18
Everything posted by 987687
Loyale 4wd rear crossmember?
987687 replied to pr8head's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Except for the mount for the diff, are there any other differences in the 2wd one? If that's the only difference, I wonder if one could just cut it off the old one, or fab a new diff mount. I've had to do the same replacement on mine, besides finding the part, it's a pretty easy job. You unbolt everything from the tube, then just take the tube off. Here's right before I started unbolting the tube. -
Honestly, I'm not the one to ask... I live in Maine. I was just down there for a few months on a business trip.
It depends on the time of year, I don't know what the rules are. But I looked it up, and I was there in a time of the year when it was free. There's a time when you have to pay, when only residents can drive (or something), and during the summer months nobody can drive on the beach. They don't want tourists getting run over, and more importantly, nesting turtles and stuff in the sand.
Great, you don't want a lot of tread to run in sand. The idea is to float over the sand, not dig in.
Ea82 dash clock ipod upgrade! Now with pics!!!!
987687 replied to AKghandi's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It looks good! Nice work. -
That's a lot of upside down welding sheet metal. I know how much that sucks. Nice work!
The last 97 impreza gauge cluster I had the displeasure of pulling out was a cable. They probably changed in 99 or whenever they went to the phase2 engine.
You should use CV grease for CV's. Napa sells it, it's about $5 a tube. The big zipties work great on the axle boots.
Technically it won't seal without the pipe in the fitting. Because the nut presses the pipe into the seat, the right way to do it is to crimp the pipe off and weld it shut. For the dipstick I have an ej22 dipstick cut to the right length with a mark on it. That way it doesn't have a broken off handle thingy.
The One Behind the Wheel! (Pics of Us!)
987687 replied to Loyale 2.7 Turbo's topic in Meet n' Greet. Your USMB Welcome Center
14" pugs with a badass paintjob.- 420 replies
- Loyale 2.7 Turbo
- JesZeK
- (and 8 more)
987687 replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hey look, he can keep up with it. The STi is faster than him... :-p -
ya, my car is a cable. Cable converter boxes are stupid expensive. I just really blatantly don't care.
Does the engine make a knocking noise while the light is on? I had an ej25 that did this. The oil light would be on for about 5 seconds, maybe more every morning. Even for a couple seconds after sitting half an hour. It made a horrible racket, but shut up a bit after the light went out. It was just tired, got worse and worse till I swapped the motor :/ Never tried re-sealing the pump or anything, with 245k miles it wasn't worth it fora 25d.
The clock in my GL works fine... I should probably take it apart and do something to it before it dies... But if it does, i'll just put a LCD in there and make my own display. I think I still have some serial LCD boards laying around somewhere... -
These blinkers suck so bad. You can't see them unless you're looking direct on at the car because they're set so far back. It's not uncommon for me to be at an intersection and people don't know if I have a blinker on because they can't see it. I keep meaning to add a relay or something so they also turn on the corner markers.
The speedo cable has been broken since I got it. I don't care to fix it anyway as it would read wrong with the tire size change. I actually have a digital VSS in the tranny now. So someday I can wire up a digital one...
My speedo always says zero. It's been broken since I bought the car, and unless I get really bored, it's going to be broken forever...
4x4 EA series rear wheel bearing
987687 replied to 81EA81's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've done it with a punch, and it worked fine. I didn't mess anything up. I have a thread about rear wheel bearings with pics in the USRM. -
Are you calibrating for tire size diference? With bigger tires the speedo will read lower, you need to multiply your gas milage by the percentage in tire size change to get an accurate number.
