Everything posted by 987687
Need 94 EJ22T help!
987687 replied to oleman77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's not interference, I don't see how a bad timing belt could ruin the engine. Fix it in his driveway and take it home... Are the covers off? Can you see the belt? Just rotate the crank until the marks line up, if they do all line up correctly, then ya, something else is wrong. I bet the belt is off though.
Need 94 EJ22T help!
987687 replied to oleman77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX^ I agree, the timing belt isn't on correctly.
2012 Impreza.. direct injection???
987687 replied to MR_Loyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot direct injected. I hope subaru does that in the future. Dunno if it's interference or not, probably is. Most engines these days are to get tighter clearance in everything. It has a timing chain though, not a belt. So it isn't of much concern.
Installing flywheel
Off the top of my head flywheel is 51, and pp is 11.5.
Importexperts timing belt kit
987687 replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTHAT TOO!! I'm gonna weld enough of the GL to at least make it safe to drive. Really just needs new rear end and axles.
Whirring noise on deceleration.
987687 replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNorm's. $150. Blech, but 56k miles. It should last longer than the transmission.
Rusted Our Rear Crossmember
987687 replied to mikec03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAt least your nuts came out. I just replaced my diff and had to sawzall the suckers off.
987687 replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis would explain why it was making bad noise.
987687 replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXArea geographically? In that case, I have no idea. I should go to california... Or engineering... That's what I've always wanted to do.
987687 replied to mikec03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTaking off the rear diff is actually really easy. You remove the two crossmember brace things that go under the axles (you'll see what you look under there). Take off the four bolts on the bottom of the diff, four bolts holding that plate on. The four bolts holding it to the driveshaft, and the two bolts on the back of the diff. Just drop it down and pop the axles out. You don't even need to unbolt any suspension to get it out. If a 95 has axle roll pins, punch them out. I can't remember when they changed that over, but doesn't add much complexity. The rusted stuck lat link bolts are going to be much more of a problem than the diff. Since I work on cars in Maine, I've probably had to sawzall 50% of them off... Esp the ones on the gas tank side, I'm afraid to use a torch right up next to the gas tank.
Ben's been in an accident
That really sucks to see I'd figure out which part of the core was leaking coolant, and crimp it off. Melt some lead into the crimp and it shouldn't leak. If it's the tank scuff it up and JB weld it.
987687 replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWorking on getting into computer engineering at UMO...
Dropped plastic tube into Front Diff. filler hole.
987687 replied to jontyuk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have the dumb black box. So I have the tube style. But my tube is long enough it can't fall all the way in. edit... I just read what I wrote... I'm too tired to change it, but it came out sounding really bad.
Replaced the rear diff in my Legacy. Good riddance high pitched scream.
987687 replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for the advise, GD. I always appreciate your opinion. I don't know how long I'll keep the car, just signed up for college. It's a good reliable car, so I'll probably drive it through college. I'll just change the belt in 60k with one of better quality to last 105k. I don't know if the automatic transmission going to last another 60k (300k miles) anyway...
987687 replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMine started as a high pitched whining only on decel,and only over about 60. Then just got worse and worse. At low speeds it was a nasty grumbly noise, high speeds it was a ear retching whine.
987687 replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe idlers aren't the dual bearing type. The cogged one is, though. The timing belt doesn't have a brand stamped on it, just "Made in the USA". It's a lot stiffer than other timing belts I've bought from napa, or wherever else. I was pretty sure the kit I ordered had the seals included, maybe not. That stuff I don't really care about so much. I saw you post somewhere else about not working on cars, maybe I missed a thread. Why have you been out of the business?
987687 replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXReplaced the diff with a 56k unit, it's all quiet again It sucked though. I had to sawzall off the back two bolts. It wasn't any fun.
987687 replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo I got the kit. I'm not impressed. They didn't include the crank or cam seals, the thermo gasket is thinner than OEM, and a paper WP gasket. Not a huge deal, I have to go to the dealer anyway for the oil pump o-ring. The WP looks flimsy... It's considerably lighter than any of my Subaru ones sitting around. It has the stamped rotor :/ Whatever, it'll probably be fine. What annoys me most is that for the two idlers, they gave me two of the single bearing kind. Not one of the dual bearing kinds for the one top right, looking at the front of the engine. Hopefully it holds up, but part of me doesn't want to have to go back in there and deal if it next year.... Not impressed so far by theimportexports kit :/
Parking light switch
Ea82? It's just a single pole single throw switch. Hot pin in the middle. When you rock the switch one way, it gives power to the tail lights directly (to kill your battery), and the other way puts the tail lights through the ignition circuit. When mine broke I just twisted the two wires together to make it come on with ignition. Worked till I got it fixed. I can't remember off the top of my head if the right or left one is through ignition, but test it. Short the middle to the right wire, then the middle to the left wire.See which ones makes it go on and off with the key.
HELP!!! Caliper mounting bolt size?
How the hell do all your lug studs sheer off at once!? Yikes! That's an awesome fix though
Which one? I suppose it would be worse to loose the bottom bolt. With the bottom bolt out, the caliper will want to pivot up and into the wheel. With the top one missing, the force of braking will just twist it tighter into the knuckle.
I concur. At least get a red one so when you open your hood it LOOKS high performance...
Free EA82 Timming belt install Instructions
I've always wondered... Why can't you just install the belt with the driver's side cam pointing down, then install the pass. side without rotating? Does the cam not like to stay in that position? Never had an ea82.. So always wondered that.
Can bad wheel bearing cause more damage until serviced? Cost Parts & Labor?
987687 replied to mountainwalker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlso compare side to side. If you brake from a stop going 60mph it's going to warm the hubs up a bit.
