18
Everything posted by 987687
I think it's completely correct that the Mayan calendar was designed to run up to the end of the world. It did! The world (from a Mayan perspective) has ended. Since it's a dead civilization, it's the end of the world for them. Done, gone. But what I don't understand, is why are people in the 21st century reading more into the whole thing than there is? Get over it, move on.
That's a good idea. I might have to give that a try, see if I can make it work on a subaru. The issue here is getting it out of the knuckle, but same method should apply. I still can't get the driver's side ball joint out of my gl. Either the cortrol arm or the knuckle. I had both loose so it could have popped out of either. I have a 4' crow bar jammed in there jumping on it... They can stick wicked tight.
Autozone mis-diagnosed something and threw parts around, at the owners expense? NO WAY.... Did they even CHECK the battery? Sounds like alternator if it's low at idle, but fine voltage at higher RPMs. It could be a tired alternator, or it could be tired wiring. No way to tell without some volt meter testing.
It really comes down to what you want to do. But if I was doing a tranny swap this afternoon, I'd leave the engine in the car. Since loading a tranny in from the top is a real back breaking PITA (in my opinion), I won't even go there. So that means I'm loading it in from the bottom. It might save a bit of time pulling the engine too, but not as much time as it would waste. Disconnecting everything, draining the cooling system, pulling rad, dealing with tranny cooler lines, BLAAAH. Do not want. It's the same thing with head gaskets... some people swear by doing it in car, some people swear at it. Do whatever works best...
The turbo and exhaust going back is more than enough back pressure. The turbo is a pretty big restriction. Intercooler is probably a good thing to do. It will help the engine run cooler AND give you more power.
seems like the shift linkage has bound up
987687 replied to stinkydogfilms's topic in Old Gen.: 80's GL/DL/XT/Loyales...
5speed in a brat? Did you swap it? There are adjusting nuts on the cable where it goes through the clutch fork. You should have about 1/4" play at the fork, and have a return spring. If the clutch isn't disengaging the cable is probably getting old and stretching, tighten it up a bit. -
The last one I did. I shoved the transmission under the car into the tranny well, then I hooked the cane up to the pitch stop mount on the bell housing of the tranny. Lifted it up, then used a floor jack to lift the back of the tranny up. Using this method you can control exactly where the tranny goes, what angle it comes at the engine, and all without fear that it's going to fall off the jack. Because it's being lifted from the highest point of the bell housing. I changed a GL transmission like this, come-along from the ceiling and spare tire jack under the tail. It only took about 2.5 hours. I'm fairly certain in the impreza you'll have room to get the front of the tranny lifted with a crane. This way makes it way easy. You can do it engine in car. And the auto means you don't have to deal with getting splines matched up.
I found a N/A loyale dyno run video
987687 replied to chaseman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
On the highway from the moment I put my foot to the floor to the moment the transmission shifts into 3rd is about 1/4 second. Actually, probably less... I can live with that. It feels instant. -
That's quite the beast! I love it!
The gearing in the 4eat pisses me off. I think my 2.2 auto is slow... I don't know how you can deal with a 3at. If it would just blow up I would have an excuse to use that pile of 5speed parts in my garage... 65 whp is pretty decent for a GL. Although mine has the ea81, so it's even more anemic than an ea82. -
92 Loyale check engine codes
987687 replied to Chevydog89's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The haynes is decent, I reference it from time to time if I need a picture of how something is gonna look, or another opinion on how to fix something. For really important things though like head torque, I wouldn't use it. It does have some stuff wrong. -
The inner tie rod is actually really easy to replace. I've done a few of them with no special tools. Unstake the washer, there are two different designs here. It's obvious once you have the boot off. Then I just use a big pipe wrench to break it loose. It's a good idea to replace the boot while you have it apart. It's not that expensive, and it's a no fun thing to replace after you have it all aligned. If there's any play at all in the outer end, it's a good time to replace that as well. The trick to getting that loose is taking the castle nut off, and beating really hard on the 1" thick metal of the knuckle right where it goes in. Since I'm bad at describing things, here's a picture (not subaru). Hit where that nub is sticking out. http://www.autoclinix.com/Mercury/TieRods2.jpg
