I believe the phase2 all had EGR, so that's not an issue. Before dropping it, do a reseal and timing belt. No need for new head bolts, people don't replace them and do fine. Subaru head gaskets only!!!! Subaru thermostat, and replace all other gaskets and seals while you have the motor out. Do the timing belt, all idlers and new tensioner. While you have it off good time to do crank and cam seals. Reseal the rear separator plate, but DON'T do the rear main seal if it isn't leaking.
	  Rarest Old-School Subaru Part or Option?987687 replied to Loyale 2.7 Turbo's topic in Old Gen.: 80's GL/DL/XT/Loyales... Mine hasn't ever had an issue..
