I need some help. I will try to make a long story short, I am on my 3rd engine in the last 6 months on my hovercraft Ea82 CARB.. First one I bought, apparently had been run really hot because when I changed the head gaskets I stripped out every bolt but one when I was re-torquing them.. 2nd Engine was a Turbo that ran good, when I bought the car,but i could not make it fit with the turbo unit in my Hovercraft. 3rd engine, I swapped for the turbo I had bought. I replaced the oil pan gasket, valve gaskets and intake manifold gaskets and I added a weber carb. I fired it up tonight and it was blowing coolent out the exhaust. I checked all connections and hoses and tried again, thinking maybe there was some moisture in the gas. I added some coolent to the radiator and while I was doing this i noticed that water was now flowing up and out my new Weber Carburetor!! What the Heck is going on? I checked the oil and it is a milkshake now. When I changed the oil when I bought the engine, it was dirty, but didn't have any antifreeze in it so I assumed everything was good. I have now run the moter for about 1 minute and its a mess. Any ideas? I pulled the intake maniford and the ports are full of antifreeze and spilling out. is my intake manifold cracked inside? I am wondering because this is the same manifold i used on Engine #1 and it was also blowing water, but the heads were blown so I thought the heads were the problem.
Sorry i dragged this out, please help.
Tks Scott
