18
Everything posted by 987687
Sensen Struts anyone use them? from APX on ebay?
987687 replied to Scott in Bellingham's topic in Suspension
A friend of mine bought them, blew them out in under 10k miles and they never rode very well. I've had the same experience with Gabriels. For $100 more you can get a set of KYBs and they'll last 5x longer. -
Replaced all the struts on my forester. The fronts went pretty well, and the rears went ok, too. Except that I have drum brakes and when I touched the brake lines they disintegrated... Fortunately I keep a roll of brake line and flare nuts so I replaced those. Then while bleeding I noticed the line further up weeping, fixed that.... Stupid cars. By some miracle I managed in getting flare nuts AND bleeder screws loose on both sides. All that stuff looks like it was dredged up from the Titanic, so I was pleasantly surprised.
You're asking for opinions, and mine is that I don't like window banners. They're tacky and often draw the wrong kind of attention to your vehicle.
Use size zero... Seriously, don't do a window banner.
If you have to ask, generally no. It would be cheaper, more reliable, and less work to just buy a car that came with a turbo.
Make sure you get a thermostat from the dealer!!! I don't need to say more than post this picture. Someone who is fast at doing subarus should be able to bang out a timing job in an hour, it's not very hard. Yank the radiator (if you're doing the pump, why not, it's 2 bolts), then there's great access to everything on the front of the engine. If they don't have the right pulley holder tool for getting the cam pulleys off, those can waste serious amounts of time...
Put some mud tires on it and go offroading, it'll feel right at home with its new scuff and scrape friends
Can you take a picture? It should be held in with three screws. One of them is probably obscured by a plastic thingy for the power wires, the other two might be under other wiring harness wires. But as for as I remember, it's the good old 3 bolt style blower setup subaru has been using forever. Get some pics and we'll see what's up, or point you in the right direction.
I see napa gold filters recommended by peolpe on here and other places on the net. I use them because that's what's close to me and I like hemorrhaging money at napa. But apparently they're made by Wix and one of the only brands that has the proper bypass pressure. I haven't had any issues with them so far. Just don't by Fram.
I'm up in Orono, welcome to the club!
There's a spring and a plunger in the door switch. When the door is open, the plunger makes contact with the body and grounds the light bulb, causing it to light up. When more than one door is open, there's more than one ground path, which is why dome lights sometimes get brighter with multiple doors open on older cars... This is because the switches get corroded and dirty and stop conducting electricity as well. The other way this can go is your problem, the switch never stops conducting electricity. If the light doesn't ever turn off, you have a short somewhere. The wire that goes to the door switches is somehow being shorted to ground, or one of the switches is full of corrosion and is always conducting a small amount of electricity which causes the light to come on dimly. Basically, you'll need to trace the wires from the door switch to the dome light, make sure they're not broken/shorting to the body, and make sure the switches aren't rusty, full of water, or corroded.
The stock intake is already a cold air intake, flows well enough to add a turbo and decent horsepower, and does a good job at keeping water out. As such there's zero performance anything you get from chrome garbage. Same deal with the exhaust system. The n/a is slow and steady, not much you can do to them. The 3rd gen is a heavy car and there isn't much you can do about gas mileage. Mine was a dog, but it was comfortable and cruised nice down the highway... until the subframe cracked in half....
