18
Everything posted by 987687
WOW jealous. I really want (need) to find a clean wagon. My sedan is rusted to bits and my outback pushed me over the edge and I'm selling it ASAP.... Lucky find!
self inflicted steering alignment issue
987687 replied to joe5's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Jack up the wheel and shake it side to side and up/down to make sure something isn't loose. If the car showed up at my shop with that description, that's where I'd start. Something must be loose, so find it. -
That's going to be a monster with a supercharged 3800! Damn. You'll be pushing way more than 200hp. I love it!
I have a driveshaft I cut off in the junkyard. I use that as a plug whenever I have to pull a trans. It fits perfectly and makes it not leak
- 14 replies
- ea81
- transmission
(and 1 more)
Tagged with:
Don't let Worst Buy touch your new car. They'll cut the wiring harness up and make a disaster of everything. I've had to work on cars butchered by them and it's a sad sight
Crank Pulley seal ? W/ ? behind seal.
987687 replied to Dinky26's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The new seal probably does have a spring inside of it. You just didn't look hard enough. If it doesn't it's a crap quality seal that's gonna leak. When you removed the old seal, the spring came out. It happens, it's not a big deal. Don't remove the seal you just put in, you'll break it. It looks like you have plenty of room to carefully extract the old spring. Put everything together and you'll be fine. -
Ball Joint change 94 subaru Loyale
987687 replied to Kraig's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sounds like as you jack, you're pulling the hub outward. Be careful not to do that too much as you can pop the axle apart. I usually put the balljoint in the knuckle first, push the balljoint all the way inward. If you leave it sticking straight down like it comes out of the box, yea, it's hard to get in. On a lifted rig sometimes you have to use a ratchet strap or similar to pull everything inward enough to get it together. Not lifted it should go together fairly easily. -
The balljoint came out of the knuckle easily? DAMN, you're lucky. Yea, I'd put it back in so I could pry the other side out. When you're prying, hammering, swearing, etc leave the nut on there, just a few turns loose. You don't want it to come loose and hurt yourself... Ask me how I know about that -
It isn't really either. There's a pinch bolt that holds the balljoint into the knuckle, and a taper seat with a nut that holds the balljoint into the control arm. I've never used a press to get them out, I've always just used a big prybar, swearing, hammer, and the torch... If you live in a rusty area, it's gonna be stuck. Be really careful not to break the pinch bolt, there's no excuse to break it. If it's stuck, use penetrant, heat, and patience. Breaking the pinch bolt ruins your day. -
I've heard of exhaust systems doing that before... I had my catback fall off on the highway once. It was hitting the road making a terrible noise, and I just KNEW as I drove over the rumble strips to pull over it was gonna catch.... And catch it did! Fortunately it was so rusty it just crumpled like a pretzel instead of pole vaulting my car into the woods.
- 27 replies
- 1997Legacy
- Outback
(and 2 more)
Tagged with:
BRAKE light on.
987687 replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I think it's plastic. Although a friend of mine who is a tech told me when the foam ones sink it's because there's water in the brake fluid. It absorbs water and sinks. -
BRAKE light on.
Found the problem.... The float for the low fluid switch ... SANK. I used a piece of stainless bailing wire to fish it up, the DRLs come on and the BRAKE light goes out. Let go and it slowly sinks back down to the bottom. WEIRD. I unplugged the harness so it isn't grounded. Not ideal because now I don't have a low fluid warning. But leaving it plugged in leaves the light on and annoys the spoob out of me. So yea, never seen that before. -
BRAKE light on.
I've never seen a subaru with sensors in the brake pads... just euro cars. Maybe newer subarus do? dunno You hit it on the head, DRLs don't come on. So it has to be the wiring to the parking brake handle somewhere. -
The BRAKE light is lit on the dash of my manual 2000 outback. Things I have confirmed are NOT the problem. Parking brake switch makes contact when handle goes up/down. Master cylinder reservoir is full of fluid Alternator is charging correctly (bat light isn't on anyway) Nothing seems wrong with the car, just curious about the light.
I've worked an a lot of subarus, all the 2.5s blow up. Yes, even your single cam ones. When the SOHC 2.5 in my outback blew up I got a 2.2 shortblock from the junkyard for $40. So they're not too expensive. Of course random guy on craigslist is gonna want too much, but when you know somebody at a junkyard
Friend has a 2000 Forester with a manual transmission. It doesn't have an engine. So the big question is, which of the two crank gears is this car supposed to have? I know around this time they could either have the reluctor wheel with a lot of teeth, or the older style with not so many teeth. It would be fantastic to know rock solid for sure which one it needs before having to change them out in car. If anyone knows for 100% sure which it needs, that would be great... We're trying not to confuse this anymore.
