18
Everything posted by 987687
If you do get it stuck (bound up). Just reverse, and it'll unbind. Or while going forward punch the gas and let off the gas while pushing the lever to try to get it out if you can't reverse for some reason.
you don't get any with an ea82...
My d/r clunks a bit when I engage/disengage 4wd. It's pretty normal for any 4wd tranny to clunk when going in and out of 4wd. But NEVER USE 4WD ON DRY PAVEMENT!!!! that's the first rule of 4wd in any vehicle!! There's no reason to anyway. And you yours is 4wd even on the s/r. The orange button clearly says "4wd" on it and you get the 4wd light on the dash.
Car look awesome!! Good find. And yes, those are for testing the ECU for trouble codes. There's a lot of info on the board on how to use them.
It doesn't always happen to me though. Maybe 1 in 10 times when it's acting up, which is intermittent. I guess you already have a thread for the misfires, but replacing the injectors is not what I'd do first... Plugs and wires, timing off, coil may be going since it's on 3 cylinders, etc. Anyway, back to my issue.
If you have misfires on 3 of 4 cylinders, you've just found your stalling issue. Fix the misfires and you'll be fine. And I have not fixed it yet. Although I'm fairly certain it's the cluster causing the issue. I have been away for the last 2 weeks on 3 different road trips, 5 different states, and 2 countries... But sometimes I'm gonna take out the cluster and clean the contacts on all the plugs if they're oxidized. I'm thinking maybe it's a connection issue.
You'd have to add material somehow to make it work.
GL Sedan the same running gear as GL Wagon?
987687 replied to BioHazard2222's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm not positive on suspension. But engine, diff, and tranny should be the same. -
If by running gear you mean drivetrain, then yes. It's the same. -
TCU location and troubleshooting
987687 replied to swampbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The AT should be way overfull when the engine is off. The torque converter drains when the engine is off, but when the engine is running it fills back up again. This is why you should always check the tranny fluid when the engine is running. You'll only get a correct reading with the engine running and the transmission warmed up. -
If you search the net there are some pretty good writeups on it. You will have to at least move the rad fans to pusher fans on the front of the rad. Some cars have to have the rad moved forward even and have the support cut and welded. But it's been done time and time again, the info is out there. No idea about the a/t though...
If it worked fine before, it's either the wheels, tires, or your 6-lug conversion. Wheels and tires are easy to check, take them to a tire shop and have them checked. If your lugs are loose it would shake, as mentioned. And also check your axle bolts. If you didn't bolt the hub back on tight enough, or forgot the cotter pin and the nut comes loose. It would be shaking (and destroying your bearings...)
It's a good combo to have! One to offroad, and one I can drive thousands of miles and not worry about! The front tires are arctic claws. I got them studded and pulled all the studs out. I hate studded tires, but I got them because they were wicked cheap and brand new. The back ones are something, I dunno. Big grabby tires though the size is 205/75/14.
BRAT with a "Sport" package
987687 replied to Twitch de la Brat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Do you have the big or small valve heads? Because I was pulling on you up that hill, and that was when I had the very corroded disty cap and rotor. -
.::I am new to site...just saying hello::.
987687 replied to nummymonkey's topic in Old Gen.: 80's GL/DL/XT/Loyales...
out of curiosity... where in maine? -
